copper based "paint"
Discussion in 'Misc DIY' started by Brandon, Jun 26, 2004.
  1. Brandon
    Brandon Guest
    I recently saw, on one of the "home" channels the end of a segment where the
    were discussing a paint that used very fine ground copper. Basically it
    could be painted on to virtually any surface and would age and patina.
    I have a 6 foot piece of 2 inch PVC coming out of the ground and up my back
    fence that is used for the backwash for my pool.
    I think it would look much nicer if I could sand it down and paint it with
    this type of finish.
    Any ideas what this is and where I can get it? Home depot?
    Brandon
  2. Brandon
    Mort Guffman Guest
    There is a type of wood preservative - it's green and the consistency
    of water. It contains copper. You use it to keep wood from
    rotting/rotting more. I forget what it's called but I think you can
    get it at HD. I don't know if it would adhere to PVC though.
    mort
    On Sat, 26 Jun 2004 02:12:51 -0700, "Brandon" <>
    >Thanks
    >Brandon
    Mort Guffman, Jun 26, 2004
  3. Brandon
    Brandon Guest
    "Mort Guffman" <> wrote in message
    > mort
    Thanks for the response. The product I saw was specifically a paint and
    could be used on a variety of surfaces.
    I wonder if the product you describe would patina wood as well?
    That would be an interesting look.
    Brandon
    the
    back
    with
    > >Thanks
    > >Brandon
  4. Brandon
    CBHVAC Guest
    "Brandon" <> wrote in message
    news:n4bDc.17$Rr2.5@lakeread03...
    the
    back
    > Thanks
    > Brandon
    What you want, is Metal Effects Copper paint.
    Made by, Modern Masters Inc
    13201 Saticoy Street,
    North Hollywood, CA 91605
    800-942-3166
    818-765-0013 FAX
    CBHVAC, Jun 26, 2004
  5. Brandon
    dadiOH Guest
    > news:...
    >> consistency of water. It contains copper. You use it to keep wood
    >> from rotting/rotting more. I forget what it's called but I think
    >> you can get it at HD. I don't know if it would adhere to PVC
    >> though.
    >> mort
    > paint and could be used on a variety of surfaces.
    It's Cuprinol. It will make the wood green.
    dadiOH
    _____________________________
    dadiOH's dandies v3.0...
    ....a help file of info about MP3s, recording from
    LP/cassette and tips & tricks on this and that.
    Get it at http://mysite.verizon.net/xico
    dadiOH, Jun 27, 2004
  6. Brandon
    Brandon Guest
    "montana wildhack" <> wrote in message
    news:2004062622002375249%montana@wildhackcominvalid...
    > On 2004-06-26 18:32:01 -0400, "CBHVAC"
    > > 800-942-3166
    > > 818-765-0013 FAX
    > You'll also need a special primer made for plastic, marketed by
    > Rustoleum (I think). It's a spray paint.
    Excellent.
    Thanks for the information.
    Any ideas is available in retail locations?
    Brandon
    Brandon, Jun 27, 2004
  7. Brandon
    m Ransley Guest
    Pro paint stores would likely sell Metal Effects It is a very nice,
    versitile product but a proper PVC primer should be used .
    m Ransley, Jun 27, 2004
  8. Brandon
    Mort Guffman Guest
    Here is a link to info on the wood preservative I was talking about.
    I'm sure I bought some a few years ago at HD or Lowes:
    http://www.merichem.com/COPPER/Main.HTM
    mort
    On Sat, 26 Jun 2004 14:07:46 -0700, "Brandon" <>
    >news:...
    >> mort
    >Brandon
    >the
    >back
    >with
    >> >Thanks
    >> >Brandon
    Mort Guffman, Jun 27, 2004
  9. Brandon
    Chris Lewis Guest
    According to Brandon <>:
    It's either cuprinol or PT "paint". The latter being liquid CCA (read Copper-
    chomated arsenate, the nasty stuff they make PT lumber out - it's NOT a paint)
    you apply to the cut ends of PT lumber.
    Highly toxic. Won't stick to plastic pipe or any other non-porous material. Won't
    cover worth diddly even if it'd stick. Will NOT patina. It's really more of
    a "wash" to let the poisonous gunk soak into the ends of lumber.
    Go to a craft or paint store that specializes in faux finishes. They may be able
    to find you something that'd stick and emulate patina reasonably well.
    Chris Lewis, Una confibula non set est
    It's not just anyone who gets a Starship Cruiser class named after them.
    Chris Lewis, Jun 28, 2004
  1. Replies:
    989
  2. DavidM
    771
    DavidM
    Jun 28, 2007
  3. James Murphy
    Water Based Sealer and Oil based Poly?
    James Murphy, Aug 5, 2003, in forum: Home Repair
    395
    James Murphy
    Aug 5, 2003
  4. John Smith
    682
    Bay Area Dave
    Apr 28, 2004
  5. Replies:
    436
