Cost of adding second layer of bricks to a conservatory
Discussion in 'Misc DIY' started by google@compoundeye.co.uk, Dec 2, 2007.
  1. Guest
    I'm wondering if anyone can give me any tips on fixing up a
    conservatory.
    I've just moved into a new 2 bed house and it has a pretty rough and
    ready conservatory. It's double glazed on all sides but it only has a
    single layer brick wall, so it's cold, it's more like part of the
    outside of the house than the inside!
    We think that putting in another layer of bricks with insulation in
    between will transform it into a proper usable space. Does anyone have
    any kind of rough guide to pricing up brick work? I guess what I'm
    after is a ball-park cost per square meter for DIY vs professional
    builder. I'm willing to do it myself but I have no experience and if
    the cost of brick-laying labour isn't extortionate then it might be
    simpler to get a bricky in.
    Can anyone give me any advice?
    Cheers
    M.
    , Dec 2, 2007
  2. Guest
    On Dec 1, 5:08 pm, wrote:
    > Hi,
    > conservatory.
    > Cheers
    > M.
    I don't know if building codes in the UK allow it, but if it were my
    place in the United States, I would put up an inner wall of gypsum
    board with a layer of insulation (we call it drywall) in between, much
    less expensive and quicker than brick.-Jitney
    , Dec 2, 2007
    Just to get things into proportion, roughly what are the relative
    areas of glass and brickwork?
    If it is only a dwarf wall, then whilst you would improve the
    situation, would it make enough difference?
    Chris
    Chris J Dixon Nottingham UK
    Have dancing shoes, will ceilidh.
    Chris J Dixon, Dec 2, 2007
  4. robgraham Guest
    > Chris
    Extending Chris' query, what is the roofing material ? If the dwarf
    wall is single brick then it suggests the structure was put up on the
    cheap and an inexpensive roof covering with poor insulation has been
    used.
    I would guess you would get a far greater improvement if there was
    better insulation in the roof covering.
    Rob
    robgraham, Dec 2, 2007
  5. Guest
    Sounds like a very practical idea, thanks!
    M.
    , Dec 2, 2007
  6. Guest
    > > Chris
    > used.
    Yup, it was definitely put up on the cheap! The roof is
    polycarbarbonate no more than 15 - 20mm so kicking myself for not
    thinking of that. I imagine that's a pretty good at losing heat. So,
    double glazed glass roof needed I guess?
    M.
    , Dec 2, 2007
  7. Guest
    The conservatory is about 6 - 7 ft x 20 - 22. One of the side walls
    has no windows, the back wall has a pair of double glazed doors. The
    other side wall and the back wall are about 2.5 - 3 feet high, the
    rest is windows. So two thirds window, one third brick roughly.
    M.
    , Dec 2, 2007
  8. dg Guest
    On 2 Dec, 01:08, wrote:
    > Hi,
    > conservatory.
    > Cheers
    > M.
    Most of the heat is going up and out through the glass or the roof.
    The thermal improvements in adding an inner skin are negligible - let
    alone the practicalities and expense.
    If you really need to do something, then dry-line it with a 50mm layer
    of PIR foam (Celotex/kingspan) and plasterboard and skim
    dg
    dg, Dec 2, 2007
  9. clot Guest
    >>>> and ready conservatory. It's double glazed on all sides but it
    >>>> only has a single layer brick wall, so it's cold, it's more like
    >>>> part of the outside of the house than the inside!
    >>>> have any kind of rough guide to pricing up brick work?
    >>> Chris
    >> used.
    Careful! From what I've read, (I no practical experience of this) some
    conservatories built with polycarbonate roofing may not be sufficiently
    sound to take double glazing.
    clot, Dec 2, 2007
  10. Guest
    Bugger :eek:/
    Anyone know what I need to look for to say if it can hanlde double
    glazing or not?
    M.
    , Dec 3, 2007
  1. David W.E. Roberts
    second layer of plasterboard on lath&plaster ceiling
    David W.E. Roberts, Apr 19, 2004, in forum: Misc DIY
    27
    1,665
  2. swinster
    638
    George
    Jul 21, 2007
  3. HouseDreamer
    Living in house while adding second floor
    HouseDreamer, Aug 11, 2003, in forum: Misc DIY
    443
    Tim Fischer
    Aug 12, 2003
  4. Beryl
    8
    835
    Just Joshin
    Mar 7, 2007
  5. RJS
    10
    551
