1/3 or 1/2 hp sump pump?
Discussion in 'Home Repair' started by Joe, Mar 7, 2009.
  1. Joe
    Joe Guest
    What factors must I consider on whether I need a 1/3 or 1/2 hp sump
    pump?
    Joe, Mar 7, 2009
  2. Joe
    Joe Guest
    On Mar 7, 10:33 am, Steve Barker <> wrote:
    > > pump?
    > how high do you have to pump it?  Either size will do the job for a
    > normal 9' lift.
    > s
    about 8 feet, is that the only factor or should I factor in how
    quickly the sump pit fills during heavy rain? Will a 1/2 hp will pump
    out considerably more water, faster during a heavy rainstorm or is the
    difference neglible?
    Joe, Mar 7, 2009
  3. Joe
    ransley Guest
    > pump?
    How fast does the pit fill and how many gallons, how high to pump out.
    On Off cycling is hardest on a pump. I would want the smallest that
    will just keep me from flooding. I would set the float switch so it
    runs longest
    ransley, Mar 7, 2009
  4. Joe
    Twayne Guest
    > pump?
    Read the specs on the boxes.
    Twayne, Mar 7, 2009
  5. Joe
    fftt Guest
    > pump?
    I wouldn't focus too much on horsepower...mfr's "fudge" the numbers
    Look at gph & head (lift)
    How quickly does your sump fill up? What pump capacity do you need to
    keep the sump from overflowing?
    Too large a pump will cycle on/off too frequently.
    cheers
    Bob
    fftt, Mar 7, 2009
  6. Joe
    Pat Guest
    > > pump?
    > runs longest
    I surely don't want the smallest that will keep me from flooding.
    There's always one more, bigger storm around the corner. Maybe the
    next one up from the smallest that will keep you from flooding. And
    yes, I will stop calling you Shirley.
    Pat, Mar 7, 2009
  7. Joe
    Kenneth Guest
    On Sat, 07 Mar 2009 10:36:05 -0600, Steve Barker
    <> wrote:
    >Regardless of rainfall rates, the ground will only pass the water at a
    >certain rate. You shouldn't see any real difference in the amount of
    >water running in the sump pit. the 1/3 unit will do just fine. Use
    >1-1/2" line and a check valve just above the water line to prevent the
    >line from flowing back into the sump when it shuts off.
    >s
    Hi Steve,
    I assume that I am misinterpreting what you have written,
    but...
    Sometimes, our sump intake shows a trickle for weeks at a
    time, and sometimes a veritable river.
    What did you mean when you wrote "You shouldn't see any real
    difference in the amount of >water running in the sump pit"?
    I see extremely significant variation...
    Thanks for telling me something more.
    All the best,
    Kenneth
    If you email... Please remove the "SPAMLESS."
    Kenneth, Mar 7, 2009
  8. Joe
    ransley Guest
    > >s
    > Hi Steve,
    > but...
    > All the best,
    > Kenneth
    In spring summer, after all is thawed, with a big 2-4" rain I do get
    alot more pouring into the sump, now the ground is still frozen.
  9. Joe
    Kenneth Guest
    On Sat, 7 Mar 2009 11:23:16 -0800 (PST), fftt
    Hi Bob,
    Why would they "fudge" HP, but not gph & head?
    Thanks,
    Kenneth
    Kenneth, Mar 8, 2009
  10. Joe
    Tom Horne Guest
    > Hi Bob,
    > Thanks,
    > Kenneth
    Because if the pump moves the amount of water to the height they say
    it does and it is overwhelmed by the incoming flow they will not have
    created a cause of action against themselves in civil court. Fudging
    the horsepower makes the pump sound more powerful to a potential buyer
    and there are several ways to calculate horsepower. There is only one
    way to calculate Gallons per Hour at a given lift.
    Tom Horne
    Tom Horne, Mar 8, 2009
  11. Joe
    Tom Horne Guest
    On Mar 7, 11:36 am, Steve Barker <> wrote:
    > >>> pump?
    > >> normal 9' lift.
    > >> s
    > s
    The gallons per minute or hour to be pumped and how high it must be
    lifted are the two things you need to know. The pump should be rated
    in gallons per hour at a given lift. If two pumps will meet the
    requirements and one is one third horsepower and the other is one half
    horsepower I would go with the slightly heavier duty motor.
