275 gallon oil tank - how long should it be between fill-ups?
Discussion in 'Home Repair' started by Joe, Jan 8, 2007.
  1. Joe
    Joe Guest
    How many gallons of heating oil should I be going through a month? I
    filled up my tank on November 7th and my gauge stopped working so I'm
    not sure when to request a refill. Knocking on the sides of the tank
    makes it seem like it's well below half - maybe even a quarter full.
    Should I have used that much in two months? I'm in CT and it's been a
    very mild winter (70 degrees on Saturday). My oil burner is an
    effecient 7 year old McClain and I live in a fairly insulated 1300 sq
    ft Cape Cod. My oil heats my house and hot water (hot water is one of
    those mini tanks that connects to the oil burner that automatically
    heats water on demand), my stove is electric. Anyone is a similar
    situation care to share with me their fillup averages?
    Joe, Jan 8, 2007
  2. cavedweller
    cavedweller Guest
    Your supplier may schedule fillups on the basis of degree-days and your
    past history. You could ask him.
    You could also remove the gauge with a wrench and "stick" the tank
    through the opening.
    cavedweller, Jan 8, 2007
  3. Pete C.
    Pete C. Guest
    Just buy a new tank gauge, they aren't expensive perhaps $30. They are
    also easy to replace if they are separate, if it's the combined gauge
    and breather Y fitting, just get the standalone gauge and install in on
    one of the other tank top openings (usually four) and ignore the old
    gauge.
    Unless you jump to the lowest price at the moment each fill up, just
    have the oil company put you on scheduled delivery and you won't have to
    worry. The first few times they'll come extra early to insure you don't
    run out, and based on the degree days and the gallons in each delivery
    the software they use will calculate a proper fill interval for you and
    adjust it as needed based on the weather. It works very well.
    Pete C., Jan 8, 2007
  4. dpb
    dpb Guest
    Pete C. wrote:
    > Joe wrote:
    > > How many gallons of heating oil should I be going through a month? ..
    What have you averaged previously?
    > Just buy a new tank gauge, they aren't expensive perhaps $30. ...
    Or use a clean broomstick handle or similar as a dipstick... :)
    dpb, Jan 8, 2007
  5. Joe
    Joe Guest
    I tried to replace the tank gauge. I think this tank is about 50 years
    old and the gauge started to fall apart when I tried to twist it. It
    also looks like there is some kind of grey sealant that has welded
    itself to the threads over the years. There are no other available
    holes on the top of the tank. There is one where the oil comes in and
    another where it goes out. The tank was inspected when I bought the
    house and was declared in good shape. As far as buying oil is concerned
    I was offered a plan in the fall but the prices were too high back then
    - about $2.70 per gallon so I have been buying the oil from a
    wholesaler for $1.99 but he doesn't do schedules and you have to call
    him to fill up. I'm just wondering if every two months is about
    standard. The last thing I want to do is run out and have my pipes
    freeze.
    Joe, Jan 8, 2007
  6. avid_hiker
    avid_hiker Guest
    > freeze.
    Depends on how well your home maintains the heat...insulation, etc. My
    past home in Upstate, NY which was a cape about 50 years old, I was
    filling up every month in the winter which got to be pretty expensive.
    With The home I have now, a ranch around 25 years old, I am filling up
    about 4 times/year.....which is quite a difference. The home now
    maintains the heat VERY well.
    Does your cape have insulation on the attic floor? If planning on
    stsying there for a long while, might want to think sealing your home
    nice and tight. Probably pay for itself with that amount of fuel.
    avid_hiker, Jan 8, 2007
  7. whiteoak
    whiteoak Guest
    Hey Joe . Check with your oil supplier or a tank dealer. See if you can
    get a gallon per inch chart that matches your tank. Then use some sort
    of rod to measure the inches of oil, and with a chart, convert inches
    to gallons :) Works well !!
