cleaning sulfuric acid stains from brick pavers
Discussion in 'Home Repair' started by Bill's Cart Service, Jul 24, 2013.
  1. Bill's Cart Service, Jul 24, 2013
  2. Bill's Cart Service
    Danny D. Guest
    On Wed, 24 Jul 2013 00:44:02 +0000, Bill's Cart Service wrote:
    > Customers are complaining about the stains on their
    > pavers. Any soulution to remove these stains would be appreciated.
    Dunno why the color is that of rust, but, in alt.home.repair
    I posted a bunch of pictures where I removed real rust stains
    (from tools left outside all winter) on plastic outdoor tables
    with pool acid.
    The caveat was that I was removing real rust stains; and that
    the medium was plastic.
    In your case, who knows what the rust-colored stain really is;
    and, depending on what the paver is made out of, the pool acid
    may eat into the paver (so you must test in an inconspicuous
    area first).
    Someone else should know a lot more; but that's all I can offer
    without knowing what the rust-colored stain is made out of.
    Danny D., Jul 24, 2013
  3. On 7/23/2013 7:44 PM, Bill's Cart Service wrote:
    > Have a golf cart business that leaves sulfuric acid stains on brick
    > pavers after batteries have been charged. It has the appearence of the
    > color of rust. Customers are complaining about the stains on their
    Have you tried battery terminal cleaner sold at auto parts stores? You
    could try a small spray can of it before looking for a larger container
    from a battery warehouse. There is a Crown Battery commercial location
    on the other side of town from me and companies like that have very
    knowledgeable folks on their staff. o_O
    TDD
    The Daring Dufas, Jul 24, 2013
  4. Bill's Cart Service
    Oren Guest
    I'd try some CLR, first. Sulfamic acid (used as a tile and grout
    cleaner - in the tile section of the store), next.
    Found this site, but have not used the product. Just passing it
    along.
    <http://www.theruststore.com/Concrete-Rust-Remover-Step-by-Step-W60C2.aspx>
    Oren, Jul 24, 2013
  5. Bill's Cart Service
    dadiOH Guest
    "Bill's Cart Service"
    <> wrote
    in message
    news:1094b$51ef2352$cf3aab60$
    > stains on brick pavers after batteries have been charged.
    > It has the appearence of the color of rust. Customers
    > are complaining about the stains on their pavers. Any
    Why/how is acid getting out of the batteries?
    I'm trying to figure out what sort of stains you actually have. Your
    description of being rust colored has gotten you suggestions on how to
    remove rust but I don't think that's what you have. Acids can induce iron
    to rust but they don't create it; the opposite in fact.
    My best guess is that the acid has dissolved some of the paver surface. If
    that's it, no cure.
    dadiOH
    ____________________________
    Winters getting colder? Tired of the rat race?
    Taxes out of hand? Maybe just ready for a change?
    Check it out... http://www.floridaloghouse.net
    dadiOH, Jul 24, 2013
  6. Bill's Cart Service
    Danny D. Guest
    > surface. If that's it, no cure.
    Maybe dissolve some more paver surface to even it out?
  7. Bill's Cart Service
    Guest
    That is my take too. I'm not sure calling it a stain is the
    right terminology. If you put acid on something it can react
    with, the chemical reaction turns what is there into something else
    and that portion is gone and not recoverable.
    might be an option if the look of those "stained" areas
    is acceptable and the rest of the pavers is not a real large
    area. It's also possible that the acid removed a layer of
    old, faded paver and left the new exposed. In that case,
    power washing the rest might even it out.
    , Jul 24, 2013
  8. Bill's Cart Service
    Dan Espen Guest
    "dadiOH" <> writes:
    > <> wrote
    > in message
    > that's it, no cure.
    My thought too, but there is a cure.
    First wash with water. If that doesn't clear up the problem, get a
    paver puller and some replacement pavers. Done deal.