    An electric motor works hardest when it is starting. To avoid the
    motor having to start under the full back pressure of the lift a small
    hole is drilled in the pipe just above the connection to the pump and
    below the check valve that prevents the water from back flowing into
    the sump. This allows the pump to start without having to lift the
    full column of water during the start. When a check valve is used in
    climates subject to freezing it is important that the piping be
    arranged so that no water will be left standing in piping that is
    exposed to freezing. It may be necessary to raise the water higher so
    that all the piping exposed to freezing will drain to the outside
    after the pump stops. In extreme climates a dry well may be needed to
    allow the sump to discharge underground. If you are blessed with
    terrain that allows underground piping to terminate below your cellar
    floor then you will never have to worry about a frozen or fractured
    discharge line. That is also a case were a battery driven back up
    pump can be fully affective. The back up pump only has to get the
    flow started and the siphon affect will do the rest allowing the back
    up battery to last a lot longer. If you have to discharge the water
    above the level of the sump, like most folks, then discharge it well
    away from the building. If you have utility provided water supply and
    are at risk for prolonged power outages, such as in areas subject to
    ice storms and hurricanes, a water driven ejector; or jet pump if you
    will; is a better back up then a battery powered pump.
    Tom Horne
    #11
  12. Joe
    fftt Guest
    > Hi Bob,
    > Thanks,
    > Kenneth
    because gph & head are verifiable by the user.....
    and horsepower is close to meaningless for the user, all that matter
    is flow rate & head
    shop vacs list all sorts of bs horsepower number....like "develops 3
    hp peak" or some such nonsense
    on shop vac I suggest looking that that amps, not hp
    on pumps....... flow & head (a tabular representation of the pump
    curve)
    cheers
    Bob
    fftt, Mar 8, 2009
    #12
  13. Joe
    fftt Guest
    > > > pump?
    > > runs longest
    Pat, by definition, the smallest one that keeps you from flooding is
    the correct choice. :)
    The pump that "keeps you from flooding" is the right pump.
    Now, how to choose that size pump.....is the trick question. Only you
    know how big your sump is & what sump filling behavior you experience
    (worst case). But having a decent sized sump you might be able to get
    away with a smaller pump, depending on rainfall beahvior. In Socal we
    sometimes get really heavy rain for a day or two (like maybe a
    couple / few inches). VERY occasionally (once every ten years?) we
    can get an inch in an hour. House rain gutters (5") can be
    overwhelmed . On average we get very little rain.
    Knowing your sump filling behavior is the best way to size a pump.
    If your sump sees input at 1gpm, you dont need a 6000gph sump pump.
    If you get a couple gpm...you;re going to need a more capable one.
    cheers
    Bob
    fftt, Mar 8, 2009
    #13
    > > >>> pump?
    > > >> normal 9' lift.
    > > >> s
    > > s
    > Tom Horne- Hide quoted text -
    > - Show quoted text -
    Tom, that is a very good summary.
    Any other points on this subject that you can offer?
    TMT
    Too_Many_Tools, Mar 8, 2009
    #14
  15. Joe
    ransley Guest
    > >> s
    > > Hi Steve,
    > > but...
    > > All the best,
    > I rekon i was just wrong.   Sure you don't have a french drain going
    > into the sump system somewhere?  My sump flow increases during a rain,
    > but not all that much.
    > steve- Hide quoted text -
    Mine is a massive french drain with several large 4" inlets and maybe
    1000 gallon pit, when it rains it pours in, the pit is maybe 5 feet
    wide and 6 feet deep
    ransley, Mar 8, 2009
    #15
  16. Joe
    Kenneth Guest
    On Sat, 07 Mar 2009 20:07:10 -0600, Steve Barker
    >>> s
    >> Hi Steve,
    >> but...
    >> All the best,
    >steve
    Hi again,
    Whew... What was that...? Some Usenet integrity? <VBG> (I
    really appreciate it...)
    No, we don't have a French drain feeding the sump, and we do
    have the variability I had described.
    All the best,
    Kenneth
    #16
  17. Joe
    Kenneth Guest
    On Sat, 7 Mar 2009 19:55:12 -0800 (PST), fftt
    >> Thanks,
    >> Kenneth
    >is flow rate & head
    Hmmm... 'Makes sense. Thanks,
    Kenneth
    #17
  1. Puddin' Man
    Specify/Install Sump Pit and Sump Pump
    Puddin' Man, Nov 24, 2003, in forum: Home Repair
    873
    Speedy Jim
    Nov 26, 2003
  2. Manf. Engnr.
    719
    Manf. Engnr.
    May 6, 2004
  3. Marc_G
    621
  4. Replies:
    504
  5. jtpr
    Sump pump Vs Automatic pump
    jtpr, Mar 15, 2010, in forum: Home Repair
    18
    866