    Whiteoak
    whiteoak, Jan 8, 2007
  8. Speedy Jim
    Speedy Jim Guest
    <SNIP>
    I would not mess with any tank fittings,
    including the gage port,if it won't come out easily.
    This may sound a bit extreme, but I would wire
    a clock (old time one with hands that go 'round :)
    directly to the burner motor.
    This will let you keep a total of the burner
    running time and, knowing the nozzle size,
    the total consumption in gallons.
    You may not have to pull the burner out to
    find the nozzle size. See if there is an old nozzle
    laying about or repair slip which gives it.
    Jim
    Speedy Jim, Jan 8, 2007
  9. Pete C.
    Pete C. Guest
    > freeze.
    You simply can't go by a number of days between fill ups since your
    consumption is not a constant.
    The software the oil companies use takes heating degree days into
    account along with your past usage to determine a gallons to degree day
    ratio for your account. By tracking the degree days since your last fill
    up and knowing the size of your tank the software schedules the next
    delivery. I'm not aware of any similar tracking software for home use.
    Have the tank gauge replaced when you have your burner's next annual
    service. It shouldn't add much to the cost of the service call if you
    tell them in advance so they have the part with them.
    As for checking the level now, if there are no other ports on the top of
    the tank you can use you won't be able to get an accurate reading
    easily.
    You may be able to use one of the stick on level gauges intended for LP
    tanks to get a decent reading. They only cover a short range so you'd
    want to stick it to a fairly low point on the tank, perhaps 1/4 of the
    way up the end. These gauges are basically liquid crystal thermometers.
    The way they work is you pour a little hot water on the gauge which
    causes it to change color. In a few seconds it starts to change back as
    it cools. Since the tank surface that is in contact with liquid inside
    will cool more rapidly you will see that area change back first
    indicating the approximate liquid level.
    The LP gauges work reasonably well on steel LP tanks so they should work
    ok on a steel oil tank. They are also cheap so it's worth a shot since
    your other option is to tap the tank and try to find the liquid level.
    For backup against having your pipes freeze, you can get two 5 gal cans
    of diesel fuel to keep as a reserve. Diesel fuel and home heating fuel
    are basically the same other than red dye in the untaxed heating fuel.
    Heating fuel is also known as "off road diesel" and frequently used for
    construction equipment that is only operated off road and not subject to
    transportation fuel taxes. 10 gal would be enough to keep you going
    until a next day oil delivery.
  10. "Joe" <> wrote in message
    Consumption varies widely ... some homes are drafty and under-insulated and
    some folks like 80 degrees.
    My 2400 sq. ft. home never used more than 800 gal. per year. It was in SW
    PA and some of the winters were fairly severe. This home had triple glazed
    windows and no leaks. I replaced the doors and gaskets to eliminate the
    drafts. If you can feel cold air drafts, you are wasting energy.
    Charles Schuler, Jan 8, 2007
  11. Hi Charles,
    I heat a 2,500 sq. ft. Cape Cod here in Halifax, N.S. and two years
    ago my consumption totalled 1,973.3 litres (525 US gallons). By
    comparison, the previous homeowners in the year prior to my purchase
    used 5,700 litres or just over 1,500 gallons. A new heating system
    (SlantFin boiler, SuperStor Ultra indirect hot water tank and Tekmar
    control system), plus various upgrades to my home's thermal envelope
    have effectively cut my fuel oil consumption by two-thirds.
    Last year, I installed a small (14,000 BTU/H) ductless heat pump and
    further reduced my fuel oil consumption to just 828.3 litres (220 US
    gallons). If my calculations are correct, approximately 70 per cent
    of this amount can be attributed to domestic hot water demand. My net
    savings (after subtracting the cost of electricity) came to roughly
    $575.00.
    With the unusually mild weather we've experienced thus far, I expect
    our consumption this winter will drop yet again. My last fill-up was
    September 8th and some four months later my tank gage is reading a
    little under 7/8ths full.
