2 port Vs 3 port central heating valves
Discussion in 'UK DIY' started by EMC, Jul 29, 2003.
  1. EMC
    EMC Guest
    I am just about to embark on upgrading my old oil fired gravity hot water /
    pumped central heating system to a gas fired fully pumped system and am
    unsure what arrangement of valves to use. What are the advantages /
    disadvantages of using a 3 port valve instead of two 2 port valves to
    control a fully pumped hot water and (single zone ) central heating system?
    EMC, Jul 29, 2003
  2. EMC
    IMM Guest
    "EMC" <> wrote in message
    news:9gqVa.133$...
    > What are the advantages / disadvantages
    Go for a 3-way throw over valve with an end switch (3 port) and a quick
    recovery cylinder (part L is not quick recovery). The cylinder will take
    "all" of the boilers output, reheating in a matter of minutes, and be
    cheaper to run. The system will be a "priority" system. These valves are
    generally to order, but come fast. A few have the end-switch, like Drayton
    and others. The end switch makes it easy to wire up.
    The now common 3-port mid-position valve can be temperamental. If going
    this route, which I suggest you do not. Use two 2-port valves, unless space
    is a problem.
    A quick recovery cylinder can be downsized. So a normal 114 litre cylinder
    can 80 litres. The 80 litre Telford Typhoon from Travis Perkins is approx
    £100. Albion and Range do them too
    http://www.albion-online.co.uk
    Version: 6.0.488 / Virus Database: 287 - Release Date: 05/06/2003
    IMM, Jul 29, 2003
  3. EMC
    EMC Guest
    IMM,
    Thanks for the information. By throw-over valve, do you mean a diverter
    valve? I assume that by using this arrangement all hot water from the
    boiler will be diverted to the cylinder when demanded. If several baths,
    washing machine and shower are used in succession (probably unlikely I
    know), would that mean the radiators may not be supplied for some time?
    On the subject of quick recovery cylinders, what is Part L? I am also
    considering an unvented cylinder and a sealed system boiler. Which unvented
    cylinders would you recommend as quick recovery?
    Eric
    "IMM" <> wrote in message
    news:bg5hof$dsv$...
    > news:bg5dnp$j6h$...
    > > news:9gqVa.133$...
    take
    are
    Drayton
    > space
    > > is a problem.
    > cylinder
    approx
    > http://www.telford-group.com
    > http://www.range-cylinders.co.uk
    EMC, Jul 29, 2003
  4. EMC
    EMC Guest
    Thanks Bill, I'm coming to the same conclusion as the lack of reliability of
    the 3 port valves seems to be a widespread opinion.
    Eric
    "BillR" <deepthought@NO_spammers-here.cyberdude.com> wrote in message
    news:dfvVa.50684$9.net...
    > > water / pumped central heating system to a gas fired fully pumped
    > > system and am unsure what arrangement of valves to use. What are the
    > > advantages / disadvantages of using a 3 port valve instead of two 2
    > > port valves to control a fully pumped hot water and (single zone )
    > I'd recommend two 2 port valves. The normal 3 way ones are a pain in my
    > opinion.
    > They are always breaking down and its also difficult to tell what mode
    > they've failed in.
    > My current (3rd) one won't shut off the CH properly. I'm changing it for
    two
    > 2 ports as soon as I can get round to it.
    EMC, Jul 29, 2003
  5. EMC
    IMM Guest
    news:CivVa.1040$...
    of
    You mean a 3-port mid-position valve. A 3-port diverter is the most
    reliable option. One reliable simple head. With two valves you double the
    problem. Diverters and 2 -ports tend to use the same heads.
    IMM, Jul 29, 2003
  6. EMC
    IMM Guest
    news:bg60bc$ah8$...
    > news:iSuVa.1026$...
    > > IMM,
    > > do you mean a diverter valve?
    > Yes, that is the correct terminology.
    > > all hot water from the boiler will be diverted
    > Yes, but in reality the cylinder is re-heated pronto. The cylinder will be
    > well re-heated and well into CH mode by the time another bath is run. A
    > largish boiler may be re-heating the cylinder faster than what the shower
    > can draw-off the hot water.
