Advice re converting window to french doors
Discussion in 'Misc DIY' started by Broadback, Jul 8, 2004.
  1. Broadback
    Broadback Guest
    I am thinking of converting a window into french doors. Is it simply a
    case of removing the bricks beneath the window (lintel above) then
    fitting french doors.
    Is planning permission and building regs involved?
    TIA
    Please reply to the Newsgroup.
    All emails sent to this address are automatically deleted.
  2. Broadback
    Owain Guest
    | simply a case of removing the bricks beneath the window (lintel
    | above) then fitting french doors.
    Planning permission probably not required, unless you require permission for
    altering a listed building or in a conservation area.
    Building regulations will be involved as you are creating a new
    entrance/exit and changing a window.
    Whether you can use the existing lintel depends, if your house is fairly
    modern the existing lintel is probably adequate. If you have an old house
    the lintel might not be up to modern standards. You will probably need to
    uncover sufficient of the structure to see what sort of lintel you have so
    the BCO can not in approval.
    Owain
    Owain, Jul 8, 2004
  3. Broadback
    BillV Guest
    "Owain" <> wrote in message
    for
    > Owain
    I'd agree with that. Have done a couple but in newer >1980 houses.
    Relatively easy job.
    Its important that the vertical dampcourse that is normal in door/window
    openings is extended all the way down.
    BillV, Jul 9, 2004
  4. Broadback
    N. Thornton Guest
    "Owain" <> wrote in message news:<>...
    Is a lintel compulsory now then? Lots of very old houses dont have them.
    Regards, NT
    N. Thornton, Jul 12, 2004
  5. Broadback
    Owain Guest
    "N. Thornton" wrote
    | > is fairly modern the existing lintel is probably adequate.
    | > If you have an old house the lintel might not be up to modern
    | > standards. You will probably need to uncover sufficient of the
    | > structure to see what sort of lintel you have so the BCO
    Something performing the function of a lintel is required, even if it's not
    a lintel. I emagine a self-supporting arch would be acceptable (structurally
    if not aesthetically, I've never been keen on the Twee Medieval Munchkin
    look).
    Which is why you might have to fit one when you form a new doorway.
    Owain
    Owain, Jul 12, 2004
  1. Replies:
    8
    1,003
  2. Thomarse
    16
    952
    Ed Sirett
    Jul 20, 2007
  3. Chris Long
    Opening a window space for french doors
    Chris Long, Jul 10, 2004, in forum: Misc DIY
    416
  4. Ian
    Doors doors doors
    Ian, Jul 17, 2009, in forum: Misc DIY
    1,306
  5. Mikepier
    Need advice for French closet doors
    Mikepier, Dec 19, 2010, in forum: Home Repair
    301
    Harry K
    Dec 19, 2010
