Dyson DC07 overheating question
Discussion in 'UK DIY' started by PHG, Dec 15, 2004.
  1. PHG
    PHG Guest
    Apologies for yet another Dyson query. The most relevant previous postings
    appear to have been pruned from the server.
    I thought I had fixed this by cleaning the pre-motor filter, but the cut-out
    has started again after 10 mins use. Certainly the area around the motor and
    base of the bin is very warm after 10 minutes use. Curiously the brush-bar
    still rotates at speed. I am not convinced the suction is as good as it was
    when new.
    1. Is there a Dyson self-help website that may be able to help me here ? Of
    course I could take this to a repair shop but I'd prefer to investigate
    myself first.
    2. Is there a maintenence/repair doc available for DC07 models ?
    Any thoughts on possible culprits here would be appreciated. Thanks Paul
    PHG, Dec 15, 2004
  2. PHG
    Dave Guest
    Hi Paul
    cut-out
    Don't know the Dyson inside out, but been in industrial vacuums for 25
    years!
    I would guess that your Dyson has a directly cooled motor, that is the
    air being moved to provide the suction also provides the cooling for
    the motor. Any blockage or restriction downstream of the motor will
    cause overheating.
    Any blockage or restriction upstream will affect the downstream and do
    the same, so look very carefully at filters, bends, hose joiners etc
    both in and out. Also check the fan blade it'self. If it's cracked or
    damaged it won't be moving enough air to cool the motor.
    brush-bar
    it was
    > when new.
    Again guessing, is the brush bar driven by the same motor as the fan?
    If so, the motor is having to work harder, sounds like a damaged fan
    blade.
    Overloads are a warning. They weaken every time they trip.
    Dave
    Dave, Dec 15, 2004
  3. In article <cpp27c$eh7$>,
    "PHG" <> writes:
    > when new.
    It sounds like there's a blockage in the airway somewhere.
    Have you checked inside all the removable bits of pipework?
    Andrew Gabriel
    Andrew Gabriel, Dec 15, 2004
  4. PHG
    PHG Guest
    "Andrew Gabriel" <> wrote in message
    news:cppg6p$k4k$...
    > "PHG" <> writes:
    postings
    cut-out
    and
    brush-bar
    was
    > > when new.
    > Andrew Gabriel
    Thanks for your suggestions. I've just removed the removable pipework but
    there
    doesn't appear to be a blockage. It appears that after just a couple of
    minutes,
    the area where the motor housing meets the bin gets hot and hot air is being
    emitted, which is why it is cutting out.
    Could there be dust inside the motor housing ? Does anyone have some
    disassembly instructions ?
    PHG, Dec 15, 2004
  1. John
    Dyson DC07
    John, Dec 6, 2003, in forum: UK DIY
    32
    1,529
  2. Clive Long,UK
    New Dyson DC07 "extension tube" very stuck
    Clive Long,UK, Dec 15, 2003, in forum: UK DIY
    2,100
    ktkdwt
    Sep 24, 2011
  3. Murdo
    937
    Murdo
    Oct 20, 2004
  4. John
    341
    Colin Wilson
    Oct 15, 2007
  5. Mucker
    Dyson DC07
    Mucker, Sep 29, 2003, in forum: UK Home Improvement
    377
    Mucker
    Sep 29, 2003
