Cavity wall ties.
Discussion in 'Misc DIY' started by Lanky, Jul 13, 2007.
  1. Lanky
    Lanky Guest
    My Building Society is insisting that I have an expert report on the cavity wall
    ties of my 1926 three-bed semi-detached house before they OK a mortgage. Can
    anyone tell me how an 'expert' will carry out this examination and what the cost
    is likely to be?
    I had the gable-end rebuilt to correct a bulge in 1980 (presumably the ties
    would have been renewed) and had remedial ties installed in the rear wall in
    1990. The front wall with the double-bay windows was rendered in 1990, after
    removing the pebble-dashing, I'm not sure whether there are ties in that wall.
    Lanky, Jul 13, 2007
  2. Lanky
    Brian G Guest
    > cavity wall ties of my 1926 three-bed semi-detached house before they
    > OK a mortgage. Can anyone tell me how an 'expert' will carry out this
    > examination and what the cost is likely to be?
    Simply drill holes in the wall at strageic points and stick a boroscope in
    to have a look around.
    > the ties would have been renewed) and had remedial ties installed in
    > the rear wall in 1990. The front wall with the double-bay windows was
    > rendered in 1990, after removing the pebble-dashing, I'm not sure
    Gable End:
    What was the reason for the 'bulge' and was it just the outside 'skin'?
    This could possible have been caused through wall tie failure - and yes, the
    ties should have been replaced at the time of the repair.
    Rear Ties:
    Do you have any paperwork or certificates confirming this - if so then all
    should be ok there.
    Front Wall:
    Unless it is a 'solid' wall (unlikely in this case) then there will be wall
    ties present and may well need 'sorting out'
    Brian G
    Brian G, Jul 13, 2007
  3. Lanky
    Lanky Guest
    >Gable End:
    >Rear Ties:
    >should be ok there.
    >Front Wall:
    >Brian G
    Thanks Brian. The bulge was just the outside skin which the builder took down
    2/3rds of the way then rebuilt. I don't have any cert for the rear wall, apart
    from the receipt for the payment which mentions the ties together with pointing.
    In view of the front wall needing sorting perhaps a Wall Tie Report is not such
    a bad idea and I have found a website which gives details of what is involved.
    http://surveyorsreports.co.uk/wall_tie_survey_report.htm
    Thanks again.
    Lanky, Jul 13, 2007
  1. Steve
    Deteriation of cavity wall ties
    Steve, Nov 25, 2006, in forum: Misc DIY
    22
    1,390
    Bob Mannix
    Nov 28, 2006
  2. sm_jamieson
    wall ties for cavity against existing wall
    sm_jamieson, Sep 11, 2008, in forum: Misc DIY
    758
    Phil L
    Sep 11, 2008
  3. Replies:
    1,778
  4. D.M. Procida
    Cavity wall ties and insulation
    D.M. Procida, Jan 2, 2009, in forum: Misc DIY
    656
    Phil L
    Jan 2, 2009
  5. Replies:
    1,597
    Tim S
    Apr 25, 2009
