Anything better than DECT...
Discussion in 'UK DIY' started by TonyK, Feb 6, 2005.
  1. TonyK
    TonyK Guest
    I live/work in a very large old Victorian mansion, i.e. lots of very thick
    stone walls, four floors etc etc. I have three DECT phones, two at one end
    and one at the other. they vary in cost from the cheapest, BT at about £75 &
    £100 to my own Samsung which was originally about £200 albeit a couple of
    years back.
    Now in theory DECT is DECT and they should have an optimum range of 300m
    (yeah right!). The cheapest struggles to go 15m between 3 rooms. The middle
    one is a bit better, and the Samsung better still. But none of them will do
    the 50m between reception and office. When I bought them I tried numerous
    models and these we're the best at the time but that was 2 years back.
    I did look at repeaters but each phone is actually on a different line so I
    think its getting a bit too complicated to extend the signal?
    Has the technology improved or is there something better out there?
    Ta
    TonyK, Feb 6, 2005
  2. "TonyK" <> wrote in message
    > years back.
    > middle
    > do
    > I
    There are super power phones out there, but they are illegal here. I
    searched for high power dect or something similar , and found something that
    would get through thirty floors IIRC, whether it would work on our phone
    system I don't know, or fry your brain on a quick call. I opted for two
    carefully placed repeaters on only one line though.
    mrcheerful
    mrcheerful , Feb 6, 2005
    > years back.
    > Ta
    Yes. Cat 5 cable and a small PABX.
    The Natural Philosopher, Feb 6, 2005
  4. TonyK
    TonyK Guest
    "The Natural Philosopher" <> wrote in message
    thick
    end
    £75 &
    of
    > > years back.
    middle
    do
    numerous
    so I
    > > Ta
    You mean fixed points around the building? I need portable handsets.
    TonyK, Feb 6, 2005
  5. TonyK
    Lurch Guest
    On Sun, 6 Feb 2005 08:05:03 -0000, "TonyK" <>
    strung together this:
    DECT repeaters. Not sure what's available for domestic GAP usage, I've
    only used them on PABX's with cell stations but the idea is that you
    have one base station with DECT repeaters around the property that
    boost that single base stations signal.
    Similar in operation to mobile phone and television transmission
    techniques.
    SJW
    Please reply to group or use 'usenet' in email subject
    Lurch, Feb 6, 2005
  6. In article <>,
    > middle one is a bit better, and the Samsung better still. But none of
    > them will do the 50m between reception and office. When I bought them I
    > tried numerous models and these we're the best at the time but that was
    > 2 years back.
    Think you're unlucky, or have unusual local circumstances. I've got two -
    with one base station at the top of the three story Victorian pile, and
    one on the ground floor. Both cover the entire house and garden fine. Even
    the old analogue cordless in the workshop does too.
    *Learn from your parents' mistakes - use birth control.
    Dave Plowman London SW
    Dave Plowman (News), Feb 6, 2005
  7. TonyK
    Mike Guest
    > years back.
    middle
    do
    I
    Alcatel Spain make high power ones for the South American market where DECT
    is used instead of wires to connect to all the houses in small villages.
    They even do special base stations. Not legal here and not sure where you
    would buy one anyway.
    Mike, Feb 6, 2005
  8. TonyK
    Lurch Guest
    On Sun, 6 Feb 2005 20:31:12 -0000, "Mike" <> strung
    together this:
    Sounds like good advice so far.
    >Not legal here
    Ah, perhaps it's not very good advice at all then.
    Er, I'd guess Spain, or somewhere in South America?
    SJW
    Lurch, Feb 6, 2005
  9. TonyK
    Mike Guest
    "Lurch" <> wrote in message
    news:p...
    > together this:
    DECT
    > >Not legal here
    Well we all break the law now and then, especially ones like Part P.
    These units have variable power so I don't think using them would cause a
    problem noticed by others.
    > >and not sure where you would buy one anyway.
    Probably :)
    Mike, Feb 6, 2005
  10. TonyK
    Lurch Guest
    On Sun, 6 Feb 2005 21:47:15 -0000, "Mike" <> strung
    together this:
    I thought that, I'd probably go with the repeaters myself. The
    advantage of the repeaters is that they will also give you a constant
    signal over a wide area as opposed to a huge signal at the base and a
    not quite so huge signal proportionate to how far away you are.
    SJW
    Lurch, Feb 6, 2005
    > news:...
    > thick
    > end
    > £75 &
    > of
    >>>years back.
    > middle
    > do
    > numerous
    > so I
    >>>Ta
    Why? Can't you walk 5 feet to a phone?
    The Natural Philosopher, Feb 7, 2005
    #11
  1. Dave Jennings
    1,098
  2. Lobster
    27
    2,035
    Nick Brooks
    Apr 7, 2004
  3. Mike Barnard
    447
    Mike Barnard
    Mar 30, 2005
  4. dean
    15
    1,034
  5. RobertL
    9
    443
    RobertL
    Dec 15, 2009
