A/C Motor Start Capacitors - Where To Buy?
Discussion in 'Home Repair' started by SMcK, Jun 29, 2009.
  1. SMcK
    SMcK Guest
    The A/C is not working. Last time this happened the neighborhood A/C
    repair guy showed me how to replace the motor start capacitor. He
    happened to have one in his truck. I'd just as soon not bother him
    again. If I can pull the suspect capacitor and get the specs off it,
    where would a guy get a replacement without going the mail order
    route?
    -Scott
    SMcK, Jun 29, 2009
  2. SMcK
    Ed Guest
    "SMcK" <> wrote in message
    > route?
    > -Scott
    Grainger, McMaster Carr, any good motor supply or repair house.
    Ed, Jun 29, 2009
  3. I get mine, at my local HVAC parts wholesale house. All you
    have to do is get your EPA card, establish a business, get a
    sales tax number, and go into the trade. No problem.
    Christopher A. Young
    Learn more about Jesus
    www.lds.org
    neighborhood A/C
    capacitor. He
    bother him
    specs off it,
    order
    route?
    -Scott
    Stormin Mormon, Jun 29, 2009
  4. Well, you know how it is with AHR posters. He's already
    replaced the thermostat three times, so it's got to be the
    capacitor?
    www.lds.org
    "Big Bob" <> wrote in message
    I curious on what he's going to do when the start cap
    doesn't fix the
    problem. Here in St. Louis there is a no return policy on
    electrical parts.
    lol
    "Stormin Mormon" <cayoung61**spamblock##@hotmail.com> wrote
    in message
    news:h2bf19$uul$...
    > a
    > www.lds.org
    Stormin Mormon, Jun 30, 2009
    > route?
    > -Scott
    That's funny, most AC condensing units don't have
    start capacitors. It is usually an option though.
    You may be referring to the oil filled "run" cap
    that is connected to the start winding. A start
    capacitor is going to be of the electrolytic type
    along with a mechanical or solid state start relay.
    TDD
    The Daring Dufas, Jun 30, 2009
  6. SMcK
    Guest
    On Mon, 29 Jun 2009 14:55:19 -0700 (PDT), SMcK <>
    >route?
    >-Scott
    Take the capacitor apart and rebuild it. You will need tinfoil, an
    insulation material and a chemical electrolyte. Then you need to
    carefully roll the materials together tightly so they fit back in the
    container, and will need to seal the base of the capacitor container
    with a rubber material.
    Or, just go to your local (large) hardware store and buy a new one.
    , Jun 30, 2009
    >> TDD
    > No Shit??
    > When did they start doing that?
    Many years ago. Start capacitors are going to be a
    high value electrolytic type in a black Bakelite
    case along with a potential relay. You will see it
    on commercial refrigeration equipment because the
    compressor often has to start under a load. Under
    ideal conditions, a home AC or refrigerator comp
    is going to have time for the pressures to equalize
    after shutdown before the thermostat calls for cold.
    Last summer I had to remove the factory hard start
    PTC thermistor from our office condensing unit after
    it shorted. That particular setup did not use a
    separate start capacitor. I replaced it with a "Kick
    Start" device consisting of a potential relay and a
    large electrolytic capacitor. A start capacitor and
    relay costs the manufacturer a few dollars more per
    unit and you may not think it's much money until you
    realize that manufacturer has to purchase a million
    of them. Here's a page that shows what I'm referring
    to:
    http://www.toad.net/~jsmeenen/boom.html
    The guy has a good site with a lot of information.
    TDD
    >> route?
    >> -Scott
    Tin foil is very expensive, I always us aluminum foil.
    It works just as well even though it's cheaper. I have
    a friend who swears that beer is the best electrolyte.
    TDD
  9. SMcK
    Bob Villa Guest
    >I have
    Close...its by-product is!
    Bob Villa, Jun 30, 2009
    >>>> route?
    >>>> -Scott
    >> TDD
    > I had a doctor friend tell me that beer is an excellent electrolyte
    > replacer for your body when you've been sweating a lot working outside
    > on a hot day. As long as you don't overdo itby drinking more than one
    > every few of hours.
    > Jeff (6 beers before 12 and 12 beers before 6)
    When I worked out on a Pacific island in the 1980's
    I had the first kidney stone that ever put me in the
    hospital. I've never consumed an alcoholic beverage
    in my life but the other guys I worked with consumed
    it by the keg and none of them suffered any kidney
    stones. They may have had them but never felt them.
