Dehumidifier where fan is NOT always on - Is there such a thing?
Discussion in 'Home Repair' started by Paul, Aug 14, 2006.
  1. Paul
    Paul Guest
    Hi All,
    I just purchased a Danby dehumidifier from Costco & have the following
    beefs;
    - the fan is always on. Customer Service tried to tell me that it's
    actually more energy efficient to run the fan constanly - an argument I
    find somewhat demeaning.
    - even the the humdity is lower then the set-humidity, the compressor
    kicks in periodically.
    I'd REALLY prefer a dehumidifier that "shuts down" when the desired
    humdity level has been reached - can anyone advise if there is such a
    product out there?
    I just replace all the light bulbs in the house with compact floresent
    sp? - I a little miffed that this dehumidifier will now such as much
    power out of the grid as I'd though I was saving.
    Thanks!
    Paul, Aug 14, 2006
  2. Paul
    Paul Guest
    My preference is to let the normal diffusion of humidity handle this,
    not the fan.
    I don't believe that the corner of the bathroom with the dehumidifier
    would be dry while the opposite corner is saturated. A dehumidifier
    with "fan-auto-shutoff" might turn on & off a little more often, but I
    choose the energy savings that come with having the fan & compressor
    always off in the majority of time when the desired humidity has been
    reached.
    Joseph Meehan wrote:
    > Paul wrote:
    > > Hi All,
    > > beefs;
    > > I find somewhat demeaning.
    > > product out there?
    > > Thanks!
    > I think the problem in part is they are using the fan to circulate the
    > air and to get the more moist air past the humidity sensor. If you don't
    > move the air the dehumidifier would not be very responsive.
    > Joseph Meehan
    > Dia duit
    Paul, Aug 14, 2006
  3. "Paul" <> wrote in message
    > not the fan.
    > reached.
    Given the location of the sensor, it is very possible to have a large
    variation in humidity. If there is enough of a draft or air movement, you
    are somewhat correct. In a closed bathroom, there is going to be little
    current to trigger the sensor, thus greater swings in humidity. Tolerable?
    Maybe, but since you are so much in the minority the makers won't be taking
    the added cost of that type of unit into consideration.
    Edwin Pawlowski, Aug 14, 2006
  4. Bob
    Bob Guest
    "Edwin Pawlowski" <> wrote in message
    news:%G4Eg.1596$117.371@trndny09...
    > news:...
    > > not the fan.
    > > reached.
    This is just a guess, but my thought is that the moisture on the heat exchanger
    and the output bucket would cause the unit to cycle back on too
    frequently if the fan turns off when the compressor does.
    Bob
    Bob, Aug 14, 2006
  5. mm
    mm Guest
    On 14 Aug 2006 11:16:39 -0700, "Paul" <> wrote:
    >Hi All,
    >beefs;
    Silly maybe, I don't know for sure, but demeaning? Don't take these
    things personally.
    >product out there?
    I'll bet it isn't too hard to rewire this one (although I suppose that
    voids the warranty.)
    I had a room ac where the fan ran all the time, all night even it
    cooled down during the night, and it was right next to my bed, to
    boot.
    All the wires inside had slide on connectors, so I just rearranged 3
    of them. (two wires won't be enough, but iirc, you only have to take
    off one end of each wire. In this case it took about 15 minutes. Of
    course I had the whole thing in my head when I started, and I'm not
    sure if you do or not.) I made it so the thermostat (in your case
    the humidistat) controlled the power to the compressor and the fan,
    instead of the fan current not going through the thermost. Make a
    sketch of the way it was so you don't get lost, and so if you do need
    service, and you probably won't, you can put it back the way it was
    before you bring it back. Use a quality phillips head screwdriver so
    you won't leave traces that you've been inside. (How else do they
    know?)
    Why the comprssor kicks in when it is not humid, I don't know. Before
    you do the above, call them and make sure it is meant to do that.
    Maybe yours is broken (although I don't think it would be able to do
    that if they didn't provide a part to make it happenn.)
    >Thanks!
    mm, Aug 15, 2006
  6. DT
    DT Guest
    In article <>,
    says...
