Cleaning brickwork
Discussion in 'Misc DIY' started by CA, Mar 5, 2005.
  1. CA
    CA Guest
    Hi. I've recently bought a new house with red brick exterior.
    However there is a lot of cement stuck to parts of the brickwork due
    to an untidy bricklayer. Is there any way I can clean the cement off
    the red brickwork using some sort of cleaner solution / wire brush
    etc?
    Craig
    CA, Mar 5, 2005
  2. CA
    Steve P Guest
    "CA" <> wrote in message
    > etc?
    > Thanks
    > Craig
    See replies to your 12.00 post
    Steve P, Mar 5, 2005
  3. CA
    tony green Guest
    > etc?
    > Thanks
    > Craig
    Brick cleaning acid is available from most builders merchants. Use as
    direction. Apply with a soft sweeping brush head, no pole. protection use
    like rubber gloves and eye protectors
    tony green, Mar 5, 2005
  4. CA
    Nicholas Guest
    Hi
    I was told not to use brick acid as it can damage/weaken the mortar holding
    the wall together...
    I'd probably ignore that advice if the wall was really messy though but make
    sure you clean off very thoroughly.
    Cheers
    Nicholas
    Nicholas Buttle - Quality Joinery and Cabinet Making
    http://www.nbjoinery.net
    "tony green" <> wrote in message
    news:6epWd.505$...
    > news:...
    >> etc?
    >> Thanks
    >> Craig
    Nicholas, Mar 6, 2005
  5. CA
    tony green Guest
    "Nicholas" <> wrote in message
    news:422ac6dc$0$8759$...
    > Hi
    holding
    make
    Its used through out the building trade, Read the instructions on the
    container before you buy, then make your own mind up.
    tony green, Mar 6, 2005
    > etc?
    Brick acid
    > Thanks
    > Craig
    The Natural Philosopher, Mar 6, 2005
  7. Nicholas wrote:
    > Hi
    Well so it does. But not enough to be an issue, because you pull the big
    lumps off first with a chisel or wire brush and use the acid to freshen
    up the surface only.
    The mortar joints will fizz, but we are talking the merest mm or so
    degradation.
    Hose the wall afterwards tho.
    > Cheers
    > Nicholas
  1. CA
    Cleaning Brickwork
    CA, Mar 5, 2005, in forum: Misc DIY
    330
    Rob Morley
    Mar 5, 2005
  2. BIGEYE
    Cleaning cement from brickwork?
    BIGEYE, Jun 3, 2005, in forum: Misc DIY
    335
    Jun 3, 2005
  3. Neil
    841
  4. HJWD
    Cleaning Paint Off Brickwork
    HJWD, Oct 25, 2005, in forum: Misc DIY
    419
  5. Cleaning brickwork
    , Mar 3, 2006, in forum: Misc DIY
    10
    861