    Cheers,
    Paul
    On Mon, 8 Jan 2007 16:22:52 -0500, "Charles Schuler"
    Paul M. Eldridge, Jan 8, 2007
    #11
  12. "Paul M. Eldridge" <> wrote in message
    > Hi Charles,
    Hi Paul: That is great performance. Many folks do not appreciate how much
    they could save by making modest investments.
    I added storm windows over the double-glazed windows and replaced the warped
    wood doors with steel doors and new gaskets. I added 6 inches of insulation
    in the attic. It really does make a huge difference. Also, there is a
    psychological advantage ... with no chilly drafts, one is much less likely
    to travel to the thermostat and kick it up a notch or two.
    #12
  13. Jeff Wisnia
    Jeff Wisnia Guest
    If by "falling apart" you're stating that the gauge no longer tightly
    seals the opening it's screwed into, then your tank is in violation of
    fire codes and you really ought to do something about it ASAP.
    Not that fuel oil vapors are anywhere near as dangerous as gasoline, but
    if the tank is inside and that cheapo dealer you're buying from happens
    to overfill the tank, some of the excess fuel oil will end up coming out
    of the broken gauge instead of it all going outside through the vent pipe.
    Do yourself and anyone else living there with you a favor and get that
    gauge replaced by someone who can do the job right. You've already
    announced to the world on this newsgroup what you did to that gauge, if
    the place burned down your insurer might just learn about what you did,
    because old newsgroup posts never really die. Stranger things have happened.
    Jeff
    Jeffry Wisnia
    (W1BSV + Brass Rat '57 EE)
    The speed of light is 1.8*10^12 furlongs per fortnight.
    Jeff Wisnia, Jan 8, 2007
    #13
  14. Pete C.
    Pete C. Guest
    One of the risks assumed by the insurer is that of loss caused by non
    criminal actions of the homeowner. Trying to remove a failed oil level
    gauge and giving up is not a criminal action except perhaps in the
    socialist republics of California and Massachusetts, so you're still
    covered. Whether you get renewed is another matter...
    #14
  15. Jeff Wisnia
    Jeff Wisnia Guest
    I defer to your superior knowledge of the intricacies of the insurance
    business Pete. But....
    My being a "Native Son of the Golden State (California) who has also
    lived in Massachusetts for the past 54 years gives me reason to believe
    that you've got it backwards. <G>
    I'd 'spect that the looney left in those two states firmly believes that
    no one should bear any responsibility for their own actions, even if
    they've been told that they might have created a hazardous situation by
    someone (me) who was for 13 years the CE of a company which manufactured
    275 gallon tank gauges and lots of other fuel oil delivery hardware.
    Liberals will always believe that you can pick up a turd by its clean end.
    Jeff
    Jeffry Wisnia
    Jeff Wisnia, Jan 9, 2007
    #15
  16. Pete C.
    Pete C. Guest
    > Jeff
    > Jeffry Wisnia
    The loony left are also the only ones who think you're a criminal if you
    have any technical knowledge and repair / maintain anything yourself. If
    they know how to use tools they might make weapons and overthrow us...
    Pete C., Jan 9, 2007
    #16
  17. Hi Charles,
    I agree completely. I'm still working on improving the thermal
    efficiency of my home and hope to cut its heat loss by a further 10 to
    20 per cent. This house was built in 1968 and the original insulation
    was pretty modest (e.g., just two inches of fibreglass in the attic).
    And although generally well built, it was uncomfortably drafty (I'm
    directly exposed to rather high winds coming off the Atlantic).
    Today, the situation is vastly improved.
    With a modest amount of passive solar and various other internal
    gains, this house will maintain a comfortable indoor temperature down
    to about 13C (55F). Once average daily temperatures consistently fall
    below this mark, additional heating is required. As far as I can
    tell, heating demand is something in the order 330 BTUs per hour, per
    degree F, as we fall below this demand point. If this number is more
    or less correct, at 0C (32F), heat loss would be approximately 7,700
    BTUs per hour (2.3 kW) and at -10C (14F), it would climb to 13,600
    BTUs (4.0 kW). In reality, heat loss is not truly linear across the
    temperature band and wind speed can have a big impact on this rate, so
    it's only a rough approximation.
