Chainsaw "Square ground cutter" sharpening?
Discussion in 'Home Repair' started by Bill, Oct 8, 2005.
  1. Bill
    Bill Guest
    Question: How do you properly sharpen a saw chain with a "square ground
    cutter"? (This is flat filed as opposed to round filed.)
    The chain with these square ground cutters is Stihl RSLFK, RSLK, or RSLHK.
    ( http://www.stihlusa.com/chainsaws/types.html )
    Do you just use a flat file and free-hand (without any guide)?
    I found some information on this at the Oregon saw-chain web site. It says;
    "Only use files specially designed for square-ground chisel cutters,
    available from your chainsaw dealer." [Double-Bevel, Hexagon, and "Goofy".]
    This was on the last page of the following link...
    http://www.oregonchain.com/tech/ms_manual/ms_06.pdf
    Anyone know where to buy these files online? Or which type of file is best
    to use?
    Comments/Opinions on saw chain which is "square ground" -vs- "round ground"?
    Bill, Oct 8, 2005
  2. Bill
    Mike Marlow Guest
    "Bill" <> wrote in message
    says;
    "Goofy".]
    > to use?
    ground"?
    Bill:
    Just based on your questions, it appears you're not terribly experienced
    with chainsaws. If I've read too much into your questions then I guess you
    can ignore everything else I have to say and accept my apologies. If
    however, you are as unfamiliar with chainsaws as your questions make it
    appear, then my immediate advice is for you not to screw around with square
    ground cutters.
    Sharpening any chain requires a certain amount of practice in order to get a
    good cutting profile. It's certainly more than just hitting the cutters a
    few licks to sharpen them up. It's not rocket science by any means, and
    anybody can certainly develop the skill to do it, but it does require an
    attention to what you're doing, and understanding of what you want to do and
    of course the most important part - a practice at achieving that desired
    goal. Square cutters are a lot harder to cut properly and offer nothing to
    the fellow who isn't cutting very large diameter trees with huge saws. You
    just can't get into wood cutting enough on a casual basis to warrant going
    to a square chain. They rely on a critical angle between the top of the
    cutter and the side and slight variations - which are easy to end up with,
    will really screw up the cut.
    Do yourself a favor and just stay with the chain your saw came with.
    -Mike-
    Mike Marlow, Oct 8, 2005
  3. Bill
    Harry K Guest
    > to use?
    Don't bother unless you are a professional. I wound up with a square
    chisel chain by accident once. Loved the way it cut. Could not file
    it by hand, dealer had no way of sharpening it. We converted it to
    round file - just use a round file and the usual angles.
    I hang out in a professional arborist/logging forum. Even the
    professionals have a very hard time learning to file square cutters.
    Angles, pressures etc. are critical.
    Harry K
    Harry K, Oct 8, 2005
  4. Thanks for the site - haven't looked - but have now - have a 192-T Pico chain.
    Just found out tonight on the page - under the model page - there is a recall.
    Safety item.
    Really nice 6.6# saw for high and light work.
    Have a 20" for the big stuff. :)
    Martin
    Martin Eastburn
    @ home at Lions' Lair with our computer lionslair at consolidated dot net
    NRA LOH, NRA Life
    NRA Second Amendment Task Force Charter Founder
    > to use?
    ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
    http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
    ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
    Martin H. Eastburn, Oct 9, 2005
  5. Bill
    Bill Guest
    The chain the saw came with *does* come (from Stihl) with square ground
    cutters. It is a Stihl "RSLFK" (full skip) chain for a Stihl MS-460 and a 32
    inch bar. This chainsaw will *only* be used for bucking large diameter logs.
    (I have a smaller chainsaw with round filed cutters which I use for the
    smaller stuff.)
    I do have experience with the round filed chains, but not with the square
    ground chains.
    I have read on the internet that a square ground chain has a bit of
    additional cutting speed, and that is important to me as the logs I am
    cutting are quite large in diameter. So worth the investment in learning how
    to sharpen the chain for square ground if it is worth it - cutting speed
    wise.
    Although the chain came with square ground cutters, I do have the option of
    filing them with a round file and no longer having square ground cutters.
    I have a friend who has been a logger for 15 years and he says he prefers
    round filed, although other loggers prefer square ground he says.
    I told him I wanted to try the square ground for awhile, then file them with
    a round file and see which I prefer. (And I should learn something in the
    process.)
