compressor motor tripping breaker
Discussion in 'Home Repair' started by a, Aug 13, 2004.
  1. a
    a Guest
    I have an older model electric motor driven compressor that causes my
    electrical circuit breaker to trip when the motor kicks in to "refill" a low
    pressurized tank. In other words, when the tank is empty and I plug it in,
    it starts and works fine, filling up the tank, then stops automatically when
    full. After use or when the tank's pressure becomes low, the motor attempts
    to start the compressor again, but is not able to. The motor hums for a
    short while, then trips the breaker.
    The circuit is one a 15 amp breaker, the motor draws less than 11 amps. Any
    ideas?
    a, Aug 13, 2004
  2. "a" <> wrote in message news:UpUSc.13229$fz2.1992@edtnps89...
    low
    in,
    when
    attempts
    Any
    > ideas?
    Have you really checked the motor draw? It can be substantially higher at
    start-up than in a steady state situation. I experienced breaker trips for
    years in the exact same situation with my compressor. My solution was to
    run a dedicated circuit to the shop for the compressor. I think I used a 25
    or 30 amp breaker and sized the wire appropriately.
    KB
    Kyle Boatright, Aug 13, 2004
  3. "Greg O" <> wrote in message
    > low
    > in,
    > when
    > attempts
    > Any
    > > ideas?
    > On all compressors there is some sort of unloader that releases the air
    > pressure at the head or discharge of the compressor pump. My bet is your
    > compressor's unloader has failed, and does not dump the air at shut off.
    > Some units have this unloader tied in to the pressure switch, others use a
    > valve at the tank that looks like a plain old fitting.
    > Greg
    Ditto.
    The function of the unloader being so the motor doesnt start under
    load--allows it to get up to speed before having to do any serious work, as
    motor startup draws a buncha amperage as is.
    Oftentimes the unloader valve gets clogged with crud from the compressor oil
    and simply need cleaning in solvent of some type.
    Usually a properly functioning unloader will release a small amount of air
    each time the pump cycles off and it makes a short hissing sound at this
    time.
    SVL
    PrecisionMachinisT, Aug 13, 2004
  4. "PrecisionMachinisT" <> wrote in message
    > news:...
    a
    > > low
    it
    > > in,
    automatically
    > > when
    > > attempts
    a
    amps.
    > > Any
    > > > ideas?
    a
    > > Greg
    > Ditto.
    as
    oil
    > time.
    > SVL
    warning: thread hijack for another compressor question
    i also have one that has a problem. it will go on, charge up the tank to 125
    psi and shutoff correctly. however, the relief valve under the electronics
    will then open, vent to 75psi, close, and the motor will go on again.
    there is another safety release valve screwed into the top of the tank. that
    one isn't the one that lets go.
    is this also a failure in the unloader? there's a plug in the top that has 2
    tubes coming out of it. one goes to the motor, one to the valve that's
    giving me the problem. does this plug have some sort of diaphragm that could
    be bad? the schematic i have of the compressor doesn't even have this part
    listed, so i don't know what it does.
    thanks,
    charlie
    Charles Spitzer, Aug 13, 2004
  5. "Greg O" <> wrote in message
    > "Charles Spitzer" <> wrote in message
    > news:cfilfc$pdq$...
    > 125
    electronics
    > that
    has
    > 2
    > could
    part
    > > thanks,
    > > charlie
    > With the unloader that is controlled by the pressure switch, there is a
    > one-way cheack valve in the compressor discharge line, before the line
    > enters the tank. Your check valve is stuck open. The function of the check
    > valve is to stop air from leaveing the tank, flowing back through the
    > discharge line, when the unloader is working.
    > Greg
    thanks. any idea where it could be, or if it can be fixed? what would it
    look like? there's no check valve on my parts list.
    regards,
    charlie
  6. m Ransley
    m Ransley Guest
    Unloader or not a motor on a compressor can take 9x surge on an old
    worn motor- compressor. Test your surge laod, wires etc.
    m Ransley, Aug 13, 2004
  7. "Greg O" <> wrote in message
    > news:cfjd9m$s2o$...
    > > news:...
    message
    > > > news:cfilfc$pdq$...
    tank
    > to
    > > > 125
    > > electronics
    again.
    > tank.
    > > > that
    that
    > > has
    > > > 2
    that's
    that
    > > > could
    this
    > > part
    > > > > thanks,
    > > > > charlie
    a
    > check
    > > > Greg
    > > regards,
    > > charlie
    > What brand of compressor?
    > My guess it would be right where the pump discharge line enters the tank.
    > Greg
    Agreed.
    Probly a brass plug looking thing screwed into the top of the tank, 1in pipe
    threads or so usually--the compresser generally delivers air to it through
    copper or aluminum tubing.
    SVL
    PrecisionMachinisT, Aug 14, 2004
  8. Guest
    It could be you have a weak breaker. Swap it with another one in the
    box (of the same amperage), or just buy another one and try. At most
    you'll be out the cost of the breaker, usually around $5, and you'll
    have a spare breaker. Motors consume huge amounts of power during
    startup. most breakers allow for that. Your breaker may just not be
    able to handle it. You could also have a weak/dying capacitor in the
    motor.
    >ideas?
    , Aug 14, 2004
  9. DanG
    DanG Guest
    The problem is with the compressor.
    It is either the unloader or the back check valve, more likely
    the back check (on some compressors the same piece performs both
    functions). This part is located where the compressor discharge
    line enters the tank on many units. Your compressor is trying to
    start against the pressure in the tank for which it was never
    designed.
    Keep the whole world singing . . . .
    DanG (remove the sevens)
    message news:...
    > news:...
    causes my
    to "refill" a
    > > low
    and I plug it
    > > in,
    automatically
    > > when
    the motor
    > > attempts
    motor hums for a
    than 11 amps.
    > > Any
    > > > ideas?
    releases the air
    bet is your
    shut off.
    others use a
    > > Greg
    > Ditto.
    under
    serious work, as
    compressor oil
    amount of air
    at this
    > time.
    > SVL
    DanG, Aug 14, 2004
  10. "PrecisionMachinisT" <> wrote in message news:<>...
    > news:...
    > > news:cfjd9m$s2o$...
    > > > news:...
    > message
    > > > > news:cfilfc$pdq$...
    > tank
    > to
    > 125
    > electronics
    > again.
    > tank.
    > that
    > that
    > has
    > 2
    > that's
    > that
    > could
    > this
    > part
    > > > > > thanks,
    > > > > > charlie
    > a
    > check
    > > > > Greg
    > > > regards,
    > > > charlie
    > > Greg
    > Agreed.
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47065
    there is a plug screwed into the top of the tank on the side that
    isn't visible in this picture. however, that part isn't listed in the
    parts list that came with it, so i don't know if it's orderable. is
    this fixable, or jury-riggable with another check valve?
    Charlie Spitzer, Aug 16, 2004
  1. LawHead
    1,172
    LawHead
    Dec 25, 2006
  2. barry martin
    breaker tripping
    barry martin, Jun 23, 2003, in forum: Home Repair
    361
    barry martin
    Jun 23, 2003
  3. Andy
    789
    Stormin Mormonn
    Nov 20, 2003
  4. Tom
    14
    835
    Stormin Mormon
    Oct 31, 2004
  5. Replies:
    233
Share This Page
