Cutting Holes In Plaster Walls
Discussion in 'Misc DIY' started by George, Dec 8, 2003.
  1. George
    George Guest
    Just bought a new house with the lathing and plaster walls. I'm pretty sure
    there's chicken wire back there too. My question is, whats the best way to
    cut a hole for a new electrical receptacle in this type of wall without
    doing to much damage to wall surrounding the new hole?
    Thanks in advance!
    George
    George, Dec 8, 2003
  2. George
    SQLit Guest
    "George" <> wrote in message
    news:Fz1Bb.408$...
    sure
    to
    > Thanks in advance!
    > George
    Drill around the area with a 1/4 inch bit then you can use a hacksaw, holes
    almost touching, or my favorite is my Dremel with the rotary bit on it.
    Zips right through almost everything.
    SQLit, Dec 8, 2003
  3. George
    New Question Guest
    news:Fz1Bb.408$...
    sure
    to
    > Thanks in advance!
    > George
    RotoZip is the superior solution. Lowes, Home Depot, Sears, etc.
    New Question, Dec 8, 2003
  4. George
    Bob Guest
    news:Fz1Bb.408$...
    sure
    to
    > Thanks in advance!
    > George
    Put the outlet next to a stud and make your first cut farthest away from the
    stud. Obviously your last cut will be the one that butts with the stud. I
    drill out the four corners and use a jigsaw.
    If you make your cuts the opposite way you run the risk of wrecking your
    wall as the lathe will shake in the wall. Mud and a large cover will fix it.
    Bob, Dec 9, 2003
  5. "George" <> wrote in message news:<Fz1Bb.408$>...
    > Thanks in advance!
    > George
    I recently did a lot of this in my own 1895 house. Used a 4.5 inch
    grinder with a diamond blade on it. No teeth to get things vibrating
    and it went through the (wood) lathe and plaster like butter. If you
    do have chicken wire or some other type of wire mesh I'm not sure how
    well it would work. I would go with the Robo Zip. Actually, I recently
    bought the Craftsman equivalent of the Robo Zip for about half the
    cost. It is on sale at Sears right now for $29.99.
    Greg
    Greg DeBacker, Dec 9, 2003
  6. George
    Don Wiss Guest
    Use a wood chisel and hammer. Face the bevel towards the hole inside. With
    little effort you can chisel out the plaster. Then cut the wood lathe with
    a saw.
    Don <donwiss at panix.com>.
    Don Wiss, Dec 10, 2003
  1. Buzby
    Reparing holes in old plaster
    Buzby, Jan 2, 2006, in forum: Misc DIY
    518
    marble
    Jan 5, 2006
  2. Replies:
    396
  3. BETAC-T
    12
    1,106
    Goedjn
    Apr 17, 2007
  4. Doug Burky
    Bricks: Round holes vs. Square holes
    Doug Burky, Aug 8, 2005, in forum: Building Construction
    13
    968
    Doug Burky
    Aug 9, 2005
  5. zek
    Cutting holes in interior walls
    zek, May 28, 2011, in forum: Home Repair
    29
    641
    Bob F
    May 29, 2011
