bathroom lighting - IP65? IP44? IP20?
Discussion in 'Misc DIY' started by rob c, Sep 28, 2003.
  1. rob c
    rob c Guest
    hi,
    I want to install recessed halogen lights in the bathroom, and I gather
    I need to use IP rated lamps in this location.
    Packaging in B&Q suggest there are 3 zones in the bathroom, but does not
    mention IP ratings, so are these correct?:
    - zone 1: directly above bath or shower (IP65?)
    - zone 2: within 0.6m laterally of shower or bath, or 0.6m any direction
    other wet areas (IP44?)
    - zone 3: other areas (IP20?)
    They only seem to sell zone 3 fittings. I picked up a jcc lighting
    catalogue from a local electrical trade shop, they have some of all 3
    ratings though the IP44s look a bit ugly, with a thick glass dome:
    http://www.jcc-lighting.co.uk/Catalogue/ProductDetail.asp?JccID=150&JccCode=JC3006
    The IP65 looks like it might be nicer:
    http://www.jcc-lighting.co.uk/Catalogue/ProductDetail.asp?JccID=155&JccCode=JC3007
    The room is 2.4m by 3.7m. I was thinking of 6 lamps, maybe 35W each: 1
    over shower & 2 over bath (IP65?), one would be within .6m of the shower
    (IP44?) and 2 near sink & loo (IP20?)
    Does this seem OK?
    I also thought I saw somewhere that IP65s should be 30mA RCD protected.
    True? If so, would it be OK to put an RCD in the upstairs lighting
    circuit outside the bathroom - it's the last room in the circuit, and a
    shaver socket is the only other connection. Other option would be using
    protected slot in fusebox for whole circuit, but I gather lighting
    circuits aren't usually protected.
    thanks.
    rob c, Sep 28, 2003
  2. rob c
    rob c Guest
    also, what should be done above the lamps? do they need a cut out in the
    loft insulation do prevent overheating?
    rob c wrote:
    > hi,
    > Does this seem OK?
    > thanks.
    rob c, Sep 28, 2003
  1. Ian Clarke
    Halogen Lighting in Bathroom
    Ian Clarke, Jul 30, 2003, in forum: Misc DIY
    15
    650
    Andy Wade
    Aug 1, 2003
  2. sukh
    484
  3. John Smith
    IP44 & IP65
    John Smith, Jul 22, 2004, in forum: UK DIY
    1,305
    Tim Mitchell
    Jul 22, 2004
  4. Replies:
    582
  5. Mike H
    Outside lights - IP44 or IP45
    Mike H, Sep 29, 2008, in forum: Misc DIY
    735
    Barry Smith
    Dec 2, 2008
Share This Page
