Cutting Crown molding with 135 degree angle wall
Discussion in 'Misc DIY' started by Steven, Feb 12, 2006.
  1. Steven
    Steven Guest
    I am trying to butt a piece of Crown molding up against the wall at a
    135 degree (inside) corner.
    I am using the 'lay the molding flat and look up the tables' approach
    to figure out where to cut. The moulding is rather large so I can't
    stand it up and just slice 135 degrees.
    Any suggestions as to what miter/bevel angles will give me a 135 degree
    angle?
    Is is even possible?
  2. Steven
    Ken Guest
    Steven wrote:
    > Hi,
    > angle?
    > Thanks
    Here is a crown molding calculator:
    http://www.construction-resource.com/calculators/crown-molding.php
    A 135 degree inside corner should be the same as doing half of a 90
    degree outside corner.
    Ken
    Ken, Feb 13, 2006
  3. Steven
    dnoyeB Guest
    Steven wrote:
    > Hi,
    > angle?
    > Thanks
    why not search the internet for crown molding. There are techniques
    that involve carving out the mold shape that are simpler than precisely
    matching the angle. Otherwise, there is a small hand device you can buy
    that is used to precisely match angles and transfer them to your work.
    Do you have a miter box or power saw or what?
    Thank you,
    "Then said I, Wisdom [is] better than strength: nevertheless the poor
    man's wisdom [is] despised, and his words are not heard." Ecclesiastes 9:16
    dnoyeB, Feb 13, 2006
  4. Steven
    Jim Conway Guest
    Ken,
    It looks like a great tool, but I'm a bit confused by the values
    calculated.
    For wall and spring of 90 degrees each and for moulding applications
    using butts meeting coped edges, isn't a miter and bevel somewhere
    around 32-33 degrees each?
    This calcutor might be good if you're to miter your moulding for each
    corner, but because walls are rarely square and coping is more
    preferable in those instances, how can I apply this calculator for
    projects to be coped?
    TIA!!
    > Ken
    Jim Conway, Feb 13, 2006
  5. Steven
    Steven Guest
    Thanks! That did the trick, I knew it couldn't be as hard as I was
    making it.
    Steven, Feb 14, 2006
  6. Steven
    Ken Guest
    Jim Conway wrote:
    > Ken,
    > calculated.
    > TIA!!
    For coping, you could still use the calculator. First cut the piece
    that will be butted, then use the calculator to miter the other piece,
    then cope it as usual. Of course make sure that you cope at an angle
    that will work with whatever wall angle you have.
    Ken
    Ken, Feb 14, 2006
  1. James Simpson
    1,053
    James Simpson
    Jan 28, 2004
  2. Foo Man Choo SE
    313
    zxcvbob
    Apr 12, 2004
  3. TC
    Cutting Crown Molding by Hand
    TC, Aug 22, 2004, in forum: Home Repair
    452
  4. Perry Templeton
    'Nother angle question, crown molding.
    Perry Templeton, Jan 30, 2005, in forum: Home Repair
    240
    Duane Bozarth
    Jan 30, 2005
  5. Foo Man Choo SE
    Trim question: To cope or not to cope 135 degree inside angles
    Foo Man Choo SE, Apr 9, 2004, in forum: Building Construction
    14
    935
    zxcvbob
    Apr 12, 2004
