Christmas tree won't drink water
Discussion in 'Home Repair' started by Finite Guy, Dec 22, 2004.
  1. Finite Guy
    Finite Guy Guest
    Hi All: I couldn't find and appropriate newsgroup for this post so I
    thought I'd try this one. Besides, if I don't solve this problem, I
    will be needing a home repair.
    We cut a fress Christmas tree a couple of weeks ago at a local tree
    farm; it is a Balsam Fir. Since this tree was huge, by the time I set
    it up, I ended up cutting about one foot off the bottom and 6 inches
    from the top. The important thing is that it was a fresh cut just
    before I put up the tree and filled the tree holder pan with water.
    This tree will not drink water. Is it becasue it is a fresh tree and
    doesn't need it?
    Any suggestions on what I should do?
    Robert
  2. Finite Guy
    James Nipper Guest
    If you did the fresh cut at the bottom just a few hours before you set it up
    and now it doesn't drink water, it may be a pretty fresh tree !! I would
    check it 24 hours later, to see if it has taken some of the water.
    I don't know of anything else you can or need to do...............
    Good Luck !!
    --James--
    James Nipper, Dec 22, 2004
  3. Finite Guy
    TCS Guest
    >doesn't need it?
    Drill a couple of 1/2" holes through the base.
    TCS, Dec 22, 2004
  4. Finite Guy
    Noozer Guest
    "Finite Guy" <> wrote in message
    > doesn't need it?
    You cut the top and bottom? Try using it like a straw! : )
    I like the drill a couple holes in the base...
    Is the cut end of the tree sitting against the bottom of the pan? This might
    be "sealing" out the water. Drilling holes will make sure the water can get
    into the tree.
    Noozer, Dec 22, 2004
  5. Finite Guy
    Finite Guy Guest
    Good Point, the bottom is pretty much touching the bottom of the pan
    which may tend to seal it. I will drill the holes toninte when I go
    home. Thanks for your help.
    Happy Holidays.
    Robert
    P.S. I will be sure not to slip and drill through the bottom of the
    pan.
    >news:...
    >> doesn't need it?
    >into the tree.
  6. Finite Guy
    bumtracks Guest
    National Christmas Tree Assn. PRESS RELEASE
    http://www.realchristmastrees.org/care.html
    > Happy Holidays.
    > Robert
    > pan.
    > >news:...
    > >> doesn't need it?
    might
    get
    > >into the tree.
    bumtracks, Dec 22, 2004
  7. Finite Guy
    Matt Guest
    Well, whatever you do, don't pour any jack daniels in the water. I
    tried that last year. I thought it was a pretty clever idea, because an
    hour after I filled the stand, the pan was empty. So I refilled it with
    plain water - nothing. Added some more JD - nothing. Finally tried some
    Chivas - pan empty in 1/2 hour.
    This cycle continued all the way up to christmas day, when my kids woke
    up me and my wife, their bright faces full of excitement way before sun
    up. So we go downstairs.... what do we find? Yep. The christmas tree
    had taken off it's star, and put a lampshade on it's head. Also, there
    was christmas tree puke (thick, yellow sap) all over the gifts.
    An alchoholic christmas tree can ruin an otherwise perfect day, so - be
    careful.
    Matt, Dec 22, 2004
  8. Finite Guy
    Guest
    On 22 Dec 2004 14:31:13 GMT, (Patscga) wrote:
    >The tree should have started drinking immediately, that I'm sure of. Why it
    >isn't, I don't have a clue. Sorry.
    >Pat
    You can lead a tree to water, but you can't make it drink.
    :p
    Sorry I had to say that, I'm weak willed.
    Merry Christmas Everyone!!!!
    tom @ www.FindMeShelter.com
    , Dec 22, 2004
  9. Finite Guy
    The_Critic Guest
    <snip>> This tree will not drink water. Is it becasue it is a fresh tree
    and
    > doesn't need it?
    > Robert
    I received the following in a gardening newsletter. jerrybaker.com Hope
    it helps.
    "It'll soon be that time of year again, so I'd like to take a moment to
    wish you and yours a happy, healthy, and safe holiday season! I'm never
    one to leave you in a lurch, so to help you out with your holiday chores,
    here are a few of my favorite holiday tips and tricks.