    If you are curious, you can view a record of my fuel oil consumption
    here:
    http://server3.pictiger.com/img/783548/other/oil-consumption.jpg
    For a summary of my estimated heat pump savings, see:
    http://server3.pictiger.com/img/783549/other/heat-pump-(summary-sheet).jpg
    (please note the first three years shown are simulations whereas last
    year and this year are actuals)
    The summary sheet pulls data from a daily log that tracks outdoor
    temperatures hour by hour. For the month of January, see:
    http://server3.pictiger.com/img/783550/other/heat-pump-(january).jpg
    Clicking on these images allows you to enlarge them.
    By way of explanation, the left column of the daily log indicates if
    the heat pump has been turned on or off (1=on/0=off); the following
    column lists the outdoor temperature; the third column shows the heat
    pump's estimated heat output (in kW) based on its published
    performance curve; the fourth column is the home's estimated heat loss
    (in kW); the fifth column is the net heat loss or heat gain for that
    hour; the sixth column is the running balance or accumulative gain or
    loss; and lastly, the final column is a check flag that confirms the
    heat pump can actually operate at that temperature (we assume that
    below -12C, the heat pump, although it may be turned on, can no longer
    transfer heat and has, in effect, suspended its operation).
    I should add that the true performance of this heat pump may be better
    than what is indicated here. As you probably know, heat pumps
    produce less heat as the outdoor temperature falls and the spreadsheet
    accounts for that. However, it's my understanding that power
    consumption also falls but, unfortunately, I don't know by how much.
    For our purposes, I've assumed it stays at a constant 1.23 kW across
    the entire temperature band.
    Cheers,
    Paul
    On Mon, 8 Jan 2007 17:25:52 -0500, "Charles Schuler"
    Paul M. Eldridge, Jan 9, 2007
    #17
  18. jackson
    jackson Guest
    >> > A man of great wisdom named "Jeff Wisnia" wrote:
    /snip
    >> end.
    That's my new tag/sig line! Classic!
    jackson, Jan 9, 2007
    #18
  19. jackson
    jackson Guest
    "Pete C." <> wrote in message
    >> freeze.
    > easily.
    Even 5 gallons will do you for most likely 24 hours, but for it to be any
    good to you you'll need to know how to 'prime' the line to the burner to get
    the furnace started again assuming you ran completely out. It will also
    depend on your heating/insulation/outside temperature as stated previously.
    Take note as well that storing diesel for an extended period is not really
    recommended, it has a shorter shelf life then gasoline AFAIK, so if you go
    with that plan rotate your can(s) every couple of weeks. Personally I'd
    just call the repair guy and have the furnace cleaned and the gauge changed,
    especially if you have now somehow broken a seal on the tank threads.
    #19
  20. Guest
    Guest Guest
    In article <>,
    Just remove the fill cap and shove a broomstick into the tank about
    once a week.
    A man who throws dirt loses ground.
    Larry Wasserman - Baltimore Maryland -
    Guest, Jan 9, 2007
    #20
  1. Cindy B.
    1,008
    Joann M. Hnat
    Jun 29, 2003
  2. dm
    1,123
    George E. Cawthon
    Jun 26, 2003
  3. greg2468
    When a gallon is not a gallon
    greg2468, Feb 27, 2008, in forum: Home Repair
    116
    1,700
    Percival P. Cassidy
    Mar 13, 2008
  4. mike
    50 Gallon loft tank WEIGHT
    mike, Sep 16, 2003, in forum: UK Home Improvement
    918
    scoob
    Sep 16, 2003
  5. David Hearn
    423
    Grimly Curmudgeon
    May 9, 2012
Share This Page
