Boiler diverter valve
Discussion in 'UK DIY' started by Ian Nutt, Nov 8, 2003.
  1. Ian Nutt
    Ian Nutt Guest
    I have a Vaillant combi boiler and seem to have a problem with the
    diverter valve. The hot water only comes on when the heating is on. I
    have taken the diverter valve out of the boiler to study it and can
    see that the diaphram is supposed to push up a pin that forces a
    hammer to fall and make a contact that ignites the burner and diverts
    water into the hot tap system.
    When I turn the hot water tap on you can see the hammer try to move
    down to make the switch contact, but it does not have the energy. It
    would seem that there is not enough pressure to push it hard enough.
    Does anyone out there understand what i'm talking about, or, even
    better, know what the problem might be?
    Kind regards.
  2. Ian Nutt
    Ed Sirett Guest
    Which model? They work by very different mechanisms.
    Ed Sirett, Nov 8, 2003
  3. Ian Nutt
    Ian Nutt Guest
    "Ed Sirett" <> wrote in message news:<>...
    Ed - thanks for getting back. I don't know! Cannot see a model number
    written anywhere and have no documents on it. Do you know how I can
    identify it?
    Cheers.
    Ian Nutt, Nov 9, 2003
  4. Ian Nutt
    Ed Sirett Guest
    > identify it?
    Please describe the general appearance - eg. grey/black/beige control
    panel. Permanent pilot or electronic ignition? Fan assisted flue or
    balanced natural draught flue?
    Anyway from the description is it most likely a split diaphragm in the
    water flow sensor.
    If you look around and perhaps remove or swing-down a panel you will
    likely find the model type and rating plate.
    Ed Sirett, Nov 9, 2003
  5. Ian Nutt
    Ian Nutt Guest
    > > identify it?
    > water flow sensor.
    Ed,
    I have taken the right hand side panel off and there is no
    identification plate visible anywhere, just various stickers with
    nothing that looks like a serial number. The pump has 'Type VP5'
    written on it, but I assume this refers to the pump.
    The control panel is black, with green dials and a pressure gauge
    bottom right. There are 4 dials (on/off/relight, water temp, ch temp,
    function setting) and 7 indicator lights that light up green to
    indicate when the burner is on etc. It is electronic ignition and
    naturally vented flued I think.
    I took the brass diverter valve out over the weekend and took it
    apart. There was a water chamber above and below the rubber diaphragm,
    and the diaphragm didn't look out of shape. There is a pin attached to
    a plate which is supposed to push up when the pressure of the mains
    water is released. I made sure it was loose enough, and refitted it.
    It didnt do any good - when the hot water tap is turned on you can see
    the hammer try to fall to make the electrnic circuit that will ignite
    the boiler, but it is obvious that the pin inside is not moving up far
    enough to push this little white plaster hammer down to make the
    circuit.
    Does this sound familiar?
    Ian Nutt, Nov 10, 2003
  6. Ian Nutt
    Ed Sirett Guest
    >> > identify it?
    >> water flow sensor.
    > Ed,
    Aha we have a vaillant VUW this is the model comes between the VCW and the
    latest Turbomax+ series. It is forced flue with a fan. IIRC.
    In this model the DHW is fired from the microswitch mounted on the
    right hand side of the diverter valve/flow valve.
    The water flow diaphragm operates directly on the diverter valve and the
    microswitch.
    You could have a problem if the diverter valve is stuck/sticky.
    Ed Sirett, Nov 10, 2003
  7. Ian Nutt
    Ian Nutt Guest
    > >> > identify it?
    > >> water flow sensor.
    > > Ed,
    > microswitch.
    Exactly right! The microswitch is a tiny fellow which makes the
    circuit when this white plastic hammer I keep mentioning pushes down
    on it.
    How do I ensure the diverter valve isn't sticky? Any tips?
    Thanks again for your continuing attention.
    Ian Nutt, Nov 11, 2003
  8. Ian Nutt
    Ed Sirett Guest
    >> >> > identify it?
    >> >> water flow sensor.
    >> > Ed,
    >> microswitch.
    > on it.
    There may be an inadequate flow of water to correctly operate the valve.
    There may be a split diaphragm in the valve.
    The diverter valve might be too stiff to move easily enough:
    i) failed lubrication
    ii) sludge etc. in pirmary
    iii) mechanical failure (unlikely)
    The micro switch could be iffy - not enough to show when you operate it
    with a finger but enough when operated by the valves.
    Ed Sirett, Nov 12, 2003
  9. Ian Nutt
    Ian Nutt Guest
    > >> >> > identify it?
    > >> >> water flow sensor.
    > >> > Ed,
    > >> microswitch.
    > > on it.
    I have bought a new diaphragm and will fit that on Saturday - ill let you know!
    Ian Nutt, Nov 13, 2003
  1. Clive Long,UK
    NO HW NO CH, Honeywell diverter valve
    Clive Long,UK, Oct 5, 2003, in forum: UK DIY
    1,012
    Clive Long,UK
    Oct 7, 2003
  2. Lee Blaver
    Vaillant diverter valve
    Lee Blaver, Dec 11, 2003, in forum: UK DIY
    800
    Lee Blaver
    Dec 12, 2003
  3. alspix
    1,334
  4. aboleth
    Vaillant boiler - diverter valve?
    aboleth, Aug 6, 2006, in forum: UK DIY
    16
    1,182
    aboleth
    Sep 14, 2006
  5. Replies:
    882