    To help your Christmas tree retain its needles all season long, you need
    to select a tree that's fresh, and then consider shape, height, and price.
    When selecting a tree, shake it as hard as you can, then reach into the
    trunk, and remove all of the needles that have accumulated in the center
    of the tree. If you do this while you're still at a tree lot, you won't
    need to vacuum up all of the excess needles when the tree is in your
    house!
    As soon as you bring the tree home, while you still have it outdoors, cut
    and discard at least one inch off of the bottom of the trunk to remove the
    dried sap that'll prevent the tree from absorbing moisture. Then fill a
    large bucket half full of hot water and add 2 cups of clear corn syrup, 2
    tbsp. of beach, and 4 One-a-Day Vitamins+Iron. Set the trunk in the
    bucket, and allow it to soak overnight. Then keep plenty of water in the
    tree stand at all times.
    If you're going to hang up some evergreen roping, soak it in room
    temperature water for 24 hours before using it. Allow it to dry then spray
    it with a commercial antidesiccant that can be found at most tree
    nurseries.
    Decorative centerpieces can sure brighten up a room, but before using
    decorative greens, soak the stems in the corn syrup solution overnight,
    then spray them with an antidesiccant. When the spray has dried, make
    fresh, sharp cuts on the ends, and force them into pieces of oasis that
    have been soaked in the corn syrup solution and wrapped in foil to prevent
    evaporation.
    Follow these simple steps, and your halls will stay decked with fresh,
    fragrant greens throughout the holiday season. Then when the holidays are
    over, make sure you dispose of the greens properly. Don't burn them in your
    fireplace because sparks can travel up the chimney and set fire to the
    roof, or burn so hot that they'll cause a fire in the flue. Remember, it's
    better to be safe than sorry!"
    The_Critic, Dec 22, 2004
  10. Finite Guy
    MC Guest
    I am really stretching back into school biology here, But I thought that
    trees only used the underlying section just below the bark to supply the
    tree with nutrients from the roots, the middle of the tree was not active at
    all ???
    Any tree experts out there ??
    MC
    "The_Critic" <> wrote in message
    news:08myd.80$...
    > news:...
    > and
    > > doesn't need it?
    > > Robert
    > it helps.
    > house!
    > nurseries.
    > evaporation.
    your
    MC, Dec 22, 2004
  11. Yep. And the suggestion of a 1/2 hole on each side is to give
    better exposure to that layer, and making the hole any deeper
    is superfluous.
    The routine of drilling the hole frequently comes up with a fresh cut with
    tree stand bottom blocking flow. That's the reason for the center spike. To
    hold the tree in place, and space it above the bottom of the stand bowl.
    MC <> wrote in message
    news:Momyd.1744$...
    at
    > all ???
    > MC
    > news:08myd.80$...
    > > news:...
    tree
    > > and
    > > > doesn't need it?
    > > > Robert
    Hope
    > > it helps.
    chores,
    price.
    > > house!
    cut
    the
    spray
    > > nurseries.
    prevent
    > > evaporation.
    are
    > your
    it's
    Michael Baugh, Dec 22, 2004
    #11
  12. Finite Guy
    TURTLE Guest
    > doesn't need it?
    > Robert
    This is Turtle.
    I think Noozer got it with the flate butt of the trunk sitting flate on the
    bottom of the pan. If you restrict the veines of the truck it will not take on
    water.
    Secondly take some of this stuff call miricle grow and mix it up strongly and
    put it in the water. the tree will stay green till next Christmas.
    TURTLE
    TURTLE, Dec 23, 2004
    #12
  13. Finite Guy
    Roger Guest
    "> We cut a fress Christmas tree a couple of weeks ago at a local tree
    > doesn't need it?