    > As you are buying a new boiler, look at getting a combi to supply the
    > showers only. Then no expensive, noisy, vibrating, troublesome power
    shower
    > pumps. Have the CH section as a conventional system with a 3-way diverter
    > valve. As the combi's water section will only be used for showers, once
    or
    > twice a day, they last quite a time. All the water system, except the
    > showers will be at low pressure and high flow.
    > If you are replacing the cold water tank think about a "combi cylinder".
    > Have a 50-50 split of hot water and cold water storage. Have the cold
    water
    > section 115 litres and take all the cold supplies off the cold water
    > section. This way using a combi boiler for the shower side you eliminate
    > the cold water tank in the loft, or put the combi cylinder in the loft
    (well
    > insulated of course) and have a larger airing cupboard. Telford do the
    > Trident, which has a 115litre/115litre split. have a look at their web
    > site. Combi cylinders are simpler and quicker to install.
    > http://www.telford-group.com/trident.htm Some cylinder makers will
    provide
    > combi cylinders to order, in that if you wanted a 115 litre hot section
    and
    > 115 litre cold section and appropriate tappings, etc, they will provide
    it.
    > So you would have:
    > 1. A combi boiler supplying any high pressure showers.
    > 2. A combi cylinder with a large cold water section. providing low
    pressur
    > hot and cold water.
    > 3. A DHW priority system.
    > In April part L of the building regs came into being. It implemented
    energy
    > regs to water and heating systems. Part L cylinders means that all
    cylinder
    > must take no more than 30 minutes to heat up. This obviously is
    depending
    > on the boiler temp being on max, which it should be, and the flow through
    > the coil. Quick recovery are far superior to Part L cylinder. So, in a
    > plumbing shop the man may say these are all quick re-heat because they all
    > conform to Part L. I have heard that being said by counter men.
    > > I am also considering an unvented cylinder
    > An unvented cylinder needs to be fitted by a BBA approved fitter. They
    are
    > not DIYable. Consider the suggestion I made above, which is cheap and
    easy
    > and give lots of flow and high pressure showers. Otherwise fit a heat
    bank,
    > rather than an unvented cylinder which requires large bore blow-off pipes
    to
    > outside, tundishes, etc. Some heat banks don't even require overflows.
    > A sealed system boiler is fine. But many combi's are cheaper and you get
    the
    > high pressure DHW section for showers for free and a very high output that
    > modulates. Many wise installers buy cheap combi's and ignore the DHW
    > section, just connecting it to the mains and capping the hot water
    draw-off
    > pipe off.
    > When fitting a new boiler to an existing system always insert a strainer
    on
    > the return next to the boiler to catch ant crud floating around. In fact
    > some Alpha combi's have a cyclone in the return pipe inside the boiler to
    > catch the debris.
    Heat banks:
    http://www.heatweb.com
    Also from Range cylinders under "thermal storage" on their web site. Albion
    don't do heat banks.
    IMM, Jul 29, 2003
  7. EMC
    Ed Sirett Guest
    IMHO using 2 (or more) 2 port valves is better in every respect than a 3
    port valve except that the 3 port (either mid-position or diverter
    variants) is marginally lighter on material costs.
    If you decide to go the 3 port way - be strongly advised that the
    diveter valve variant (either but not both CH and HW) - has been found
    wanting by many.
    Ed Sirett, Jul 29, 2003
  8. EMC
    IMM Guest
    "Ed Sirett" <> wrote in message
    > wanting by many.
    This new to me. A 3 port diverter is as simple as a two port. They use the
    same heads.
    IMM, Jul 29, 2003
  9. EMC
    Andy Hall Guest
    >news:...
    >> wanting by many.
    >same heads.
    I had diverter valves of this type in my system from when the house
    was built until I ripped it out with the rest of the abortionate
    plumbing that they had done in the airing cupboard.
    There were four replacements over a 15 year period which I don't think
    is impressive. Typically, either the mechanism would stick in the
    base or a leak would develop.
    Using 2 port versions and having the boiler do the priority control
    seems to be a much better solution.
