Beckett CB151UL Condensate Pump
Discussion in 'HVAC' started by jsforks@gmail.com, Jul 1, 2008.
  1. Guest
    I am trying to trouble shoot a Beckett CB151UL condensate pump. I
    found a pool of water next to my furnace and I suspect it is from the
    condensate pump. The water level in the reservoir was fairly high,
    close to the brim.
    I do not have experience working with pumps but while the pump was on
    I removed the clip connecting the hose and there was enough pressure
    for the water to shoot out like a fountain. I was able to put the
    tube back and the duckbill value correctly.
    I have turned off my AC, and manually poured water into the
    reservoir. This started the pump but I don't see it pumping the water
    out (I did see it pumping water out before I removed the tube).
    I would appreciate if someone can help explain the puddle of water and
    why I the pump is not pumping water out of the reservoir? Also, is
    there a owner's manual/troubleshooting manual I can locate online?
    What other checks can I do?
    Thanks.
    , Jul 1, 2008
  2. Mark Guest
    is the hose clogged?
    Mark, Jul 1, 2008
  3. Guest
    Mark,
    I don't think the hose is clogged, but I'll take a look at the portion
    which goes into the crawl space to verify the hose is ok down there.
    The water level in the output hose rises a little bit but I don't see
    it being pumped out. Its as though the pump is not pumping the water
    out even though I can hear the pump running. I did not want to
    unscrew the pump and disconnect the hose. But it seems that might be
    the next step.
    Thanks for providing guidance.
    > > reservoir. �This started the pump but I don't see it pumping thewater
    , Jul 1, 2008
  4. KJPRO Guest
    <> wrote in message
    > Hi,
    > close to the brim.
    > Thanks.
    I would suggest that you call a HVAC company, if you can't troubleshoot a
    simple pump without making the situation worst.
    KJPRO, Jul 1, 2008
  5. ftwhd Guest
    On Mon, 30 Jun 2008 22:56:51 -0700 (PDT), wrote:
    >Hi,
    >close to the brim.
    >Thanks.
    You should check your head for a brain...
    ftwhd, Jul 1, 2008
  6. essenz Guest
    Open up the pump, inside will be a brass tube that goes down toward
    the bottom. At the bottom it flares out. That wide section is where
    the impeller is. The bottom portion below the impeller is usually
    connected to the main body with 6 or so bolts and a gasket.
    Note: On the newer pumps, everything is plastic, but if you have one
    of the older pumps that still has brass... see below.
    Over time the bolts rust and fall off, or the gasket falls apart. The
    perimeter that the gasket seals must be 100% sealed, if not the
    impeller can't pump water as good, and what happens is the pump just
    runs forever, and it can't get enough lift pressure, then the motor
    overheats and the unit shuts off, it fills with water, etc.,.
    Its actually easy to repair, but to be honest, I would buy a newer
    plastic one. A new 460V becket condensate pump is like $380, less for
    230/208V.
    -John
    On Jul 1, 1:56 am, wrote:
    > Hi,
    > close to the brim.
    > Thanks.
    essenz, Jul 2, 2008
  7. KJPRO Guest
    "essenz" <> wrote in message
    > 230/208V.
    That's nice, but the "Beckett CB151UL condensate pump" is a 120 V model.
    KJPRO, Jul 2, 2008
  8. Sounds like your tube is clogged. Replace tube. Regrets, I've got gmail
    users blocked, so saw your question through someone else.
    Christopher A. Young
    Learn more about Jesus
    www.lds.org
    "ai" <> wrote in message
    news:w21hk.518$...
    ai had written this in response to
    http://www.thestuccocompany.com/hvac/Beckett-CB151UL-Condensate-Pump-33417-.htm
    Good morning.
    It is a shame when home owners look to the web for some basic info re:
    CB151, and those in the know can only be sarcastic. Once you've
    disconnected the pump and taken it apart, try flushing the chamber with a
    mixture of vinegar and water. Aggitate left and right, trying not to wet
    the electronics. Rinse. If this doesn't take care of it as it did for me,
    then you have to look into replacing seal.
    At any point, if you have no luck, look into calling for help.
    I don't think the members here are looking to help, only to chastise you
    for not hiring one of their kind.
    The days of helping an inquiring homeowner died on the prairie.
    wrote:
    > Hi,
    > close to the brim.
    > Thanks.
    Delivered via http://www.thestuccocompany.com/
    Building Construction and Maintenance Forum
    Web and RSS access to your favorite newsgroup -
    alt.hvac - 25054 messages and counting!
    Stormin Mormon, Jul 22, 2008
  9. KJPRO Guest
    news:w21hk.518$...
    > Good morning.
    > wrote:
    God forbid him to replace a $40 pump...
    Geez...
    KJPRO, Jul 22, 2008
  1. frank1492
    Beckett Oil Burner Shuts Off After 10 secs.
    frank1492, Oct 16, 2005, in forum: Home Repair
    1,249
    HeatMan
    Oct 20, 2005
  2. Edwin Pawlowski
    Beckett Heat Manger Any experiences?
    Edwin Pawlowski, Feb 5, 2006, in forum: Home Repair
    449
    Edwin Pawlowski
    Feb 5, 2006
  3. Warren
    409
    Paul M. Eldridge
    Sep 23, 2006
  4. homeguy
    383
    Speedy Jim
    Feb 11, 2007
  5. traderfjp
    Set Screw In Beckett Pump?
    traderfjp, Feb 11, 2007, in forum: HVAC
    44
    741
    DIMwit
    Feb 16, 2007
