Carrier Weathermaker 8000 furnace
Discussion in 'Home Repair' started by Tony Hwang, Aug 27, 2005.
  1. Tony Hwang
    Tony Hwang Guest
    ~10 year old furnace started intermittent lock up with error code 31.
    Careful investigation revealed intermittent inducer motor. It starts
    but stops running or it won't start when heat is called for.
    Took the control board out(HK42FZ004) and went through it. The problem
    found was cracked solder joint on two high Wattage resistors R34 and R33
    (both 330 Ohms) had cracked solder joints on the PCB due to heat(?).
    Reinforced the joints with silver solder. Now furnace is behaving normal
    again. Google search showed it is known problem mentioned in service
    bulletin. Going price for replacement board is ~200.00.
    Hope this may be of some help for someone who has same furnace type.
    (Carrier, Bryant, Payne brand uses same board I believe).
    Tony
  2. Tony Hwang
    Tony Hwang Guest
    Tony Hwang wrote:
    > Hi,
    > Tony
    BTW, the original board is obsolete. Replacement board conversion kit if
    needed with wiring harness has p/n: 325878-751
  3. "Tony Hwang" <> wrote in message
    news:Gq1Qe.320054$s54.70742@pd7tw2no...
    > Tony Hwang wrote:
    >> Hi,
    >> Tony
    And can be bought by any legitimate tech for under $50.....
    Carolina Breeze HVAC, Aug 30, 2005
  1. MikeE
    510
    American Mechanical
    Aug 21, 2004
  2. Proteus
    10
    518
    Denise Baker
    Aug 23, 2004
  3. Carrier Weathermaker - no heat
    , Feb 19, 2007, in forum: Home Repair
    677
  4. Proteus
    17
    512
  5. Mike
    Carrier WeatherMaker 8000
    Mike, Sep 17, 2004, in forum: HVAC
    887
    Stormin Mormon
    Sep 18, 2004
