blue flame vs. infrared Backup Propane Heater
Discussion in 'Home Repair' started by crazysounds, Oct 23, 2004.
  1. crazysounds
    crazysounds Guest
    Does anyone know the major differences between the blue flame vs. infrared
    propane heaters. I know that with the blue flame you can see the flame and
    the infrared uses a ceramic block that heats up. Which one is better and
    why?
  2. "crazysounds" <> wrote in message
    news:umued.50766$...
    > Hi,
    > and
    > why?
    Infrared heaters heat objects, not the air. If you are in direct line of
    sight, you will feel the warmth immediately. They are quiet, very
    efficient. Think of radiation of heat from the sun. You feel in more in the
    open than you do standing in the shade, so do the objects the heater is
    aiming at.
    Flame heaters often can circulate air more if there is a booster fan. They
    can warm a larger area faster but at the sacrifice of the "line of sight".
    Edwin Pawlowski, Oct 23, 2004
  3. crazysounds
    crazysounds Guest
    I don't have experience with either one. I want a propane heater for my
    livingroom. The heater would supplement my oil fired furnace. I want
    something that would allow me to keep the house warm if there was an
    electricity outage. My livingroom is about 20 a 15 feet. Which type of
    propane heater would you suggest?
    "Edwin Pawlowski" <> wrote in message
    news:Yrved.22934$...
    > > Hi,
    infrared
    > > and
    and
    > > why?
    the
    > aiming at.
    They
    crazysounds, Oct 24, 2004
  4. "crazysounds" <> wrote in message
    news:%QNed.64978$...
    I'd look at something like this.
    http://www.vermontcastings.com/about/products/productdetails.php?id=161
    Visit your propane dealer and they may have some suggestions about
    installation and the best type of stove for your setup.
    Ed
    http://pages.cthome.net/edhome
    Edwin Pawlowski, Oct 24, 2004
  5. crazysounds
    modervador Guest
    "Edwin Pawlowski" <> wrote in message news:<Yrved.22934$>...
    > > Hi,
    > > and
    > > why?
    > aiming at.
    BTU's are what does the heating, BTU's/hour is how fast the heating
    occurs, and a BTU/hr is a BTU/hr. So for a given BTU/hr heater, the
    "area" is being heated at the same given rate. The rest can come down
    to perception.
    I guess it may depend on what you mean by "a larger area." Do you mean
    just the air, or all the other objects in the room?
    With the ceramic brick heater, the closer objects in the line-of-sight
    do indeed warm up faster than the air on the other side the room, but
    you feel the heat radiating from these warm objects and the air near
    them is also warmed by conduction, which could feel nice. A
    circulating fan can get that heated air moving to other parts of the
    room same as for the blue flame heater, by the way.
    With the flame heater, the air gets warm first which may feel nice,
    but the air near to objects in the room will feel cold anyway because
    the objects absorb heat from the air as well as absorbing heat that
    you radiate, while not radiating heat back at you. So your perception
    of warmth is decreased by the chill that seems to come from the
    objects in the room.
    So assume you come into a cold room and flip on the heater. One of
    them will feel warm wherever red light from the heater falls but
    farther away it can still feel cold for a while. With the other, you
    feel sort of a warm breeze but everything else about the room seems
    cold for a while. After the room has been warmed for a few hours, the
    differences are less noticeable, because the air and the objects reach
    a more even temperature.
    So it depends a bit on where you will put the heater relative to where
    you will be in the room, what you prefer in terms of feeling warm in
    the early stages of the warmup, and how long the heater will be on.
    %mod%
    modervador, Oct 24, 2004
  6. "modervador" <> wrote in message
    The radiant heater is a better choice if the work areas is say, 5 x 5 but
    the room is 50 x 50. You feel warmer as long as you are in sight of the
    heater. A bunch of people spread out over the entire area, to reach a fast
    level of comfort, will need a few radient heaters or one larger one that
    heats the air first.
    You did a better job of explaining it.
    Ed
  1. Chris
    957
    John McGaw
    Dec 5, 2003
  2. Chris
    444
    CBHvac
    Dec 7, 2003
  3. Rick Blaine
    Propane Grill Infrared Burner Question
    Rick Blaine, Oct 13, 2007, in forum: Home Repair
    14
    1,067
    Rick Blaine
    Oct 28, 2007
  4. HVAC Guy
    15
    1,366
    HVAC Guy
    Nov 8, 2007
  5. GreenXenon
    Stormin Mormon
    Jan 24, 2011
