Cutting Perspex?
Discussion in 'UK DIY' started by Bob Eager, Sep 6, 2003.
  1. Bob Eager
    Bob Eager Guest
    This may seem a simple question...but I've never done it...
    I have some Perspex - about 3mm thick - which I need to cut into several
    pieces. It's rectangular and all the pieces will also be rectangular.
    What's the best way? Saw? Knife? Score and snap? Never worked with the
    stuff before....
    Bob Eager
    rde at tavi.co.uk
    PC Server 325*4; PS/2s 9585, 8595, 9595*2, 8580*3,
    P70...
  2. Bob Eager
    DKSanders Guest
    Treat it like glass i.e. score carefully and firmly, once, using a straight
    edge along the desired cut.
    Place on a flat surface with something straight and about 3-5mm high, under
    the score.
    Whilst holding the perspex one one side so it doesn't move, apply firm
    downward pressure to the other side.
    It should snap along the score line.
    I have had to do this many times and with long pieces (e.g. more than 1m
    cuts, you carefully 'walk' the snap up the score.
    Best of luck.
    "Bob Eager" <> wrote in message
    > stuff before....
    > Bob Eager
    > rde at tavi.co.uk
    > P70...
    DKSanders, Sep 6, 2003
  3. Bob Eager
    Dave Plowman Guest
    In article <>,
    > stuff before....
    I usually saw it, although I think you can score and snap. It's a super
    material to work with - just be careful not to melt it with friction when
    drilling or cutting. You can, in general, treat it like metal as far as
    machineing operations are concerned.
    If you need to polish the edges, treat it like cellulose paint on a car -
    sand with wet or dry used wet and then polish with Brasso.
    Chloroform is an excellent solvent.
    *If God dropped acid, would he see people?
    Dave Plowman London SW 12
    RIP Acorn
    Dave Plowman, Sep 6, 2003
  4. Bob Eager
    Chris Oates Guest
    "DKSanders" <> wrote in message
    news:bjb8l4$b4n$...
    straight
    under
    > the score.
    you can also cut it with a fine jigsaw if you go slowly (or it will melt)
    polycarbonate is much easier to work with & won't shatter
    Chris Oates, Sep 6, 2003
  5. Bob Eager
    BigWallop Guest
    > stuff before....
    > Bob Eager
    > rde at tavi.co.uk
    > P70...
    Have a look down this page : http://www.sdplastics.com/polycast.html for
    some expert advice.
    BigWallop, Sep 6, 2003
  6. Bob Eager
    BigWallop Guest
    > stuff before....
    > Bob Eager
    > rde at tavi.co.uk
    > P70...
    Actually, here's a clearer version ::
    http://www.aquariacentral.com/diy/acrylic.shtml
  7. Bob Eager
    Grunff Guest
    Which is not very easy to get hold of these days.
    Grunff
    Grunff, Sep 6, 2003
  8. Bob Eager
    Bob Eager Guest
    On Sat, 6 Sep 2003 00:25:55 UTC, Dave Plowman <>
    Thanks, everyone. Excellent! It was (inter alia) the melting while
    sawing I was worried about.
    Bob Eager
    rde at tavi.co.uk
    P70...
  1. Dean Heighington
    Perspex Mirror supplier?
    Dean Heighington, Jul 30, 2003, in forum: UK DIY
    793
    Stephen Gower
    Aug 4, 2003
  2. Ben C
    Bending perspex/plastic
    Ben C, Aug 9, 2003, in forum: UK DIY
    2,587
    Paul Hewish
    Aug 11, 2003
  3. dee
    paint thinner + perspex
    dee, Feb 2, 2004, in forum: Misc DIY
    1,165
    Grunff
    Feb 4, 2004
  4. Ex Alfa Adam
    8
    2,233
    Badger
    Nov 1, 2004
  5. rjs
    Cutting Perspex
    rjs, Aug 6, 2005, in forum: UK DIY
    12
    790
    weekendwarrior
    Jul 3, 2006
