Ariston Microgenus 23 combi boiler
Discussion in 'UK DIY' started by Lawrence Raybould, Jan 6, 2004.
  1. Ariston Microgenus 23 combi boiler
    My boiler recently developed a fault where I had central heating but
    no domestic hot water (stone cold). I was advised to fit a new
    diverter valve which I did.
    The problem I have now is that I still have central heating but the
    domestic hot water only runs hot for 2 to 3 minutes then runs luke
    warm although the boiler is still fired up.
    Does anyone have any suggestions what is causing this to happen?
  2. Lawrence Raybould
    BillR Guest
    Flow switch?
    BillR, Jan 6, 2004
  3. Lawrence Raybould
    Ed Sirett Guest
    1) Temperature sensor(s) out of spec?
    2) Diverter valve letting primary water to CH during DHW mode.
    I'm fairly sure this boiler does not have any sort of thermal store but
    otherwise the behaviour is exactly as it would be if it had.
    Ed Sirett, Jan 6, 2004
  4. Lawrence Raybould
    IMM Guest
    "Ed Sirett" <> wrote in message
    news:p...
    It has an electric diverter valve. It has a flow switch which detects flow
    and energises the diverter valve. Had the valve actually gone? The
    actuator can be changed, rather than the whole valve inc water section.
    Version: 6.0.555 / Virus Database: 347 - Release Date: 23/12/2003
    IMM, Jan 7, 2004
  1. Sharma
    802
    geoff
    Jul 15, 2003
  2. Replies:
    1,290
    Ed Sirett
    Mar 12, 2005
  3. Chris Tomlinson
    Ariston microGENUS HE combi-boiler any good?
    Chris Tomlinson, Aug 2, 2006, in forum: UK DIY
    51
    1,605
    Doctor Drivel
    Aug 5, 2006
  4. Replies:
    1,172
  5. Replies:
    340
    Ed Sirett
    Nov 27, 2006
