Border necessary for paving stones?
Discussion in 'Home Repair' started by Bill Stock, May 6, 2007.
  1. Bill Stock
    Bill Stock Guest
    I'm installing a shed on some 2x2 patio stones in an 8x10 rectangle. The
    ground is not level, being about 4+ inches higher on one side than the
    other. I plan to put about 5" on 3/4 gravel and 2" of Limestone screenings
    under the patio stones to help with drainage/heaving. But I'm wondering how
    much the gravel might migrate if I don't put a border (PT lumber) around the
    outside? I did something similar a few years ago with some penny pavers and
    marble chips (same gravel base) and I used a PT border to keep the chips in
    place. It worked out well then, but I hadn't really planned to go to the
    trouble this time. Although with my slope it might be a good idea.
    Any preferences?
  2. Roger
    Roger Guest
    Yes, a border board will keep the ballast in place, especially with the
    slope, and help stabilize the edging 2x2 stones.
    I like to use Bend-A-Board, a reddish recycled plastic product, and be sure
    to use bendaboard stakes, too. Neither will rot, and will saw, bend, and
    screw with no splitting. Usually I use the 1x6 boards, 20 feet long. They
    also come in 1x4, 2x4, and other sizes. I place the border so it is just
    short of flush with the final stone surface, so the border board basically
    disappears, as it should, as it is a below-grade product.
    Roger
    "Bill Stock" <> wrote in message
    > how much the gravel might migrate if I don't put a border (PT lumber)
    > around the outside? I did something similar a few years ago with some
    > penny pavers and marble chips (same gravel base) and I used a PT border to
    > keep the chips in place. It worked out well then, but I hadn't really
    > planned to go to the trouble this time. Although with my slope it might be
    > a good idea.
    > Any preferences?
    Roger, May 6, 2007
  1. jeffc
    235
  2. bdeditch
    laying paving stones 12" X 12" ?
    bdeditch, Apr 6, 2007, in forum: Home Repair
    10
    438
    Edwin Pawlowski
    Apr 7, 2007
  3. bdeditch
    bdeditch, Apr 6, 2007, in forum: Building Construction
    360
    bdeditch
    Apr 9, 2007
  4. ARWadsworth
    13
    458
    ARWadsworth
    Sep 25, 2011
  5. Chuck Banshee
    51
    949
    Chuck Banshee
    Jan 26, 2012
