Fence construction
Discussion in 'UK DIY' started by Chris, Aug 10, 2009.
  1. Chris
    Chris Guest
    I need to put up some fencing, and need a little advice...
    1) I intend to use shiplap (feather edge?) boards. Seems like 150mm is the
    standard width. How much overlap should I account for when calculating how
    much i need? I am thinking about 25mm.. suggestions?
    2) I have a wooden posts concreted in, and so i need to fit the horizontal
    rails to which i'll attach the boards. I have noticed that fencing put up by
    proper contractors use a non-square section.. the top surface slopes,
    presumable to stop rain sititng on it. I can only find 2"x2" at B&Q, so i'll
    get it from Jewson. What do I ask for? I dont want to make a tit of myself
    by describing the section over the phone :)
    3) There is gonna be a lot of nailing to do when putting the boards up. I
    have a domestic ue nailgun.. fires 40mm nails rather nicely, though they
    dont have a huge head, they are more like mini brads. What the consensus
    that this will be fine?
    4) Any other tiips welcome :)
    Cheers,
    Chris
    Chris, Aug 10, 2009
  2. zaax
    zaax Guest
    Chris wrote:
    > Hi,
    > is the standard width. How much overlap should I account for when
    > calculating how much i need? I am thinking about 25mm.. suggestions?
    I over lapped mine by 1/2.
    > horizontal rails to which i'll attach the boards. I have noticed that
    > fencing put up by proper contractors use a non-square section.. the
    > top surface slopes, presumable to stop rain sititng on it. I can only
    > find 2"x2" at B&Q, so i'll get it from Jewson. What do I ask for? I
    > dont want to make a tit of myself by describing the section over the
    > phone :)
    go to a timber yard - they will have lots of different types
    > up. I have a domestic ue nailgun.. fires 40mm nails rather nicely,
    > though they dont have a huge head, they are more like mini brads.
    > What the consensus that this will be fine?
    Only two nails per board, one for each rail. Also don't knock them in
    fully encase it needs to come down in a few years time. Actully mines
    got to come down soon and I might put them back up with screws next
    time.
    leave about 12" between the top rail and the top of the cant. So anyone
    trying to climb over it will break the board off.
    Read here
    http://www.gardeningdata.co.uk/construction/boardfence/fence_rails.php
    and google it.
    zaax
    Frustration casues accidents: allow faster traffic to overtake.
    zaax, Aug 10, 2009
  3. Chris wrote:
    > Hi,
    Maybe too much, 10 - 15mm will be fine. The bigger the overlap the more
    boards you will use & the more nails you have to put in.
    > phone :)
    You can buy 'cant' rails which are rectangular in cross section, but with a
    sloping top - a Trapezoid IIRC. These rails fit onto the face of the post.
    Or you can have arris rails which fit between the posts using arris rail
    brackets.
    No good at all, 18g brad is far too small.
    Make up a jig to keep the overlap the same without having to measure every
    time and use a string line to kep the top of each board in line.
    Dave - The Medway Handyman
    www.medwayhandyman.co.uk
    The Medway Handyman, Aug 10, 2009
  1. KJR
    Deck Construction ?
    KJR, Jul 17, 2003, in forum: UK DIY
    610
    Andy Milner
    Jul 19, 2003
  2. Replies:
    543
    willshak
    Jun 7, 2007
  3. David WE Roberts
    20
    1,099
    David WE Roberts
    Sep 10, 2009
  4. Robert
    Concrete block construction with construction adhesive
    Robert, Oct 20, 2003, in forum: Building Construction
    23
    2,812
    Ed Kliman
    Oct 22, 2003
  5. gy
    30
    1,241
