Exterior Wood filler
Discussion in 'UK DIY' started by IMM, Feb 17, 2004.
  1. IMM
    IMM Guest
    I have an old sash window that has just shown signs of rot. A cavity has
    appeared in the wood frame. This will have to be done properly by replacing
    a section of the frame in the summer or so. What type of filler could I use
    to see it through the next 6 to 9 months? Anyone have any ideas?
    IMM, Feb 17, 2004
  2. IMM
    Grunff Guest
    Car body filler (styrene resin filled with either aluminium or polymer
    powder) will do a good job of sticking to pretty much anything as long
    as it's dry. You can subsequently sand and fill it.
    Grunff
    Grunff, Feb 17, 2004
  3. IMM
    IMM Guest
    "Michael McNeil" <> wrote in message
    > "IMM" <> wrote in message
    > news:c0rml2$7oj$
    has
    replacing
    use
    > Is this a joke or are you even more of a tit than I thought?
    Do you mean I should not use a filler? How strange!
    IMM, Feb 17, 2004
  4. IMM
    Dave Plowman Guest
    In article <c0rml2$7oj$>,
    > has appeared in the wood frame. This will have to be done properly by
    > replacing a section of the frame in the summer or so. What type of
    > filler could I use to see it through the next 6 to 9 months? Anyone
    > have any ideas?
    And I thought you lived in a modern super insulated house. Something else
    you've made up?
    For a repair to only last a few months, I'd use mortar.
    Car body filler - Isopon etc - is better, but not worth the expense for
    such a short time.
    *See no evil, Hear no evil, Date no evil.
    Dave Plowman London SW 12
    RIP Acorn
    Dave Plowman, Feb 17, 2004
  5. IMM
    Grouch Guest
    news:c0roh0$hp0$...
    > news:...
    > > news:c0rml2$7oj$
    > has
    > replacing
    I
    > use
    If you read his posting properly you will see the light. ;o)
    Get some dry wall plaster this goes hard as nails but rember to paint over
    it
    Grouch, Feb 17, 2004
    Car body filler if painting afterwards.
    Use brute frce and wire brushes to remove all punbky wood, then
    treatwith staivilisinf stuff - actually superglue, and =knooting both
    eem to bind soft fi=bers together.
    When that lot has set, slap on two part polyester resind mix =- P38 or
    chemical metal are the usual 'brands' - shape as good as you can with a
    poutty knofe, allow to half set (5 mins) then sand like firey as once
    set rockhard it takes forever to sand down.
    That will outlast any wooden frame you have left by aboutt 100 years.
    The Natural Philosopher, Feb 17, 2004
  7. IMM
    IMM Guest
    "The Natural Philosopher" <> wrote in message
    has
    replacing
    use
    IMM, Feb 17, 2004
  8. IMM
    stuart noble Guest
    Dave Plowman wrote in message <>...
    >such a short time.
    Cheap from trade outlets. £10 for 3.5kgs with 4 tubes of hardener.
    stuart noble, Feb 17, 2004
  9. IMM
    Dave Plowman Guest
    In article <STnYb.166$>,
    > >such a short time.
    And a handful of sand and cement costs...?
    *24 hours in a day ... 24 beers in a case ... coincidence? *
    RIP Acorn
  10. IMM
    PoP Guest
    On Tue, 17 Feb 2004 00:24:17 +0000 (UTC), "Michael McNeil"
    Put it this way, if there were two of him then Jordan would feel
    intimidated.
    PoP
    My published email address probably won't work. If
    you need to contact me please submit your comments
    via the web form at http://www.anyoldtripe.co.uk
    I apologise for the additional effort, however the
    level of unsolicited email I receive makes it
    impossible to advertise my real email address!
    PoP, Feb 17, 2004
  11. IMM
    Bob Mannix Guest
    has
    replacing
    use
    Whatever you do, don't sniff the glue - it plays havoc with your keyboard
    skills :eek:)
    Mind you "sand like firey" has a certain ring of truth about it!
    Bob Mannix
    (anti-spam is as easy as 1-2-3 - not)
    Bob Mannix, Feb 17, 2004
    #11
  12. IMM
    stuart noble Guest
    Bugger all and, as a wood filler, you would get what you had paid for.
    #12
  13. IMM
    Pete C Guest
    Car filler is not necessarily a good idea, sometimes the 'filler'
    ingredient is talc which is quite porous. Also car filler isn't very
    flexible so may pull away from the wood as it shrinks when the weather
    gets drier.