    Dan Espen
    Dan Espen, Jul 24, 2013
  9. Bill's Cart Service
    Oren Guest
    On Wed, 24 Jul 2013 13:04:27 -0400, Dan Espen <>
    Can't you just turn the paver over to the good side and use it again?
    Oren, Jul 24, 2013
  10. Bill's Cart Service
    TomR Guest
    > pavers after batteries have been charged. It has the appearance of
    > the color of rust. Customers are complaining about the stains on
    > their pavers. Any solution to remove these stains would be
    > appreciated.
    Acid is used to intentionally do "acid staining" of concrete to change the
    color of the concrete. So, I doubt that anything will "reverse" the stains
    that you are causing on people's concrete or brick pavers.
    I like the ideas that others suggested of using a "paver puller" to remove
    the damaged pavers and either replace them or flip them over etc. Or, maybe
    switch them out with other pavers that are in a non-visible location.
    Obviously, something needs to be put down under where the work is being done
    so no acid or anything else drips down and damages the surface of whatever
    is underneath. That would be true for any type of on-sight vehicle repair
    service.
    If Bills Cart Service is your real name, it looks like you are in the
    Houston, TX area
    TomR, Jul 25, 2013
  11. Bill's Cart Service
    Oren Guest
    >> appreciated.
    >service.
    "...This GC2 (Golf Cart Battery) battery box is manufactured from
    polyethylene plastic that effectively collects electrolyte, allows
    ventilation and prevents accidental contact of battery terminals. This
    Plastic Battery Box GC2 Case meets USCG Code of Federal Regulations
    183.420 and ABYC E-10.7 specification."
    Proudly Made in The USA!
    <http://www.remybattery.com/group-size-gc2-battery-box>
    >Houston, TX area
    Oren, Jul 25, 2013
    #11
  12. Bill's Cart Service
    Oren Guest
    On Thu, 25 Jul 2013 06:51:26 +0100, "harryagain"
    <> wrote:
    >If you have battery acid leaking then you have a major problem with the
    >batteries.
    Why a "major problem"? Do batteries in the UK not have corrosion? It
    is from the acid that can weep out of the cells.
    <http://www.agcoauto.com/content/images/electrical/transient/corroded_terminal.jpg>
    I've seen battery mounts and fasteners rusted, corroded, same with
    corrosion deep into a battery cable - that can not be cleaned up and
    needs replaced.
    Tip: put a copper penny on the battery top, the corrosion will migrate
    to the penny and not the cable. Replace as needed for a penny.
    >This needs attention or your golf carts will corrode away apart from the
    >safety aspect (someone could get an acid burn).
    Hence, the plastic battery boxes I mentioned prior.
    Oren, Jul 25, 2013
    #12
  13. Bill's Cart Service
    harryagain Guest
    "Oren" <Oren@127.0.0.1> wrote in message
    >>batteries.
    I haven't seen a battery as bad as that for years now.
    And never seen one so bad that acid leaks on to the floor.
    A bit of WD40 or similar on the terminals cuts out most of the terminal
    corrosion problems.
    Most batteries for traction applications are sealed in case the vehicle
    overturns when the driver could be burned otherwise.
    > needs replaced.
    harryagain, Jul 26, 2013
    #13
  1. Replies:
    600
  2. Ignoramus12938
    Sulfuric Acid Drain Cleaner Concentration?
    Ignoramus12938, Apr 29, 2006, in forum: Home Repair
    10
    952
    Jim Yanik
    May 2, 2006
  3. Concrete pavers / interlock pavers
    , Apr 14, 2005, in forum: Building Construction
    486
  4. Dave Osborne
    Getting rid of acid stains on patio
    Dave Osborne, Sep 10, 2010, in forum: UK DIY
    21
    2,119
    Dave Osborne
    Oct 11, 2010
  5. bob
    20
    688
    Stormin Mormon
    Apr 1, 2011
