A/C A-coil drip pan leaking
Discussion in 'Home Repair' started by JOHN D, Jul 22, 2005.
  1. JOHN D
    JOHN D Guest
    My A/C A-coil drip pan is leaking leaking water. It's in the attic. Not a
    good place for a water leak. I know there's a bunch of rust scale in the pan
    cus I just cleaned everything else and inspected the A-coil to check it. I
    didn't clean the pan cus it's so hard to get into. Maybe I'll get lucky and
    it's just a plugged drain but I don't think so. It might be impossible to
    get at the leak but if I can get at it, what do you HVAC guys use to patch
    up a rusted leaking drip pan?
    John
  2. JOHN D
    meirman Guest
    In alt.home.repair on Fri, 22 Jul 2005 06:34:20 GMT "JOHN D"
    <> posted:
    >John
    I'm not an HVAC guy, and I'm sure there are better ways, but in
    general it's goodto know that PC-70 can be put on a wet material and
    still stick. I was only a temporary roommate of a tenant whom I
    didn't know in advance, but I once fixed a sink drain with a hole and
    a faucet that wouldn't stop dripping, with PC-70, while water was
    coming out of the hole. I had to keep pushing the stuff back in place
    but eventually it hardened and stayed there, and didn't leak.
    Meirman
    If emailing, please let me know whether
    or not you are posting the same letter.
    Change domain to erols.com, if necessary.
    meirman, Jul 22, 2005
  3. JOHN D
    Dr. Hardcrab Guest
    "JOHN D" <> wrote in message
    news:Mr0Ee.26438$IJ1.9161@trnddc02...
    > pan
    > I
    > and
    > John
    As the Kinch man said: a new air handler. At the least, a new coil. That is
    unless a new drain pan can be ordered. Sure they make some caulk that will
    plug a leak (even under water! Why, you can even glue your helmet to a steel
    beam and suspend yourself 50 feet in the air!!!), but you'll just end up
    with another leak elsewhere, and I GUARANTEE it will happen when you least
    expect it (while you are on vacation and your ceiling ends up on the floor).
    Go ahead and patch it for now, but i would plan on replacing it before
    something major happens...
    Dr. Hardcrab, Jul 22, 2005
  4. JOHN D
    Guest
    pan
    I
    and
    > John
    Depends, best case, a new pan, worst case, new air handler, or coil. Depends
    on the situation, and how extensive the damage, if any, is.
    , Jul 22, 2005
  5. "JOHN D" <> wrote in message
    > pan
    > I
    > and
    > John
    Worst case scenario is you clean the pan and lay up fiberglass and resin
    just like they do to make a boat or shower stall. Could very well be a
    clogged drain.
    Edwin Pawlowski, Jul 22, 2005
  6. JOHN D
    JOHN D Guest
    "Richard J Kinch" <> wrote in message
    news:Xns969B1E1D092D8someconundrum@216.196.97.131...
    > JOHN D writes:
    > > patch up a rusted leaking drip pan?
    > A new air handler.
    I just ordered a new drain pan for $8
    JOHN D, Jul 25, 2005
  1. Les Desser
    Drip-drip-drip driving us mad
    Les Desser, Apr 22, 2008, in forum: UK DIY
    697
    Les Desser
    Apr 23, 2008
  2. orangetrader
    Delta faucet drip...drip...drip...
    orangetrader, Dec 24, 2004, in forum: Home Repair
    18
    843
    Doug Kanter
    Dec 26, 2004
  3. miamicuse
    718
    nospambob
    Aug 19, 2005
  4. JOHN D
    A/C A-Coil drip pan leaking
    JOHN D, Jul 22, 2005, in forum: HVAC
    32
    1,568
    pjm@see_my_sig_for_address.com
    Jul 25, 2005
  5. JOHN D
    395
    JOHN D
    Jul 22, 2005
