A/C filter-drier flow direction
Discussion in 'Home Repair' started by roger61611@yahoo.com, Apr 15, 2006.
  1. Guest
    I thought the same thing. I'd check mine and tell you what it says but
    it's raining.
    , Apr 15, 2006
  2. DJA Guest
    I just had a new a/c system installed so forgive this if it's a stupid
    question...
    I thought the uninsulated line running to the compressor was the freon
    return line and the flow was *toward* the compressor. On my system, the
    flow arrow on the filter-drier is pointing out. See picture....
    http://home.comcast.net/~iflyfish/ac.jpg
    Is this the correct mounting of this part?
    Thanks,
    David
    DJA, Apr 15, 2006
  3. lp13-30 Guest
    The drier is installed correctly. The uninsulated line(usually 3/8"
    copper) is carrying liquid refrigerant to the inside evaporator coil,
    and the insulated larger line is returning refrigerant vapor to the
    compressor. Larry
    lp13-30, Apr 15, 2006
  4. This is correctly installed. The small line travels towards the house.
    The large line, the freon travels towards the outdoors.
    Christopher A. Young
    You can't shout down a troll.
    You have to starve them.
    "DJA" <> wrote in message
    question...
    the
    Thanks,
    David
    Stormin Mormon, Apr 15, 2006
  5. HeatMan Guest
    > question...
    The drier is correct.
    The Romex power supply is NOT correct! You may not have codes to follow in
    your area, but common sense should tell you and the installer that the way
    the high voltage wiring is installed IS NOT right! I'm almost willing to
    bet there isn't a disconnect there either.
    Zip tying the 220volt power supply to the suction line..... Geeesh.
    Is this on a Carrier condenser?
    HeatMan, Apr 15, 2006
  6. hvactech2 Guest
    >question...
    >Thanks,
    >David
    yes, That is the correct flow direction.
    spam protection measure, Please remove the 33 to send e-mail
    hvactech2, Apr 15, 2006
  7. Sugob Guest
    Yes it is.
    Sugob, Apr 15, 2006
  8. HeatMan Guest
    "Sugob" <> wrote in message
    in
    way
    to
    > Yes it is.
    Just because the condenser is a Carrier is NO excuse for the electrical to
    be done like that.
    Are you the OP?
  1. Lobster
    10
    630
  2. crb
    509
    John Stumbles
    Dec 2, 2007
  3. David Robinson
    484
    spamlet
    Apr 27, 2010
  4. Marc O'Brien
    18
    446
    Bob_Loblaw
    Nov 27, 2006
  5. Nick
    514
    Jim K
    Aug 4, 2010
