Drill a hole in a porcelain sink?
Discussion in 'Misc DIY' started by Ike, Jun 11, 2004.
  1. Ike
    Ike Guest
    We just purchased a new kitchen faucet set with a soap dispenser. The
    problem is there isn't a hole in the sink to mount the soap dispenser.
    There is another hole but it has the dishwasher and garbage disposal
    vent mounted in it.
    How does a person add a hole to the sink without chipping out a huge
    hunk of porcelain? It seems like it would be too tough of a job for a
    hole saw.
    Ike, Jun 11, 2004
  2. Ike
    Rudy Guest
    I watched a friend do it with a holesaw. He ended up standing IN the sink
    for leverage while he drilled. Once the saw cleared the porcelain, the
    drilling thru the soft cast iron was easier than I'd have thought.
    > vent mounted in it.
    BTW, they dont vent DW/disposals with the typical Air Gap gizmo around here.
    Dont know why but I never liked them anyway.
    Rudy, Jun 11, 2004
  3. Ike
    Speedy Jim Guest
    > > vent mounted in it.
    > R
    Just to add- there is a special carbide-tipped hole saw
    available for drilling ceramic tiles (even HD has them);
    should work on the porcelain too.
    Some cities mandate an air gap for sanitary reasons;
    if that's the case where OP is, he'll have to retain it.
    Jim
    Speedy Jim, Jun 11, 2004
  4. Ike
    John Willis Guest
    On Thu, 10 Jun 2004 17:11:00 -0700, Ike <>
    scribbled this interesting note:
    >vent mounted in it.
    >hole saw.
    On some kitchen faucets, the single lever kind, you can mount them
    without using the baseplate. This allows you to use the other two
    (former) mounting holes. One would be for a sprayer and one would be
    for the soap dispenser.
    Buying the right faucet would eliminate the need for drilling into
    your sink. Perhaps you could return the one you already have?
    John Willis
    (Remove the Primes before e-mailing me)
    John Willis, Jun 11, 2004
  5. Ike
    Kenneth Guest
    On Thu, 10 Jun 2004 17:11:00 -0700, Ike wrote
    (in message <>):
    > vent mounted in it.
    > hole saw.
    I successfully drilled my porcelain kitchen sink for a water filter
    dispenser. To make the 1/4" guide hole for the hole saw, I used a glass bit
    to start, then a carbide masonry bit, then a high speed steel bit to go
    through the cast iron. All were lubricated with cutting oil. I then used a
    1-1/4" carbide abrasive hole saw to make the larger hole, also lubricated
    with cutting oil. I recall using fairly heavy pressure and a slow cutting
    speed to avoid heating the work. It took quite a while, but worked fine.
    Kenneth, Jun 11, 2004
  6. Ike
    Ike Guest
    On Fri, 11 Jun 2004 01:49:59 GMT Kenneth <>
    >(in message <>):
    >> vent mounted in it.
    >> hole saw.
    I failed to mention that our sink is a porcelain clad steel sink that
    is five years old. From what I've been able to glean off the Internet,
    these sinks are the toughest to drill a hole through. They chip very
    easily. Stainless are the easiest, cast iron second and clad steel the
    hardest to do.
    The wife is the one who wanted this particular faucet knowing full
    well that we may not be able to mount the soap dispenser. She's
    willing to compromise on the dispenser knowing that there is a good
    chance I could ruin the sink. It's not worth throwing away a five year
    old perfectly good sink and buying a new one with five holes.
    Thanks for the suggestions guys, but I think the wise thing to do is
    take a pass one this one.
    Ike, Jun 11, 2004
  7. Ike
    Doug Kanter Guest
    "Ike" <> wrote in message
    > >(in message <>):
    > >> vent mounted in it.
    > >> hole saw.
    bit
    used a
    cutting
    > hardest to do.
    Maybe you can test this idea on various scrap materials: If you use cutting
    oil and run a hole saw backwards briefly, you should be able to etch the
    porcelain surface so as to not crack it when you reverse direction to do the
    actual cutting. This isn't much different than the way you'd make a ring on
    both sides of a door with the hole saw when installing a lock set, so you
    don't chip the wood when the saw comes out the other side. I
    know....porcelain's not fibrous like wood, but intuitively, I think this
    idea's worth some thought.
    Doug Kanter, Jun 11, 2004
  8. Ike
    Guest
    Doug
    I had a problem like that and I took the sink to a glass company and they
    were able to drill a perfect hole with no problem at all.
    Good Luck
    -------------------- http://NewsReader.Com/ --------------------
    Usenet Newsgroup Service $9.95/Month 30GB
    , Jun 11, 2004
  9. Ike
    ameijers Guest
    > >(in message <>):
    > >> vent mounted in it.
    ????? Please elucidate. Since when is there a vent to room air for the
    D/W/Disposal? Doesn't the drain hole in the sink take care of any needed
    venting? I grew up in residential construction in the midwest, and I have
    NEVER seen anything other than knobs, spouts, squirters, and dispensers
    visibly mounted on back edge of sink. Not doubting your word, I'm genuinely
    curious. Can you post a jpeg somewhere and list the link here?
    Maybe you could reroute the vent elsewhere, or put the soap dispenser
    through counter next to sink?
    aem sends...
    ameijers, Jun 13, 2004
  10. Ike
    Ike Guest
    On Sun, 13 Jun 2004 02:17:14 GMT "ameijers"
    >news:...
    >> >(in message <>):
    >> >> vent mounted in it.
    I'm not a plumber so I have no idea what purpose it serves. The wife
    says soap bubbles come up through it when the dishwasher is emptying
    and she drains the sink of dishwater at the same time. We live in
    Vegas and all new construction has the vent on the sink. I think if I
    tried mounting it under the sink I could end up with a real mess at
    some point.
    Ike, Jun 13, 2004
  1. Markus J
    339
    Markus J
    Aug 26, 2003
  2. pray4surf
    1-Hole, 3-Hole, or 4-Hole - Pros and Cons
    pray4surf, Sep 21, 2004, in forum: Home Repair
    8
    637
  3. Butzmark
    Drilling a hole in a porcelain sink
    Butzmark, Sep 6, 2006, in forum: Misc DIY
    581
    sosessyithurts
    Sep 7, 2006
  4. grinder
    Drill Hole in Kitchen Sink ?
    grinder, Oct 22, 2006, in forum: Misc DIY
    391
    Paul Franklin
    Oct 22, 2006
  5. MM
    896
