2x4 for lowered ceiling joists?
Discussion in 'Building Construction' started by Jim, Aug 21, 2003.
  1. Jim
    Jim Guest
    Guys
    Finishing a basement and have to lower some ceilings because of mechanicals.
    Guidelines on 2x4 vs. 2x6 spans for ceilings just supporting drywall and a
    few recessed cans? Most areas are 36 to maybe 52 inches...2x4 ok?
    One room is 85"...so I am thinking 2x6
    Or maybe add some center supports to overhead joists and keep them 2x4s?
    Also, what about laying the 2x4 sideways because of clearance to
    ductwork...ok on short spans with center supports?
    I see some DIY use 2x2s for soffits...I had planned on 2x4 min for
    everything....thoughts?
    Thanks!
    Jim
    Jim, Aug 21, 2003
  2. JD
    JD Guest
    "Jim" <> wrote in message
    news:FQ61b.5364$...
    > Guys
    mechanicals.
    Span tables have your answer.
    JD, Aug 21, 2003
  3. Jim
    Jim Guest
    Span tables are.....in framing books?
    Jim
    "JD" <> wrote in message
    news:6C71b.113$...
    > news:FQ61b.5364$...
    > > Guys
    > mechanicals.
    a
    Jim, Aug 22, 2003
  4. Bob Marencin
    Bob Marencin Guest
    uh
    i would suggest moving your mechanicals to the side of the room's ceiling
    then building a box down that side of the length room to make a plenum for
    all the mechanicals. you could run floresent lights down that strip hung
    under it or maybe build a book case / shelves that would bring the wall
    flush with the plenum. You dont want to drop a basement height at all
    because being under ground without windows is confining enough. you also
    want easy access to the mechanicals so 1/8th" bead board comes in 4'x8'
    sheets held in with moldings that can be removed would be good material to
    make that box.
    but
    you can sister a 2x onto another to bring the height down
    __ 1st floor
    | |_
    |_| | <- nail
    |_|
    if you are thinking of face nailing a parallel 2x into the 2x above it you
    would have to use screws at minimum or lag bolts if its holding something
    heavy and its not a good thing to do as you will ruin the joists causing
    splits.
    __ 1st floor
    |_| don't
    |_|
    if you run the 2x s perpendicular to the joists you can use screws but you
    will be restricting access to those mechanicals / pipes with more then some
    thin 1/2" of drywall and that may mean a huge headache in a few years.
    bob marencin
    www.yourepair.com
    news:FQ61b.5364$...
    > Guys
    mechanicals.
    > Thanks!
    > Jim
    Bob Marencin, Aug 22, 2003
  5. Jim
    Jim Guest
    thanks.
    Ceiling is nine foot...most rooms I was able to keep all ductwork inside
    joists..so full 9' ceilings. One bedroom will have a tray....but the
    bathroom, hall and a small craft room have just too many crisscrossing ducts
    etc..so I am lowering the entire ceiling in those rooms to 8'..........still
    nice and high really.
    I decided on my two longer spans of 85 and 90" to use 2x6...my smaller spans
    like 50" and smaller I am using 2x4.
    I did find span tables and they listed 2x4 good for 10-11'...well, that
    seemed excessive, so I am using 2x6.
    Jim
    Jim
    "Bob Evans" <._NOSPAM> wrote in message
    news:HCr1b.173322$...
    > What is your ceiling height in the basement? When finishing basements I
    > typically strive for every inch of ceiling height I can obtain. This
    > typically means moving the mechanicals as close to the adjoining walls as
    > possible and treying the ceiling. If mechanicals run along one wall and it
    > is of sufficient size, I sometimes frame a new wall and recess bookcases
    or
    > the entertainment center into it.
    > If you insist on a flat ceiling with no trey, you may want to consider a
    > suspened drop-in tile ceiling. Although most people prefer smooth
    ceilings,
    > you can often times hold a suspended ceiling closer to the mechanicals
    than
    > a framed/sheetrock ceiling.
    > Bob
    > news:FQ61b.5364$...
    > > Guys
    > mechanicals.
    a
    > > Thanks!
    > > Jim
    Jim, Aug 23, 2003
  1. Charles Middleton
    Lowered ceiling
    Charles Middleton, Dec 6, 2004, in forum: UK DIY
    17
    489
    Dave Plowman (News)
    Dec 8, 2004
  2. Darryl
    Sewage question in lowered basement...
    Darryl, Nov 21, 2003, in forum: Home Repair
    210
    Darryl
    Nov 21, 2003
  3. AgaPSDIVER
    Use 2x4 or 2x6 for ceiling rafters
    AgaPSDIVER, Dec 8, 2003, in forum: Home Repair
    415
    William Morris
    Dec 11, 2003
  4. AgaPSDIVER
    AgaPSDIVER, Dec 8, 2003, in forum: Building Construction
    529
    William Morris
    Dec 11, 2003
  5. Replies:
    410