    How long was it from cutting to putting into water? Two weeks? Once a tree
    is cut, it should be put into fairly deep water (I use a bucket) to start it
    drinking the day it is cut. The base should be recut another 1/2 inch or so
    to expose fresher wood, immediately upon getting the tree home, with a 1/4
    inch bevel cut around the base along the bark, using a very sharp utility
    knife, to expose phloem/xylem channels. I use a flat stone or gravel to keep
    tree base off bottom of bucket. Once tree is stored in shady cool place like
    this, it can be moved whenever you like into the house, even weeks later,in
    a bucket style tree base with righting bolts. While outside, it should be
    topped off daily. It will drink like crazy for several days, then slow down
    markedly by the end of a week, but by that time the tree will be hydrated
    and resist drying once it is inside.
    Roger, Dec 23, 2004
    #13
  14. Finite Guy
    Guest
    This does not occur very often, but there are occasionally some
    Christmas trees that are alcoholics. You will need to fill the stand
    with beer or some hard liquor such as whiskey or rum. Once the stand
    has been filled with your favorite alcoholic beverage, decorate the
    tree as usual, except it is highly recommended by "The National
    Association for Alcoholic Christmas Trees" (NAACT), that you install
    some sort of durable string or wire from the center of the trees trunk
    to a solid object, such as the wall behind the tree. The reason for
    this is because drunk trees tend to fall over easier than those that
    are on the wagon. It would be a good idea to take your tree to an
    "Alcoholics Anonymous" (AA) meeting, as soon as the holidays are over,
    so that it can recover from it's alcoholism and from all the stress of
    the holidays. On a final note, you might consider using some egg nog
    containing a large amount of rum in the stand, because that would be
    the most traditional Christmas beverage.
    "HIC"
    Merry Christmas to you, your family, and your drunk tree !!!
    Ho Ho Ho
    >doesn't need it?
    >Robert
    , Dec 23, 2004
    #14
  15. Finite Guy
    Noozer Guest
    Copper is poison to plants...
    Want to kill a tree? Drive a few pennies into it with a hammer.
    "Zemedelec" <> wrote in message
    > Try adding a few copper coins to the water ---it helps cut flowers hydrate
    > themselves. so why not a tree?
    > zemedelec
    Noozer, Dec 23, 2004
    #15
  16. Finite Guy
    gary Guest
    1/2 sprite solution with 1/2 water to keep it alive longer, if it indeed
    starts to take up water. Copper pennies???
    "Noozer" <> wrote in message
    news:FpHyd.568255$nl.525088@pd7tw3no...
    > news:...
    >> hydrate
    >> zemedelec
    gary, Dec 23, 2004
    #16
  17. Finite Guy
    gary Guest
    Use and IV?
    <> wrote in message
    >>it
    >>Pat
    > :p
    gary, Dec 23, 2004
    #17
  18. Finite Guy
    gary Guest
    Xylem and Phloem Cells, boy that takes me back..
    "MC" <> wrote in message
    news:Momyd.1744$...
    > at
    > all ???
    > MC
    > news:08myd.80$...
    >> news:...
    >> and
    >> > doesn't need it?
    >> > Robert
    >> Hope
    >> it helps.
    >> price.
    >> house!
    >> the
    >> spray
    >> nurseries.
    >> prevent
    >> evaporation.
    >> are
    > your
    >> it's
    gary, Dec 23, 2004
    #18
  19. Finite Guy
    Guest
    Just cut the bottom at a slight angle.
    , Dec 24, 2004
    #19
  20. Finite Guy
    Guest
    On Thu, 23 Dec 2004 23:04:11 GMT, "gary" <>
    wrote:
    >Use and IV?
    I don't like needles, can't you just feed them salty peanuts and
    popcorn? It works at bars to get the people drinking more.
    later and Merry Christmas All!
    ><> wrote in message
    >news:...
    >>>it
    >>>Pat
    >> :p
    tom @ www.FreelancingProjects.com
    , Dec 24, 2004
    #20
  1. David P
    71
    1,787
    Dave Plowman (News)
    May 11, 2006
  2. Gareth
    443
    ARWadworth
    Mar 10, 2008
  3. mstrspy
    ChristmasTree Won't Drink Water
    mstrspy, Dec 23, 2005, in forum: Home Repair
    436
  4. toecheese
    246
    toecheese
    Jan 30, 2008
  5. Should I drink softened water
    , Nov 20, 2010, in forum: Home Repair
    522
    Robert Neville
    Nov 21, 2010