    TDD
  11. SMcK
    Guest
    On Mon, 29 Jun 2009 18:45:45 -0500, The Daring Dufas
    >> route?
    >> -Scott
    >TDD
    Which was very common on older compressor units.
    , Jul 1, 2009
    #11
  12. SMcK
    SMcK Guest
    > >> route?
    > >> -Scott
    OK, just to tie up the loose ends on this one:
    1. It turned out the capacitor was fine. I thought it migh be the cap
    because the last time that's what it was and the guy that replaced it
    told me that it's often the problem. The replacement was one he had
    already and I don't know how old it was when we installed it. I
    figured if I could get one and install it myself it would be a cheap
    enough experiment that it was worth it if I could avoid having to pay
    a pro.
    2. I assumed it was a "motor run capacitor" when I went looking for a
    replacement and saw references to them. Maybe it wasn't. It's a
    capacitor with two sides, one labeled "fan" and the other "therm" with
    a common in the center.
    3. In the end I ended up calling in my neighbor again. This guy has
    been doing heating, A/C, electric and plumbing in the neighborhood for
    about 50 years. Nice guy and very helpful and I hate bugging him. He
    determined it was low on freon, and charged it. He also checked for
    leaks and cleaned out the grill(?) with a hose. I paid him a little
    more than what he asked (still a bargain) and gave him a framed photo
    of his house with the sunset behind it.
    4. I don't know how old the unit is. It was there when we moved in in
    '98. I'm going to guess it's about 15 years old.
    -Scott
    SMcK, Jul 1, 2009
    #12
    >>>> route?
    >>>> -Scott
    > a pro.
    > -Scott
    Just so you know, the terminal marked "herm" means hermetic which
    refers to the hermetically sealed welded can compressor. I bet the
    wire was yellow for the "herm" and brown for the "fan". The common
    terminal could have been just about any color except green.
    TDD
    The Daring Dufas, Jul 1, 2009
    #13
  14. SMcK
    SMcK Guest
    On Jul 1, 6:14 pm, The Daring Dufas <>
    > >>>> route?
    > >>>> -Scott
    > > a pro.
    > > -Scott
    > TDD- Hide quoted text -
    > - Show quoted text -
    IIRC it was yellow for common, reddish brown for fan and blue for
    herm. I'm pretty certain about the yellow.
    -Scott
    SMcK, Jul 2, 2009
    #14
    >>>>>> route?
    >>>>>> -Scott
    >>> a pro.
    >>> -Scott
    > -Scott
    You may be right, I've been putting in so many hours
    lately that everything is running together. My hair
    hurts, my toenails itch and my eyeballs are squeaking.
    Last service call was over at 8:00pm.
    TDD
    The Daring Dufas, Jul 3, 2009
    #15
  16. In article <>, Bubba wrote:
    >On Wed, 1 Jul 2009 10:24:45 -0700 (PDT), SMcK < wrote:
    <EDITED FOR SPACE>
    >What a shame to hear that the guy has been doing this for 50yrs and
    >cant find a simple refrigerant leak.
    >Refrigerant doesnt wear out or go bad. It leaks out. You have a leak.
    >It will continue to leak
    How small a leak is one supposed to find? One that leaks out not quite
    all the refrigerant in 15 years?
    Just a few years ago, I was told (IIRC) that A/C techs are finding and
    repairing leaks of 4 ounces of refrigerant per year, and that ones
    around or less than 2 ounces per year are often too small to find and are
    often tolerated.
    - Don Klipstein ()
    Don Klipstein, Jul 6, 2009
    #16
    > <EDITED FOR SPACE>
    > often tolerated.
    > - Don Klipstein ()
    I've been using a stop leak made by Cliplight Manufacturing Company
    for several years and have had very good luck with it. The stuff is
    great for those tiny inaccessible leaks in evaporators.
    http://tinyurl.com/lby8fz
    TDD
    The Daring Dufas, Jul 6, 2009
    #17
  1. mike
    549
  2. Doug
    576
  3. Zoubidoo
    396
    Zoubidoo
    May 8, 2006
  4. stoneattic
    Run versus Start Capacitors - How to tell
    stoneattic, Apr 18, 2007, in forum: Home Repair
    22
    3,756
    trappe
    Nov 8, 2009
  5. Tim Lamb
    motor capacitors
    Tim Lamb, Aug 12, 2011, in forum: UK DIY
    16
    Tim Lamb
    Aug 15, 2011