    For a temporary repair fill the cavity with expanding foam, sand the
    foam flat then tape over it with aluminium tape and paint over that.
    It's also worth treating the hole in the frame with wood preserver to
    minimise further rot.
    For a more permenant repair first chisel the rotten wood away to good
    leaving a clean regular shaped hole. Then cut a piece of similar wood
    to fill the hole as neatly as possible but slightly proud to the
    surrounding frame, and treat the wood and the frame with preserver.
    When dry glue the wood fillet in with a good polyurethane
    adhesive/sealant such as Sikaflex 221, and when that has set sand the
    new wood flush to the frame.
    Hope this helps,
    Pete.
    Pete C, Feb 17, 2004
    #13
  14. IMM
    Dave Plowman Guest
    In article <6stYb.354$>,
    Since it's only got to last a few months I can't see the point in spending
    money. Perhaps you've got more than me. So saying, IMM is good at spending
    other's money, so perhaps I should be recommending a gold inlay.
    *You! Off my planet!
    RIP Acorn
    #14
  15. "IMM" <> wrote in message
    news:c0sr9p$fke$...
    > news:...
    Cuprinol wood hardener?
    Michael Chare
    Michael Chare, Feb 17, 2004
    #15
  16. IMM
    IMM Guest
    "Michael Chare" <> wrote in message
    news:c0tvv6$m26$...
    > news:c0sr9p$fke$...
    > > news:...
    Is that what all that says?
    IMM, Feb 17, 2004
    #16
  17. IMM
    Grunff Guest
    > gets drier.
    I don't know what car filler you've been using, but it's *nothing* like
    anything I've ever used.
    The resin is normally styrene, and the filler is almost always either
    polymer or aluminium. It's very flexible, and never shrinks.
    Have you ever actually tried sanding foam??? I have...
    Grunff
    #17
  18. IMM
    Pete C Guest
    >> gets drier.
    I was thinking of more common body fillers like Isopon p38. Looking at
    the MHDS:
    http://www.u-pol.com/countries/en/downloads/hsds/isoponbodyfillerrange.pdf
    it reads:
    "4. Mineral filler (which is a constituent of most body fillers), "in
    excessive quantities", is considered a moderate
    risk and, therefore, it is advisable to provide proper working
    methods/machinery to minimise the risk."
    Sounds like talc to me, as a polymer or metal is not a mineral. Talc
    is an ideal constituent for filler as it's cheap and easy to sand. A
    polymer would react with the styrene, or melt and clog the sandpaper
    whilst sanding, and aluminium would be an absolute b*tch to sand
    down!!!
    Sorry I meant the wood itself shrinks and expands due to changes in
    humidity throughout the seasons. Car body filler is only slightly
    flexible and has fairly poor adhesion to wood if it gets damp and/or
    moves due to humidity changes, so will separate from the wood over
    time. Car body filler is fine for interior use though.
    No, what sort of foam was it and how did you sand it? I would have
    thought a belt or random orbital sander would do well enough. Cutting
    it with a sharp knife might be another alternative, it isn't the
    hardest material to shape.
    cheers,
    Pete.
    Pete C, Feb 18, 2004
    #18
  19. IMM
    Guest
    > >> gets drier.
    > the MHDS:
    > it reads:
    Er, um, I think you'll find that metals are most definitely mineral,
    they certainly aren't animal or vegetable.
    Chris Green
    , Feb 18, 2004
    #19
  20. IMM
    stuart noble Guest
    And this from a man who owns a house in Balham. I thought you lot were all
    millionaires :)
    stuart noble, Feb 18, 2004
    #20
  1. Kyle Boatright
    Re: exterior wood filler
    Kyle Boatright, Feb 26, 2006, in forum: Home Repair
    2,096
    BobK207
    Feb 26, 2006
  2. Robert11
    Wood Filler For Exterior Wood Patching ?
    Robert11, Mar 4, 2007, in forum: Home Repair
    861
    C & E
    Mar 4, 2007
  3. abby
    540
    John Grabowski
    Jul 26, 2008
  4. Existential Angst
    Epoxy repair/filler for exterior wood.
    Existential Angst, Aug 9, 2011, in forum: Home Repair
    1,129
    Existential Angst
    Aug 14, 2011
  5. George
    exterior wood filler?
    George, Aug 26, 2012, in forum: Home Repair
    439
    George
    Aug 30, 2012