    ..andy
    To email, substitute .nospam with .gl
    Andy Hall, Jul 30, 2003
  10. EMC
    IMM Guest
    "Andy Hall" <> wrote in message
    news:eek:...
    > >news:...
    > >> wanting by many.
    > > same heads.
    Sounds like a poor make and compounded by a poorly installed system. They
    can be fitted on the cooler return pipe which enhances longevity.
    Version: 6.0.488 / Virus Database: 287 - Release Date: 06/06/2003
    IMM, Jul 30, 2003
  11. EMC
    Andy Hall Guest
    >> >> wanting by many.
    >> > same heads.
    IIRC, the original was made by Switchmaster? (had a blue motor head),
    there were then I think a Danfoss and two Honeywells, with the latter
    two lasting about 4 years each. I wouldn't call Danfoss and
    Honeywell poor makes as such.
    The fitting position was on the return in one of the recommended
    positions so no clue there either.
    I even went to the trouble of exercising the heating at least weekly
    during the summer months so that the valve wouldn't stick. The
    failures weren't at any particular time of year.
    ..andy
    #11
  12. EMC
    IMM Guest
    found
    > >> >> wanting by many.
    > >> > same heads.
    They
    On a far simpler valve you have a failure rate far higher than the more
    troublesome mid-position 3 port valve. Sounds like the system was faulty
    somewhere.
    Correct and sufficient inhibitor can lubricate valve mechanisms. A two pump
    casting Grundfoss Tee setup can be used instead of any 3-port valve,
    mid-position or diverter.
    IMM, Jul 30, 2003
    #12
  13. EMC
    Andy Hall Guest
    >somewhere.
    There was nothing much else to it so I can't see that that would
    influence anything
    I did all of that religiously
    >A two pump
    Interesting idea and I believe not much different in cost to a
    conventional set of pump and valve.
    ..andy
    #13
  14. EMC
    IMM Guest
    > >somewhere.
    > influence anything
    Then you are just unlucky. Can someone be "that" unlucky using three
    different makes of valves?
    > > A two pump casting Grundfoss Tee setup
    IMM, Jul 30, 2003
    #14
  15. EMC
    Ed Sirett Guest
    > news:...
    > > wanting by many.
    > same heads.
    I don't mean to imply that there was a reliability issue. As you say the
    heads are the same as a two port unit. What I mean is that people are
    unhappy with a system that cannot simutaneously run the heating and the
    water!
    More than once I have been asked to 'fix' a system with a diverter valve
    that the owners perceived as broken, and as you know, the customer is
    always right.
    Ed Sirett, Jul 30, 2003
    #15
  16. EMC
    IMM Guest
    > > news:...
    > > > wanting by many.
    the
    > > same heads.
    > water!
    > always right.
    I assume they have old fashioned British Standard pig of a cylinder and not
    a quick recovery. If they had a quick recovery they would not complain as
    they would not notice the heating has been off for a few minutes or so.
    IMM, Jul 30, 2003
    #16
  17. EMC
    Ed Sirett Guest
    > news:...
    > > > news:...
    > > > > wanting by many.
    > the
    > > > same heads.
    > > water!
    > > always right.
    Whilst a fast recovery cylinder would cetainly have mitigiated the
    problem it would (at least for one customer) not have fixed it.
    The usage the cusotmer wanted to put the system to was simple: Off for
    days at a time then come home and switch both heating and HW on, a
    completely reasonable way to operate the system for his lifestyle.
    Even a 15 minute delay would really have been unacceptable.
    Ed Sirett, Jul 31, 2003
    #17
  1. Ron Askew
    1,219
    Ron Askew
    Oct 29, 2003
  2. LaserMark
    9
    632
    John Stumbles
    Feb 19, 2007
  3. Sam
    2-port and 3-port CH valves
    Sam, Jan 10, 2008, in forum: UK DIY
    18
    1,195
    John Rumm
    Jan 12, 2008
  4. samul888@vip.163.com
    634
    Apr 1, 2006
  5. mm
    571
    Robert Allison
    Jun 25, 2010
