Electricity Meter flashing light
Discussion in 'Misc DIY' started by lemmy, Jun 17, 2007.
  1. lemmy
    lemmy Guest
    I've just moved house and notice that the Siemans electricity meter
    has a red light wich is flashing slowly. Plus the LCD display is
    flashing between 8888 and the current reading. Does anyone know what
    this signifies?
    lemmy, Jun 17, 2007
  2. Colin Wilson
    Colin Wilson Guest
    > this signifies?
    The flashing red light indicates usage, and somewhere on the meter
    will probably be a reference to xxxx flashes per kWh
    The 8888 is simply a test pattern to prove the meter has all the
    display segments working correctly.
    Colin Wilson, Jun 17, 2007
    The light flashes once for each 1W/hr consumed (ie 1000 flashes per kW/hr)
    > Plus the LCD display is flashing between 8888 and the current reading.
    Shows that all the segments of the display are working and thus the
    numbers shown are correct. No confusion between say 8 and 0, or 7 and 1
    etc.
    Cheers
    Dave. pam is missing e-mail
    Dave Liquorice, Jun 17, 2007
  4. Part timer
    Part timer Guest
    > this signifies?
    On one of those Sky Three "law-and-order" type programmes 2 cops were
    hunting down a dodgy white van (permanantly borrowed from a rental
    fleet). Terraced houses, lots of cars parked, they had a look into the
    van and a cutain twitched in a nearby house. "Ello ello ello!" - they
    knock on the door. No answer. Looked through letterbox - smell of hash
    plantation! The two young lads leg it out of the back and are caught.
    One cop noticed the electricity meter was giving it all the 8s,
    flashing between the current reading - and he said it had been
    tampered with (obvious as the tails were linked to the incomers in a
    very dodgy way).
    Get it looked at!
    Part timer, Jun 17, 2007
    >> this signifies?
    >very dodgy way).
    Hmmm which is the most likely :
    a) Test pattern to show that the display is correct.
    b) Copper that knows anything about electronic electricity meters.
    Mike Harrison, Jun 17, 2007
  6. The Wanderer
    The Wanderer Guest
    No, I don't think so. See the reply from Colin Wilson.
    the dot wanderer at tesco dot net
    The Wanderer, Jun 18, 2007
  7. The Wanderer
    The Wanderer Guest
    On Mon, 18 Jun 2007 08:46:25 +0100, David Hansen wrote:
    > On Mon, 18 Jun 2007 07:43:47 +0100 someone who may be The Wanderer
    > <> wrote this:-
    > You mean the one where he typed, "The flashing red light indicates
    > usage, and somewhere on the meter will probably be a reference to
    > xxxx flashes per kWh"?
    > While it may or may not be 1000 flashes per unit, the light flashing
    > certainly does indicate usage.
    Err, yes, and my reference to CW's answer made it quite clear that I wasn't
    disputing that the light flashes to indicate usage.
    What I was disputing was the statement that the light flashes once for
    every watthour. It is an erroneous statement that might mislead others. Or
    are you suggesting that we should collectively turn a blind eye to
    misinformation?
  8. AJH
    AJH Guest
    <> wrote:
    >the light flashing
    Has anybody made a counter that sees the flashes and data logs them
    off a usb port? Must be better than the clamp on things that are being
    shown on the news.
    AJH
    AJH, Jun 18, 2007
  9. Alex
    Alex Guest
    > shown on the news.
    http://offog.org/code/electricity.html
    Alex
    Alex, Jun 18, 2007
  10. lemmy
    lemmy Guest
    So everything's ok. Thanks very much for all the info.
    lemmy, Jun 18, 2007
  11. The Wanderer
    The Wanderer Guest
    On Mon, 18 Jun 2007 11:59:04 +0100, David Hansen wrote:
    > On Mon, 18 Jun 2007 10:49:22 +0100 someone who may be The Wanderer
    > <> wrote this:-
    >>every watthour.
    > The meter in the office is labelled "1000 imp/kWh". I assume that
    > "imp" stands for impulses, AKA flashes.
    And the one here at home is labelled 800 imp/kwh. Which proves my point
    that the earlier statement that the meter flashes once for every watthour
    consumed is misleading. It *may* do, but other calibrations exist.
    #11
  12. AJH
    AJH Guest
    >> shown on the news.
    Thanks but that seems to need an understanding of Linux, I do have a
    Linux box I could leave running but....
    AJH
    AJH, Jun 18, 2007
    #12
  13. nickt
    nickt Guest
    > > shown on the news.
    > Alex
    www.calc-electric.com (£5, uses a webcam)
    nickt, Jul 21, 2007
    #13
  14. Lurch
    Lurch Guest
    Re: Re: Electricity Meter flashing light
    On Sat, 21 Jul 2007 03:46:39 -0700, nickt <>
    mused:
    >> > shown on the news.
    >> Alex
    Spamming ****.
    Regards,
    Stuart.
    Lurch, Jul 21, 2007
    #14
  15. Keith
    Keith Guest
    In message <>,
    nickt <> writes
    >> > shown on the news.
    >> Alex
    Which requires a computer on 24/7 to tell you how much you're wasting by
    leaving things switched on 24/7.
    Keith
    Keith, Jul 21, 2007
    #15
  16. Bob Eager
    Bob Eager Guest
    On Sat, 21 Jul 2007 13:23:30 UTC, Keith <>
    wrote:
    > In message <>,
    > nickt <> writes
    > >> > shown on the news.
    > >www.calc-electric.com (ú5, uses a webcam)
    Not a problem..I have several computers on 24/7...!
    The information contained in this post is copyright the
    poster, and specifically may not be published in, or used by
    http://www.diybanter.com
    Bob Eager, Jul 21, 2007
    #16
  1. Stanley Spanner
    Water pipe OK near electricity meter?
    Stanley Spanner, Feb 17, 2004, in forum: Misc DIY
    449
    Kalico
    Feb 17, 2004
  2. Sparks
    Electricity Meter rating
    Sparks, Sep 27, 2004, in forum: Misc DIY
    9
    701
    Sparks
    Sep 28, 2004
  3. The 1st Philosophical Handyman of the Humber
    Digital electricity meter - red light on constantly!
    The 1st Philosophical Handyman of the Humber, Oct 29, 2006, in forum: Misc DIY
    4,704
    Oct 30, 2006
  4. Jay Spenchian
    603
    Mike Sheehan
    Aug 22, 2003
  5. New Question
    865
    Beachcomber
    Nov 24, 2004
