Difference between single-pole and double-pole socket
Discussion in 'UK DIY' started by Alec, Feb 19, 2004.
  1. Alec
    Alec Guest
    What are the differences between them? How can I tell the difference by
    looking at them? For normal domestic installation. can I use either
    (single-pole being cheaper)?
    TIA
    Alec, Feb 19, 2004
  2. Lurch
    Lurch Guest
    On Thu, 19 Feb 2004 18:51:00 -0000, "Alec"
    >TIA
    Poles referring to switching of live only or live and neutral.
    Look for the words 'double pole' on the socket.
    I would recommend using double pole, although single pole will be
    fine.
    SJW
    A.C.S. Ltd.
    Lurch, Feb 19, 2004
  3. G&M
    G&M Guest
    "Lurch" <> wrote in message
    > >TIA
    > fine.
    Double pole is compulsory for certain applications - bathroom cutoffs, hot
    water tank heaters, central heating controls (I believe - can't see why) and
    a few others.
    G&M, Feb 19, 2004
  4. Lurch
    Lurch Guest
    >a few others.
    Switches yes, sockets no.
    SJW
    A.C.S. Ltd.
    Lurch, Feb 19, 2004
  5. Dave Plowman
    Dave Plowman Guest
    In article <c13c1l$9qr$>,
    > hot water tank heaters, central heating controls (I believe - can't see
    > why) and a few others.
    Those, surely, are hard wired so you're talking about an isolator switch.
    With something that's plugged in you isolate it by unplugging it.
    *Honk if you love peace and quiet.
    Dave Plowman London SW 12
    RIP Acorn
    Dave Plowman, Feb 20, 2004
  6. Guest
    > >a few others.
    ???? What's a single pole socket?
    Chris Green
    , Feb 20, 2004
  7. Lurch
    Lurch Guest
    >> >a few others.
    A socket with single pole switching.
    SJW
    A.C.S. Ltd.
    Lurch, Feb 20, 2004
  8. BillV
    BillV Guest
    > It refers to the switch built into the socket. Most sockets you buy
    > now have double pole switching that switch the neutral as well as the
    > live. They are only a few more pence, so you might as well buy them.
    > You'll increasingly find they come with two earth terminals, too.
    > When wiring these up on a ring, you should put one earth wire into
    > one terminal and the other into the other.
    Just fitted some MK Logic ones I got in TLC and I expected to see these two
    earth terminals .... but they didn't have them.
    BillV, Feb 20, 2004
  9. Owain
    Owain Guest
    "Dave Plowman" wrote
    | > cutoffs, hot water tank heaters, central heating controls
    | > (I believe - can't see why) and a few others.
    | switch. With something that's plugged in you isolate it by
    | unplugging it.
    The objection to a SP-switched socket in these circs is that someone
    switches off at the socket without unplugging, thinks it's isolated, then
    Bang! Ouch! Yarrooo! finds it isn't.
    But I agree they should all be hardwired.
    Owain
    Owain, Feb 20, 2004
  10. Dave Plowman
    Dave Plowman Guest
    In article <>,
    If someone isn't capable of keeping line and neutral wired correctly,
    would you trust them not to have the earth wired through one of the two
    poles on an isolating switch? ;-)
    *I wish the buck stopped here. I could use a few.
    RIP Acorn
  1. East Coast
    749
  2. Dave
    532
  3. Replies:
    13
    407
    Chris Lewis
    Sep 11, 2006
  4. capediver
    double pole single throw switches
    capediver, Nov 10, 2010, in forum: Home Repair
    517
    Stormin Mormon
    Nov 11, 2010
  5. misterroy
    16
    763