    >Hi All,
    >beefs;
    I have never had one that operates with the fan always on. I currently have a
    Goldstar and a GE and they both shut off the fan. They come back on for a brief
    period every so often to sample the air and and see if the compressor needs to
    run.
    Dennis
    DT, Aug 15, 2006
  7. Paul
    Paul Guest
    Thanks all - hadn't considered rewiring, but I am somewhat of a tinkerer.
    Thanks to everyone for the intelligent responses. I think this internet
    thing is gonna be a hit.
    Hmm...hadn't considered opening up the hood & doing some rewiring, but
    I am somewhat of a tinkerer. I promise to post the result if I try it.
    Based on responses it seems like I will NOT find a new dehumidifier
    that turns the fan off when it's "resting", although geez, didn't the
    old ones work this way?
    The dehumidifier itself is currently in a small bathroom in my
    basement, there is frequent traffic but no other circulation other then
    the exhaust fan. Have already tried running exhaust fan constantly, but
    that does not do the job.
    My primary concern is energy consumption, although the dehumidifier
    running constantly in the small bathroom is a mild annoyance to my
    renter, and I really like to keep her happy.
    I could put the dehumidifier in the furnace room (beside the bathroom)
    - although I think to make the bathroom dry, it would mean "venting"
    the bathroom to the furnace room somehow.
    Does anyone know a good place to get energy consumption stats - I just
    replaced nearly all my light bulbs with compact fluorescent. I'm not
    really trying to save money, just to minimize my energy consumption.
    (save the planet, not the money ;o)
    > >Hi All,
    > >beefs;
    > things personally.
    > >product out there?
    > boot.
    > know?)
    > >Thanks!
    Paul, Aug 15, 2006
  8. Paul
    Paul Guest
    very interesting thank you - I will check this out. Home Depot, here I
    come.
    DT wrote:
    > In article <>,
    > says...
    > >Hi All,
    > >beefs;
    > run.
    > Dennis
    Paul, Aug 15, 2006
  9. "Paul" <> wrote in message
    > Hi All,
    > beefs;
    I'd bet that no matter how many facts they give you, nothing would change
    your mind. Yes, under many circumstances they are correct.
    Edwin Pawlowski, Aug 15, 2006
  10. DT
    DT Guest
    In article <>,
    says...
    >come.
    Not sure what the Depot carries, but I know I got the Goldstar at Walmart. By
    the way, the Goldstar has superb accuracy, keeps the humidity within a few
    percentage points, is continuously adjustable and is very easy to get the water
    container back in. The digital GE goes up 5% at a time, although it works well
    also. The GE water bucket is a pain, it is in back and takes 3 or 4 tries to
    get it properly hung so the 'full' switch doesn't trip. Both have real hose
    connections directly to the water container if you want to leave them hooked
    up. From another dehumidifier thread a few weeks ago, some units just have a
    goofy way to hang the end of the hose under the water spout.
    Dennis
    DT, Aug 15, 2006
  11. mm
    mm Guest
    Re: Thanks all - hadn't considered rewiring, but I am somewhat of a tinkerer.
    I don't know. About either question.
    Interestingly enough, they now make room ACs the way I made mine with
    a swtich to make the fan always on or on auto. Strangely, they call
    this the power saver, when I would call it the noise saver.
    mm, Aug 15, 2006
    #11
  12. Mike S.
    Mike S. Guest
    In article <>,
    DT <> wrote:
    >In article <>,
    > says...
    >>Hi All,
    >>beefs;
    >run.
    Ditto the LG and Sears/Kenmore models (which are manufactured by LG).
    Mike S., Aug 15, 2006
    #12
  13. Guest
    Yes. You might add an external humidistat like this one
    ($32, with a 4.4A contact rating):
    http://www.grainger.com/Grainger/wwg/itemDetailsRender.shtml?ItemId=1611632220
    Nick
    , Aug 17, 2006
    #13
  1. Alex
    699
    stuart noble
    Sep 9, 2003
  2. TheScullster
    571
    Lobster
    Apr 27, 2004
  3. mrcheerful
    470
    James Salisbury
    Aug 19, 2004
  4. Sean
    2,113
    Peter D
    Oct 13, 2004
  5. Otter
    405
    Otter
    Jul 14, 2003
