Carrier Weathermaker 2900: PCB problem?
Discussion in 'Home Repair' started by MikeE, Aug 20, 2004.
  1. MikeE
    MikeE Guest
    Hi ppl.
    Carrier Weathermaker 2900. Approx 4 years old.
    I noticed the blower wasn't working when thermostat kicked in. Went to
    basement, opened machine. things appear fine, but per service-sheet there is
    no light coming from LED.
    Tested with VMeter for ~110 at L1/L2 and 24 VAC at S1 S2. All checks out.
    (although the xformer seems to buzz slightly, but I guess that could be
    normal.)
    Fuse looks good 2. Even with service-switch closed, I can't get LED to come
    on. (although it did come on once for me, but I can't seem to repeat that...
    strange fluke.)
    anyway... does it appear that I have to go spend $200 on a new "hk32fz011
    PCB for this unit?... grrrr.. way 2 much $$ for that part....
    Does anyone know of any component-level issues that can cause this sort of
    failure... as I would prefer to replace that part obviously...
    (althogh if the DIAG-piece is busted, it could be the main ICs that are
    fried, and thats the end of that...)
    Is the PCB the problem for sure? (obviously I don't want to spend $200 on a
    part that isn't the problem...)
    [ should I pull*all* the wires OFF and try to run it with just the
    power-feed attached to trully isolate the problem, or is that not worth
    it. ]
    Any assistance/insight for a HVAC newbie would be much appreciated.
    thanks -- MikeE
    MikeE, Aug 20, 2004
  2. "MikeE" <> wrote in message
    news:eek:...
    > Hi ppl.
    is
    > normal.)
    come
    that...
    > strange fluke.)
    ? That's pretty cheap. I would have a more experienced diagnosos before I
    started throwing parts at it though.
    Doubtful.
    a
    > it. ]
    It wouldn't be worth it.
    Get the opinion of someone, i.e a contractor, so you can be sure that the
    part you're testing is in fact the problem. It's just too hard to guess
    over the internet.
    - Robert
    > thanks -- MikeE
    American Mechanical, Aug 21, 2004
  1. Proteus
    10
    488
    Denise Baker
    Aug 23, 2004
  2. Tony Hwang
    Carrier Weathermaker 8000 furnace
    Tony Hwang, Aug 27, 2005, in forum: Home Repair
    870
    Carolina Breeze HVAC
    Aug 30, 2005
  3. Carrier Weathermaker - no heat
    , Feb 19, 2007, in forum: Home Repair
    633
  4. Replies:
    558
  5. Proteus
    17
    469
Share This Page
