Clogged kitchen sink with garbage disposer
Discussion in 'Misc DIY' started by fantabular, Aug 4, 2004.
  1. fantabular
    fantabular Guest
    I peeled potatoes and like a fool, crammed them down th disposal
    instead of throwing them away.
    Now, when I turn on the disposal, all the water in the left side goes
    down the drain and comes up the right side of the double sink.
    This happened before, but it was fixed by removing some of the peels
    that I could see. Now, I see nothing and I have DRANO in my sink as
    well (Drano didn't work, as you might have guessed).
    Where should we go from here?
    Thanks in advance!
  2. fantabular
    AC/DCdude17 Guest
    X-No-Archive: Yes
    > Thanks in advance!
    I just checked our sink and found that disposal is on the right side. A
    Horizontal pipe from disposal connects to the left sink with a T joint
    then right below the left sink is the U trap.
    When you run the disposal, it acts like a centrifugal pump that pushes
    the debris/water out the horizontal pipe. If there's less resistance
    going up than down, water will get pumped up the left sink.
    I'd first inspect the U trap. Make sure you put a bucket under there
    before you pull it out :). If this fails, you could plug the disposal
    side hole with a rubber plug that came with the disposal. Have someone
    hold down the plug. Fill the left sink and force the water down with a
    toilet plunger.
    AC/DCdude17, Aug 4, 2004
  3. fantabular
    DaveG Guest
    "fantabular" <> wrote in message
    > Thanks in advance!
    Your disposal plumbing is packed with partially ground potato goop. Get a
    pail big enough to fit under your drain trap, which will be on the sink next
    to the disposal. Put the drain plug in the sinks to minimize the water gush
    you'll get when the clog is removed. Then remove the horizontal pipe that
    runs from your disposal to the drain trap. It's possibly clogged. Take it
    and rinse the crap out. Use your laundry tub or some other sink, don't run
    more water into your kitchen sink. Then dis-assemble your drain trap the
    clean it as well. This should get most of the clog. Then re assemble
    everything, Revove the sink plugs, turn on the disposal and hope for the
    best. Flush out with lots of clean water.
    Be sure to wear gloves and eye protection for that draino water. You don't
    wan't that stuf on your skin or in your eyes.
    DaveG, Aug 4, 2004
  1. Grendel
    How to remove garbage disposer...
    Grendel, May 20, 2004, in forum: Home Repair
    355
  2. SApelzin
    Garbage disposer - can it be repaired?
    SApelzin, Jun 22, 2004, in forum: Home Repair
    347
    Steve B.
    Jun 23, 2004
  3. Percival P. Cassidy
    Garbage disposer too noisy with stainless steel sink?
    Percival P. Cassidy, Jul 27, 2006, in forum: Misc DIY
    365
    Phisherman
    Jul 27, 2006
  4. Joy
    8
    750
    DerbyDad03
    Apr 6, 2008
  5. Jim
    Kitchen Sink and Disposer Question
    Jim, Aug 21, 2003, in forum: Building Construction
    286