    Just wanted some additional feedback on which is better and tips on
    sharpening. Also where to get the special files online if possible.
    "Mike Marlow" wrote in message
    > Bill:
    > you
    > square
    > ground cutters.
    > a
    > and
    > to
    > You
    Bill, Oct 9, 2005
  6. Years ago, I read about the difference between "chisel" and "chipper" and
    "Semichisel" chain.
    Chisel had square teeth, and chipper had rounded corners on the teeth. From
    the end, chisel chain looked like a 7, and chipper chain teeth looked more
    like a ?.
    The chisel chain was supposed to be faster cut.
    Christopher A. Young
    Do good work.
    It's longer in the short run
    but shorter in the long run.
    smaller stuff.)
    ground chains.
    wise.
    process.)
    Stormin Mormon, Oct 9, 2005
  7. Bill
    Bill Guest
    "Stormin Mormon" wrote in message
    > "Semichisel" chain.
    > From
    > like a ?.
    The cutters on my chain look like "7's". Following are all the different
    variations of saw chain you can get from Stihl...
    Pitch
    1 = 1/4"
    2 = .325"
    3 = 3/8"
    4 = .404"
    6 = PICCO (3/8" Extended)
    Gauge (on drive link)
    1 = .043" (1.1 mm)
    3 = .050" (1.3 mm)
    5 = .058" (1.5 mm)
    6 = .063" (1.6 mm)
    0 = .080" (2.0 mm) (Harvester Chain Only)
    Cutter Type
    P = PICCO
    R = RAPID
    Cutter Shape
    C = Comfort (Low Vibe Version)
    D = Duro (Carbide Tip)
    DS= Duro Special (Carbide Tip)
    M = Micro (Semi-Chisel)
    S = Super (Full Chisel)
    Special
    1 = Triple-Humped Tie Strap
    2 = Triple-Humped Tie Strap
    3 = Single-Humped Drive Link
    F = Full Skip
    H = Semi Skip
    L = Square Ground
    K = Classic Cutter design
    N = Narrow
    S = Special
    Number of Drive Links in Reels
    Type 100'
    1/4" 2400
    3/8" PMN 1640
    3/8" P 1640
    ..325" 1840
    3/8" 1640
    ..404" 1480
    Various Stihl Cutter Types...
    Stihl Saw Chain Identification...
    http://www.stihlusa.com/chainsaws/sawchain_select_id.pdf
    Bill, Oct 9, 2005
  8. Bill
    Bill Guest
    Bill, Oct 9, 2005
  9. Bill
    Harry K Guest
    Go to arborist.lawnsite.com
    That is a professional and semi professional forum although anyone is
    welcome. Search the "chainsaw" forum for filing info. You will find
    more than you really want but will find what you need. It will also
    give you on-line sources for chainsaws/tools/etc.
    Baileys.com (I think that's right) is one off the top of my head.
    Harry K
    Harry K, Oct 9, 2005
  10. Bill
    Bill Guest
    Thanks. I found what I was looking for by searching that forum. The first
    link below says...
    Q: Is a square ground chisel chain really better than a round ground chisel
    chain?
    A: Yes, if cutting performance and efficiency are what you are after. Square
    ground chisel chains perform 10% to 15% better. If maximum stay sharp
    ability and ease of filing are your objective, the answer is: no.
    Maintenance of square ground chisel saw chain...
    http://www.madsens1.com/chainmnt.htm
    Also baileys.com had a bottle of booze on it!
    Is this the site?
    http://www.baileys-online.com
    "Harry K" wrote in message
    > Harry K
    Bill, Oct 9, 2005
  11. Bill
    Harry K Guest
    Yeah, that's it. Sorry about that.
    The Arborist site is one awesome resource. I hope you sign up and
    join in some of the discussions. Asbestos pants might be required in
    some of them. You would probably enjoy looking through some of the
    archives.
    Harry K
    #11
  1. Vortex
    Chainsaw Sharpening Tools
    Vortex, Apr 10, 2005, in forum: Misc DIY
    462
    RichardS
    Apr 13, 2005
  2. Bill
    400
    Christina Peterson
    Oct 6, 2005
  3. Robert11
    380
    Robert11
    Nov 6, 2005
  4. Robert11
    16
    713
    Stormin Mormon
    Nov 9, 2005
  5. Dave Baker
    Chainsaw sharpening
    Dave Baker, Sep 1, 2013, in forum: UK DIY
    228
