Central Heating pump knocking?
Discussion in 'UK Home Improvement' started by milleniumaire@hotmail.co.uk, Nov 7, 2006.
  1. Guest
    A couple of weeks ago I refitted a radiator in our bathroom after it
    had been tiled. Coincidentally, during the back end of last week I
    noticed a knocking sound at the same time as I could hear water being
    pumped through the radiators in the house. I wasn't concerned as I
    thought maybe some air had got into the system (it is a sealed system
    with a 8 year old Saunier Duval Thelia Twin combi boiler) and I would
    go around the house and bleed all the radiators. Last night, the
    knocking became continuous and even louder and I now realise it isn't
    coming from the pipework or the radiators it is coming from the boiler
    but is being amplified through the piping so that it can be heard
    throughout the house. The noise appears to be coming from what I think
    is the pump which seems to be an integral part of the boiler.
    The noise is a regular loud knocking sound and stops when I switch of
    the boiler, but starts when either the hot water only or heating and
    hot water settings are selected. The radiators are still warming up
    and the water is still hot so everything appears to be working okay
    apart from the loud noise which is so disruptive that we had to turn
    the boiler off last night in order for us and our children to get any
    sleep.
    Our heating system is insured but an engineer won't be out to look at
    it until Thursday, and then I suspect we will have to wait another week
    while they get whatever spare part is required.
    If this is a mechanical problem with the pump is it likely to be
    dangerous to leave it on?
    Is the problem likely to be the bearings in the pump or is it possible
    that trapped air could cause this noise? I ask this as if it is a
    problem with the pump I'm surprised that the radiators all around the
    house are still hot i.e. the pump is still working.
    I would appreciate any suggestions on what the problem might be and
    anything I could do to fix it or minimise the noise before the engineer
    arrives later this week.
    Thanks.
    , Nov 7, 2006
  2. Codswallop Guest
    > sleep.
    > Thanks.
    If you put the tip of a screwdriver on the pump casing and put your ear
    against the screwdriver handle, that should confirm that the noise is coming
    from the pump. It could be worn bearings and isn't dangerous. If it is
    possible to change the speed of the pump you could try running it at a
    slower of faster setting. I doubt that air would cause loud knocking. An old
    blanket wrapped around the pump might muffle the sound if it is safe to do
    that.
    Codswallop, Nov 7, 2006
  3. Merryterry Guest
    > Thanks.
    Could be water too hot and creating steam in the pump. Have you turned
    the boiler Temp up lately? Have had this problem on my oversized boiler.
    Merryterry, Nov 7, 2006
  4. Guest
    As far as I'am aware the temperature hasn't been turned up. I have
    also tried turning down the hot water and heating temperatures but this
    makes no difference.
    When I arrived home tonight (to the constant, regular, loud knocking
    noise coming from the boiler in the garage) I noticed that all the
    downstairs radiators and pipes were cold and I immediately assumed that
    the heating was no longer working. However, upstairs all radiators
    were hot! How can this be?
    Is it possible that the knocking is being caused by a "switch" that is
    allowing hot water to the upstairs radiators, but not downstairs?
    I'm even more confused now.
    Paul.
    , Nov 7, 2006
  5. malc Guest
    > this makes no difference.
    > that the heating was no longer working. However, upstairs all
    > radiators were hot! How can this be?
    More likely it is your pump that's knackered. The reason your upstairs rads
    are heating is due to thermal syphoning.
    Malc
    "AFB Mr Tracey."
    "Underbirths are og"
    Les Barker - Irrational Neutscene
    malc, Nov 7, 2006
  1. john
    Central Heating Pump
    john, Jul 4, 2003, in forum: UK DIY
    1,024
  2. kipper
    kipper, Nov 10, 2003, in forum: UK DIY
    374
    BigWallop
    Nov 10, 2003
  3. Simon Elliott
    Knocking sound in central heating system
    Simon Elliott, Nov 23, 2005, in forum: UK DIY
    8
    1,249
    Dave Plowman (News)
    Dec 1, 2005
  4. Manf. Engnr.
    692
    Manf. Engnr.
    May 6, 2004
  5. David
    Central heating making a knocking noise
    David, Nov 10, 2003, in forum: UK Home Improvement
    1,632
    BigWallop
    Nov 11, 2003
