15mm Flexible Pipe?
Discussion in 'UK DIY' started by r.rain@btinternet.com, Jun 3, 2005.
  1. Guest
    Hello All
    I am in the process of planning for re-routing some 15mm pipe work for
    a toilet supply and wash basin. The old pipe under the floor boards is
    copper and is pretty difficult to manoeuvre and just wondered if
    plastic flexible pipe would be recommended instead?
    If so can you join copper to plastic using the push fit fitments?
    For the washbasin I am going to have to route the pipe inside the stud
    wall too, should I get some of those braided type flexible connectors
    to attach to the taps, making the job easier?
    Any advice, comments?
    Thanks as usual
    Richard
    , Jun 3, 2005
  2. Wingedcat
    Wingedcat Guest
    >just wondered if
    Yes you can do but it is not necessarily that flexible. You can't bend
    it around 90 degree corners unless you have about huge radius for
    example.
    Yes you can but you need inserts for the plastic section and compatible
    pushfit connectors (Screwfix's Cuprofit will work, others probably will
    too).
    Yes you can but as they restrict the water flow with a very narrow
    opening at the tap end, so if you are already suffering from poor flow
    they will make it worse. It will look better to use copper too.
    Luke
    Wingedcat, Jun 3, 2005
  3. John Rumm
    John Rumm Guest
    Yes it can be simpler in these cases. While it is a bit stiff to work
    with, you can thread it through joists and turn a corner in the space
    between joists. The final rise up to the basin would look better in
    copper of chrome though.
    Yes. You can use push fit on either pipe type.
    It may, although if you have copper "tails" connected to plastic pipe
    you may fine the copper is now easy enough to align anyway due to the
    plastic.
    Cheers,
    John.
    | Internode Ltd - http://www.internode.co.uk |
    | John Rumm - john(at)internode(dot)co(dot)uk |
    John Rumm, Jun 3, 2005
  1. Replies:
    363
  2. Peter
    1,242
    Dave Fawthrop
    Aug 28, 2005
  3. Keefiedee
    1,097
    Keefiedee
    Mar 12, 2011
  4. Keefiedee
    793
    Roger Mills
    Mar 13, 2011
  5. Keefiedee
    329
    Keefiedee
    Mar 13, 2011
