can I apply exterior semi gloss directly over flat exterior paint?
Discussion in 'Misc DIY' started by Bruce Millar, Apr 13, 2004.
  1. Bruce Millar
    Bruce Millar Guest
    About 6 months ago I hired a painting contractor to paint a rental
    property that I own. The building was painted with white flat latex,
    sprayed on. It was a "budget" job, which I am now regreting, as all
    of the dust, pollen, etc. sticks right to the paint. The paint was
    also put on too thin for my liking.
    My question - Can I apply a quality semi-gloss exterior latex directly
    on top of the flat latex without priming? The flat latex has a
    surface that looks and feels (to me, a non-painter) just about like a
    primer. Opinions?
  2. Bruce Millar
    m Ransley Guest
    Re: can I apply exterior semi gloss directly over flat exteriorpaint?
    Go right over it , no primer necessary.
    m Ransley, Apr 13, 2004
  3. Bruce Millar
    davefr Guest
    There's a saying that nothing sticks to latex like more latex.
    But having said that, you can run into problems if the base coat is a
    real low end/non acrylic latex.
    You'll probably want 2 coats anyway so I'd make the firt one a primer
    coat tinted to half the color formula of the topcoat and then you can
    probably get by with one topcoat assuming you use quality paint.
    I prefer Pratt and Lambert Suprime for the primer and Accolade for the
    topcoat. Make sure you start by preparing the walls by washing with a
    TSP solution and rinse.
    (Bruce Millar) wrote in message news:<>...
    > primer. Opinions?
    davefr, Apr 13, 2004
  4. Bruce Millar
    jeffc Guest
    "Bruce Millar" <> wrote in message
    > primer. Opinions?
    Paint is fine, dirt is not. Powerwash it first, and remove any peeling
    paint obviously. Otherwise, flat paint essentially is primer (although it's
    not stain blocking of course.)
    jeffc, Apr 14, 2004
  5. Bruce Millar
    jeffc Guest
    "davefr" <> wrote in message
    I have never understood this advice. Just use the exact same color.
    jeffc, Apr 14, 2004
  6. Bruce Millar
    jeffc Guest
    "NorMinn" <> wrote in message
    > Tint the primer so if coverage is not totally opaque there is less
    > contrast with the top coat. Primer can't be tinted as much as cover
    > coats or it reduces the primer adhesion/sealing qualities, according to
    > my favorite paint store salesman.
    Well I suppose if you're painting your walls red, it might be a problem.
    Otherwise, just use the exact same good quality paint you're going to use
    anyway (unless you need stain blocking or something, of course.)
    jeffc, Apr 14, 2004
  1. Tom
    aluminum siding flat or semi-gloss
    Tom, Jul 20, 2003, in forum: Home Repair
    mark Ransley
    Jul 21, 2003
  2. squeaky88th
    Interior Painting: flat over semi-gloss
    squeaky88th, Feb 2, 2004, in forum: Misc DIY
    406
    George E. Cawthon
    Feb 3, 2004
  3. Replies:
    412
  4. milo
    8
    1,054
  5. Tube Audio
    479
    dadiOH
    Oct 15, 2007
