Driving over septic system
Discussion in 'Home Repair' started by Steve, Jul 23, 2006.
  1. Steve
    Steve Guest
    I need to take down a large tree in my backyard where the only way to
    do it is either through a climber (very expensive) or by bucket truck
    (much cheaper and I liked the owner). $2,000 vs $600
    The main issue is that there is no way to avoid crossing the septic
    system. Mine is about 45 years old.
    I once heard you can't drive over any part of the septic system. What
    he plans to do it to use ground protection mats to create a path to
    the tree. He says it is not good to drive directly over the tanks,
    but it would be fine to go over the pipes using these mats. In
    particular this would be the pipe between the house and the tank (not
    the leach fields). I estimate the pipe is buried only about a foot
    and a half. He says that because of the round shape it can take a
    great deal of pressure without breaking.
    This is a site with mats like he is describing:
    http://www.alturnamats.com/
    Does this sound ok and safe to do or should I go the more expensive
    route and get a climber?
    Thanks,
    Steve
    Steve, Jul 23, 2006
  2. Steve
    Lawrence Guest
    Why do you ask that your post not be archived?
    Lawrence, Jul 23, 2006
  3. Steve
    chuckster Guest
    Don't Feed the TROLLS!!
    chuckster, Jul 23, 2006
  4. Steve
    dpb Guest
    Steve wrote:
    > Hi,
    No problem as long as he doesn't put the truck _in_ the tank--the lids
    are not designed to support that kind of load. I wouldn't worry too
    much about the drain field for a (relatively) light truck, either, for
    a field that has been in place that long as long as you don't do it
    during a period of wet weather. That's not to recommend driving around
    all over it, but a single track in and out during dry weather w/ a
    truck that won't be more than say 5-6000 lb isn't likely to be a major
    problem. If he were to start cutting obvious ruts in the area when he
    started in, that would be a bad thing (TM) :), but w/ the load
    distribution mats I wouldn't worry much at all...
    dpb, Jul 23, 2006
  5. Steve
    Bob Guest
    I used the 10" round black plastic pipe (very similar to septic pipe)
    as drain pipe under my drive. It's buried about 16" deep. Then I had
    loggers cut 20 acres of pine on the back of my property. They drove 18
    wheelers loaded with logs across the drain pipe in the drive and never
    damaged it. So yea, that round pipe can take a lot of pressure.
    Bob
    Bob, Jul 23, 2006
  6. Steve
    Guest
    get a estimate on a new septic system then decide if the savings are
    worth the risk.
    , Jul 23, 2006
  7. Steve
    Tom G Guest
    "Steve" <> wrote in message
    > Hi,
    > Thanks,
    > Steve
    My leach field is on the other side of my driveway from the house. About
    thirty years of all kinds of trucks, including garbage trucks driving across
    the pipe from the tank to the field (gravel driveway) hasn't hurt it.
    Tom G.
    Tom G, Jul 23, 2006
  8. Steve
    Guest
    OPs system is 45 years old thats before PVC pipe:(
    terracota pipe cracks easily under load
    , Jul 23, 2006
  9. Steve
    EXT Guest
    If this is the single line from the house to the septic tank and it is only
    18 inches deep it is worth a little investigating. In an area that the truck
    will NOT drive over, dig down to the pipe. Be careful because 45 years ago a
    lot of clay pipe was in use and it will be brittle. If the pipe is cast
    iron, you should take care because stress can crack it and the 5 foot
    lengths will add to its fragilness. If it is vitrified clay (glazed clay) it
    can shatter under the load, do not let him drive over it unless you are
    prepared to replace it. If the pipe is black fiber "No-Co-Rode" pipe, it
    probably will hold up as it has a little bit of play. If the pipe is black
    polyethylene, you will have no trouble. I cannot think of any other types of
    pipe in use 45 years ago. If the best intentions fail, and whatever pipe you
    have fails, you should be able to easily replace it with modern 4" PVC sewer
    and drain pipe.
    > Hi,
    > Thanks,
    > Steve
    EXT, Jul 23, 2006
  10. Steve
    Pop Guest
    In news:,
    Steve <> typed:
    > Hi,
    > system. What
    > path to
    > tanks,
    > tank (not
    > foot
    > take a
    How do you figure a foot and a half? Is your tank sticking up
    out of the ground or something?
    IME, it's OK to do. Did you ask him what he'll do if he does
    crush it? You might like the answer. If not, ask a couple other
    contractors and compare answers. Many know what they're doing, a
    few don't of course, but that's part of what they're being paid
    for.
    It shouldn't be a problem, really.
    > expensive
    If you're the grudge type, get the climber out there.
    Pop
    > Thanks,
    > Steve
    Pop, Jul 23, 2006
  1. John
    672
    Randy Anderson
    Apr 14, 2004
  2. raymondj
    smell from septic system
    raymondj, May 18, 2004, in forum: Home Repair
    265
    Eric Tonks
    May 18, 2004
  3. weeG
    water over septic tank
    weeG, Jun 3, 2004, in forum: Home Repair
    9
    356
    Rob Reali
    Jun 27, 2004
  4. Pop Rivet
    Grass over septic
    Pop Rivet, Jul 25, 2004, in forum: Home Repair
    268
    Pop Rivet
    Jul 25, 2004
  5. John Gilmer
    Small pool over septic tank?
    John Gilmer, Jun 25, 2007, in forum: Home Repair
    10
    391
    Eigenvector
    Jun 26, 2007
