Correctly framing 45 degree angles in walls
Discussion in 'Building Construction' started by psubill78@gmail.com, Oct 16, 2006.
  1. Guest
    I'm finishing off my basement, and am having some issues figuring out
    how to properly build the walls to follow my foundation structure.
    There is a bay door that the foundation walls follow and I want to
    frame it out to keep the shape.
    I searched to find some pictures or a design on how to do this properly
    so that the drywallers would not have difficulty putting in the
    drywall..
    Suggestions?
    , Oct 16, 2006
  2. longshot
    longshot Guest
    Rip your framing with a table saw set on 45 degrees
    <> wrote in message
    > drywall..
    > Suggestions?
    longshot, Oct 16, 2006
  3. Willshak
    Willshak Guest
    > drywall..
    > Suggestions?
    Are you meaning to frame the steps area leading to the Bilco door?
    If so, why bother?
    I framed my basement and when I got to the stairs area, I just framed
    the basement wall for an outside insulated door and left the stair area
    as it was. I insulated well around the door framing. The locking
    insulated door served as a more secure basement, as well as providing
    more insulation than the Bilco door. From inside, the door looks like
    any other door to another room or to the outside.
    Bill
    in Hamptonburgh, NY
    To email, delete the double zeroes after @
    Willshak, Oct 17, 2006
  4. Guest
    Right, what if I don't have access to a table saw....
    Are there any other options/methods?
    > <> wrote in message
    > news:...
    > > drywall..
    > > Suggestions?
    , Oct 17, 2006
  5. Guest
    Clamp a two by on edge in your Workmatel walk down it with your skill
    saw set at 45.
    On an inside corner, you can butt two by's at a 45 degree angle. An
    outside corner is just the reverse of an inside corner ... you can
    float the corner as a second choice.
    Ken
    , Oct 17, 2006
  6. HerHusband
    HerHusband Guest
    Wouldn't you want to rip the framing at 22-1/2 degrees?
    If you cut each wall at 45 degrees and butt them together, you'll end up
    with a 90 degree turn.
    Anthony
    HerHusband, Oct 17, 2006
  7. longshot
    longshot Guest
    "HerHusband" <> wrote in message
    news:Xns985F4DA3563FBherhusband@216.196.97.136...
    > Anthony
    all depends on your layout. either would work
    longshot, Oct 17, 2006
  8. Guest
    On Tue, 17 Oct 2006 09:37:55 -0500, HerHusband <>
    You cut one at 45.
    Ken
    , Oct 17, 2006
  1. James Simpson
    972
    James Simpson
    Jan 28, 2004
  2. Dolchas
    459
    Dan G
    Aug 17, 2003
  3. Foo Man Choo SE
    291
    zxcvbob
    Apr 12, 2004
  4. maurice
    741
    maurice
    Dec 2, 2006
  5. Foo Man Choo SE
    Trim question: To cope or not to cope 135 degree inside angles
    Foo Man Choo SE, Apr 9, 2004, in forum: Building Construction
    14
    895
    zxcvbob
    Apr 12, 2004
Share This Page
