bamboo florring and concrete subfloor
Discussion in 'Misc DIY' started by chris, Oct 18, 2007.
  1. chris
    chris Guest
    I'm really attracted to bamboo flooring for my dining room/kitchen
    area. Can it be successfully laid over a concrete floor? I hear
    conflicting advice. One said that it must be glued to the floor, but
    there's no guarantee that it won't move. A search of message boards
    suggests that it's probably ok. Grateful for any advice!
    Chris
    chris, Oct 18, 2007
  2. chris
    Oren Guest
    On Thu, 18 Oct 2007 13:08:09 -0700, chris <>
    >Thanks
    >Chris
    Got a link for the material? Some flooring types need to expand and
    contract. Some need a _quality_ glue. Both can be bamboo, I suppose.
    Oren
    ...through the use of electrical or duct tape, achieve the configuration in the photo..
    Oren, Oct 18, 2007
  3. chris
    dpb Guest
    Instead of message boards and usenet, I've a novel thought.
    Go to the site(s) of the manufacturer(s) of the product(s) you're
    interested in and get the skinny on installation from those who are in
    position to know.
    dpb, Oct 19, 2007
  4. chris
    Oren Guest
    On Thu, 18 Oct 2007 18:54:31 -0500, "HeyBub" <>
    wrote:
    >Wooden flooring is generally glued to some sort of cushion and the cushion
    >is glued to the subfloor. If the wood is glued directly to concrete,
    >something's gotta give as the humidity changes. I've heard a wooden floor
    >may expand as much as 1/2" inch as the humidity goes from 30% to 60%.
    Some quality glues have a moisture inhibitor/blocker.
    Oren
    "I wouldn't even be here if my support group hadn't beaten me up."
    Oren, Oct 19, 2007
  5. chris
    Jeff Guest
    Over concrete a floating floor installation is usually recommended over a
    moisture barier layer. You can get click-together bamaboo which is a
    floating installation. This example is from a Canadian distributer..
    http://www.costco.ca/Browse/Product..._Price|1||P_SignDesc1&lang=en-CA&Sp=C&topnav=
    "chris" <> wrote in message
    > Thanks
    > Chris
    Jeff, Oct 19, 2007
  1. John
    Laminate florring quote
    John, Jun 2, 2005, in forum: UK DIY
    277
    WoodYouLike
    Jun 5, 2005
  2. traderfjp
    814
    miamicuse
    Jul 18, 2005
  3. tim
    Bathroom laminate florring
    tim, Oct 16, 2005, in forum: UK Home Improvement
    337
    Bob Watkinson
    Oct 17, 2005
  4. drew
    568
  5. LizardEye
    Installing Bamboo flooring on a concrete slab
    LizardEye, Oct 20, 2003, in forum: Building Construction
    347
    LizardEye
    Oct 20, 2003
