Charcoal smell from electric clothes dryer?
Discussion in 'Home Repair' started by Unused Classified, Nov 22, 2010.
  1. I noticed a new odd behavior from my 10 year old electric Kitchen Aid
    dryer, the clothes smell like charcoal or lighter fluid.
    I checked the lint trap and it was empty.
    Is this a symptom of some common problem?
  2. Unused Classified
    ransley Guest
    > Thanks
    Are you sure the exhaust hose isnt full if lint blocking airflow, that
    could burn out a unit, I wouldnt use it till its checked out.
    ransley, Nov 22, 2010
  3. Unused Classified
    Mikepier Guest
    > > Thanks
    Does it smell like possibly the belt is burning or rubbing against
    something?
    Mikepier, Nov 22, 2010
  4. I just cleaned out the exhaust hose, there was a very small amount of
    lint in there, not enough to cause a problem.
    The smell is really exactly like lighter fluid or charcoal.
    Thanks for the ideas.
    Name Classified, Nov 23, 2010
  5. Unused Classified
    Bob Guest
    Have you checked the air intake path across the heating coil? That's
    the most likely source if the clothes smell bad. The air goes through
    the fan and filter after it passes through the tumbler.
    Bob, Nov 23, 2010
    > Thanks
    Haven't a clue - but if you use charcoal lighter fluid when you cook
    out, you're ruining your steaks - consider one of these:
    http://www.amazon.com/Weber-7416-Ra...1?ie=UTF8&s=home-garden&qid=1290478000&sr=1-1
    Bob(but not THAT Bob), Nov 23, 2010
  7. Unused Classified
    jeff_wisnia Guest
    > Thanks
    Anybody leave a Zippo lighter in a pants pocket?
    Jeff
    Jeffry Wisnia
    (W1BSV + Brass Rat '57 EE)
    The speed of light is 1.8*10e12 furlongs per fortnight.
    jeff_wisnia, Nov 23, 2010
  8. Unused Classified
    N8N Guest
    On Nov 22, 9:07 pm, "Bob(but not THAT Bob)" <>
    > > Thanks
    > http://www.amazon.com/Weber-7416-Rapidfire-Chimney-Starter/dp/B000WEO...
    Been doing that for years... but I just take a coffee can and a bottle
    opener and make my own. No handle, keep a pair of Channellocks handy
    to remove it. If it starts falling apart, make a new one.
    nate
    N8N, Nov 23, 2010
  9. Unused Classified
    Guest
    Could be the belt from the motor to the drum is slipping. That
    normally smells like burnt rubber, but not everyone knows that odor.
    Be sure the motor itself is not coated with lint too. This may be a
    good time to open the dryer cabinet and take a vacuum cleaner to
    everything inside, check the belt, and clean out the exhaust pipes
    too. You dont want a fire, and after 10 years they do get a good
    share of lint buildup inside. Also look for any burnt looking wires
    and connections.
    , Nov 25, 2010
  1. BPO
    430
  2. BPO
    321
  3. Danny
    Electric or Charcoal Smokers?
    Danny, Jun 26, 2004, in forum: Misc DIY
    492
    Edwin Pawlowski
    Jun 27, 2004
  4. Tube Audio
    Clothes dryer burning smell
    Tube Audio, Jun 11, 2007, in forum: Home Repair
    18
    750
    Tube Audio
    Jun 12, 2007
  5. Replies:
    13
    720
    Marina
    Mar 25, 2009
